| Motorbikes Everything related to the two-wheeled breed. |
| | Thread Tools |
| | #661 (permalink) | |
| Senior - BHPian Join Date: Oct 2007 Location: Bombay
| Quote:
| | #663 (permalink) |
| BHPian Join Date: Jun 2005 Location: Thrissur
| Guys, looks like the HID thing is a bit complicated,expensive and risky. Can anyone tell me wether its possible to replace the stock[35W] R 15 headlight which are yellowish to white ones[like the ones on the P200].
__________________ M O N S O O N DRIVE - IAm GAMe 4 IT..... Last edited by Veelubai : 27th June 2008 at 22:21. |
| | #665 (permalink) |
| BHPian Join Date: Mar 2008 Location: Bengaluru
| HIDs expensive ? - absolutely. Complicated and risky - not ! as long as you dont intend to touch the ballast while the HL is on ![]() I have a Vision X HID kit complete with all the required wiring and two ballasts and two bulbs and a relay which is what is required for a Car. I was using one of those bulbs with one ballast and the relay on my P200. You get Bosch,Philips etc HID kits. Many of them are meant for cars hence carry the aforementioned items for a hefty price of around 10K plus. For bikes you get malaysian/chinese single bulb kits from around 4K onwards. You can have either - 1.Single beam HID - only one beam can be used as hi/low 2.HID/Halogen - one beam is HID(usually low beam),high beam halogen though its a matter of changing the connections in the switch to use it in the opposite way. 3.Bi-Xenons - low and hi beam HID - either there are two arcs one for each beam or a single beam that is moved fwd and back for hi and low respectively. Mine is the last version.,but the CT is 6000K. Best Colour temp would be 4300K. And I saw the R15 specs sheet - the HL is 35/35 12V and nothing has been mentioned about the batt IIRC ...so its Ah rating is a mystery... |
| | #666 (permalink) |
| Senior - BHPian | The Yamaha R15 has H4 Xenons... Its recommended to get the HID's specially for the bike and not the ones used on cars as the HID which are made for bikes have an extra relay and booster to boost the power of the light..
__________________ Mitsubishi Cedia - Pearl White Skoda Octavia vRS - Magic Black Last edited by karthik247 : 27th June 2008 at 23:27. |
| | #667 (permalink) | |
| Quote:
Can you pls clarify when you say "HIDs specially for the bike" ? Because the only difference is in the pkg contents - bike kits have only one ballast and one HID bulb. There will almost always be a relay. Before that the HIDs ( meant for cars) came with 2 bulbs and 2 ballasts - one for each Head Lamp obviosuly ..and there is a single relay of course. ![]() What I mean to say is .. there is no difference technically in the so called "bike" kit and the "car" kit. You get one bulb and ballast less , thats it. The "boosting" you mentioned is actually the signal amplification done by the ballast so that your low voltage signal from battery is amplified to 22kV with a suitable current rating to keep the overall power dissipation/consumption to 35W. Such kits are the 35W ballast kits. Similar explanation holds good for 55W kits.This is no different in a "car" kit or a "bike " kit. As I said, the bike kit is just the car kit without the extra ballast and bulb. Anyway, I dont see why you can't use a HID on the R15. pls correct me if I am wrong - since I have not heard or read about any technical differences in "bike" and "car" kits. | |
| | #668 (permalink) | |
| Quote:
I think the the R15 has H7's, which means one is a low beam and the other the high beam. If it has H4's as you say then both lights will be on at the same time and change to high & low beam at the same time. | |
| | #669 (permalink) |
| Senior - BHPian | The guy who installed HID's on the R15 from XBHP told me it was H4s... Dunno if its right or not.. Can u explain how the kit will work on the bike? Like how the two bulbs will work... cuz one is highbeam n the other is lowbeam And do u get 4bulbs with a H7 kit?? 2low n 2high?? So do u need to use only one pair ie 1low n 1high on the bike which means the other set is not needed??
__________________ Mitsubishi Cedia - Pearl White Skoda Octavia vRS - Magic Black Last edited by karthik247 : 28th June 2008 at 00:14. |
| | #670 (permalink) | |
| Quote:
| | #672 (permalink) |
| Senior - BHPian | The bikes are here but deliveries will start only on July 1st cuz of some RTO approval thing... And as for the no. plate, gonna smoke/paint the visor black and will stick it on the visor.
__________________ Mitsubishi Cedia - Pearl White Skoda Octavia vRS - Magic Black |
| | #673 (permalink) |
| Even here the deliveries are slated only for July 1st.Even Iam planning to do the same but looks like that rod which holds the orginal Lisc.plate cant be removed.
__________________ M O N S O O N DRIVE - IAm GAMe 4 IT..... |
| Thread Tools | |
Similar Threads | ||||
| Best 150 - 200 cc Motorcycle for my son? EDIT - Bought Yamaha R15 | shishya | Motorbikes | 43 | 24th October 2009 13:17 |
| Yamaha V-MAX launched in India 16/9/09 | navpreet318 | Motorbikes | 32 | 22nd September 2009 14:46 |
| ALL RISE! Toyota Landcruiser coming to India EDIT: Launched at 81 lakhs | GTO | The Indian Car Scene | 170 | 21st July 2009 20:02 |
| Yamaha to bring R1, MT-01 superbikes: Edit: Now launched at 10.5 lakhs | black12rr | Motorbikes | 433 | 28th March 2009 16:04 |
| VW Jetta is Launching in India EDIT: Now Launched | nicejits | The Indian Car Scene | 249 | 8th October 2008 16:41 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
