| Motorbikes Everything related to the two-wheeled breed. |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jun 2007 Location: Chennai
| I have a Yamaha RX135...2002 model. I want to replace the carburetor for better pick up...which is the best suited one for this model...need advice ![]() Last edited by bharath.kan : 13th February 2008 at 12:45. |
| | #2 (permalink) | |
| Senior - BHPian | Quote:
If the result pickup doesnt excite you, go to the next level of porting, replacing reed values, bigger jets etc. Take mods stage by stage so you can achieve the desired level as I learned from personal experience.
__________________ *06 Alto LXi* *97 Zen LX* *03 HH Ambition* *RC Cars - HPI Baja 5B SS, Thunder Tiger SledgeHammer S50, ST-1 & Sparrowhawk XB* Last edited by mail4ajo : 14th February 2008 at 18:48. | |
| | #3 (permalink) |
| BHPian | First start with Digital CDI then air filter along with bigger jets may be a bigger carb itself(flat slider will be the best), Porting, race piston and long connecting rods, carbon fibre reeds, fully synthetic gear and 2T oil(preffered Motul), weight reduction and if its 4 speed then make her 5 speeder and you are done.
__________________ Ab main rashan(malls) ke kataron main nazar aata hoon. JS. |
| | #5 (permalink) |
| Senior - BHPian Join Date: May 2005 Location: TRV
| First start with an air filter like the Uni or the K&N, upjet your carb. You will get a slight improvement in performance. If you want more add a well designed expansion chamber to the setup. Again upjet your carb. For more performance think about getting your RX ported from a reputed tuner. Increase the compression by milling the head. Again check and upjet the carb. You might have to use another expansion chamber which will match the new port setup. Your old expansion chamber might not work properly. This is not the end but if you do upto this level you'll get good performance out of your RX. Bigger carbs and aftermarket CDIs can be thought of during later stages it's not needed at this stage, the stock CDI is good enough. Last edited by Sankar : 14th February 2008 at 23:31. |
| | #6 (permalink) |
| Senior - BHPian | In addition to what Sankar has rightly advised, I want to add some info that may help you. As far as I know, some years of the RX135 came with a larger VM22 carb. For emissions they went back to the VM20 in later years. You might want to check exactly which carb you have. Just changing the carb wont net you anything, actually maybe a little top end but the full advantage of the carb wont be realized. Your first step should be to go to someone who knows what he's doing, and get a matched port job and expansion chamber, along with jetting. Do NOT buy a generic chamber and then get it ported by someone. Then go ahead and get the supporting equipment like an aftermarket CDI ignition and a UNI filter. Anything over a 22 mm wont be useful on a street-oriented engine IMO. People will throw around big numbers like "Yeah, my bike pulls to 13000 rpm" but ask him in what gear he drives around town, the answer will be 1st gear. The point is, a bigger carb alone is useless.
__________________ No Try. Do. Or do not. - Yoda. Last edited by ananthkamath : 15th February 2008 at 08:31. |
| | #7 (permalink) |
| Team-BHP Support ![]() | A motorcycle is God's way to remind us he exists. You can do whatever is possible to increase the bhp the torque and all that force but how will you get your bike to stop without breaking you up. I suggest you change your bike to a bigger one. Why don't you check out the 220 cc bikes from Bajaj and HH. or try your luck in finding a RD350E. Its not just about going fast, its also about coming to a stop fast and safe.
__________________ Ever catch yourself listening to a nice song on the radio and dedicating it to your car. |
| | #8 (permalink) | |
| Quote:
i have not installed any add on to the existing machine...i wanted to know the brand of the equipments which can fit into the vehicle...which will be of great help. | |
| | #10 (permalink) |
| Hey did some improvement in my Yamaha...first of all i removed the big and heavy silencer to the past and traditional Yamaha silencer...then the cab part i have just cleared out the clouding and u can find the difference... am planning to add some performance upgrades to the vehicle and will keep you posted on the same....thanks for the advise guys pic of the bike and specs will be let out after the complete make over ![]() |
| | #12 (permalink) | |
| BHPian Join Date: May 2008 Location: Back in Chennai
| Quote:
| | #13 (permalink) |
| BHPian | this is my friends bike rx 135 5 speed, 2003 model. as u can see, he keeps his bike well. just got the tyres replaced by mrf rear ones and got the tail lamp and all indicators changed today. battery used is exide 7 volts. opinion wanted for performance mods ![]() |
| | #14 (permalink) |
| Senior - BHPian Join Date: Oct 2004 Location: Vikhroli, Mumbai, India
| Dear pulsarmaniac, Are you sure that is a 5-speed? The graphics look totally different. The stance though is the same. AFAIK, the 5-speed is a bit taller. Atleast mine was compared to my friends 4-speed. |
| Thread Tools | |
Similar Threads | ||||
| WTB: Yamaha RX135 in Bangalore | nitin.dangayach | Shifting gears | 5 | 8th August 2009 17:42 |
| Recommended Yamaha RX135 mechanic in Delhi? | Shakensoul | Motorbikes | 114 | 24th June 2009 23:32 |
| My friend's Yamaha RX135 5 Speed | manjunag | Motorbikes | 37 | 18th March 2009 19:06 |
| Yamaha Rx135 (1998) | blasé | Shifting gears | 1 | 29th December 2007 00:26 |
| Yamaha RX135 5 Speed - help | MillionSwords | Motorbikes | 6 | 5th December 2007 13:17 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
