| Motorbikes Everything related to the two-wheeled breed. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Where in Pune or Mumbai can I get my Engine Balanced? I've got aftermarket pistons and rods for my RD350. For the new rods to fit, the webs have to be modified and the new Wiseco Pistons weigh lesser than stock (don't have the exact figures). And so I'll have to get my crank dynamically balanced. I would want to go to someone who's been building cranks for so long that 'crank' is his middle name now. It need not be a 2-wheeler guy. Afterall, a crank is a crank. After reading the RD350 part, I know MOST of you would suggest Ron Chinoy. But I have already dumped the option. Not because he's not good at what he does. But because I'll have to send off the crank to him and I'll miss out on learning from the whole experience. PS: Delibrately not posted in the motorcycles section.
__________________ Motorsport is the only 'REAL' sport.... all others are just Games! Aalap Patel '97 Zen '88 RD350 Last edited by dustDevil : 15th March 2008 at 23:24. |
| | #2 (permalink) |
| Team-BHP Moderator ![]() | 2 stroke cranks are quite a bit different from 4st because they run on needle bearings. Does Wiseco recommend that the crank be balanced? If the weight drop is negligible, then it may not be necessary.
__________________ The difference between the men and the boys....................is the speed of their toys. |
| | #3 (permalink) |
| BHPian | No wiseco did not recommend balancing as such. But the con-rods are actually for the Banshee ATV. These can be used with the RD crank,but with a little modification to the webs. That is why it'll require balancing. Where can I get it done?
__________________ Motorsport is the only 'REAL' sport.... all others are just Games! Aalap Patel '97 Zen '88 RD350 |
| | #5 (permalink) |
| Senior - BHPian | If a shell bearing or a bush bearing like in the fourstrokes is being used the crank needs to run in wet sump where it can do with the oil splash lubrication or the big end should be pressure fed; or both. The shell and bush bearings need pretty good lubrication. This will not work with a two stroke in which the crankcase is sealed and the lube is provided by mixing the 2t in the petrol. So needle bearings are used at the big end and the small end pins. Even crank main bearings are lubricated by 2t oil in the fuel.
__________________ "Auto racing, bull fighting, and mountain climbing are the only real sports... all others are games." Ernest Hemingway |
| | #7 (permalink) |
| Senior - BHPian | There used to be one guy in Chennai who could do dynamic crank re balancing. He's known amongst the performance Bulleteering crowd. Maybe someone from Chennai could help you.
| | #10 (permalink) | |
| BHPian Join Date: Mar 2004 Location: Ludhiana
| Quote:
Now that you've already dumped that option, I'll try and enquire from some friends in both Pune and Mumbai
__________________ Punjabi for Life. | |
| | #14 (permalink) |
| Senior - BHPian | Aalap, I am free on Friday 21Mar'08. Give me a call and I'll take you to the right places to get the crank balanced. I hope its the original RD crank and not the altered KB crank that is more usually found in RD's?
__________________ Ask not what your country can do for you, think of a way you can make them do it! |
| | #15 (permalink) | |
| Senior - BHPian | Quote:
Small fourstroke engines with needle bearings at the big end can do with splash lubrication.
__________________ "Auto racing, bull fighting, and mountain climbing are the only real sports... all others are games." Ernest Hemingway | |
| Thread Tools | |
Similar Threads | ||||
| santro (Nov 2004) crank shaft failure at 30000km | msvilkhoo | Technical Stuff | 15 | 11th March 2008 23:02 |
| Forged Baleno Conrods , Crank , performance cam and intake manifold for SALE !!!! | mclaren1885 | Shifting gears | 0 | 24th April 2007 23:23 |
| What is Crank Scraper | finetuning | Technical Stuff | 6 | 26th October 2006 18:03 |
| wheel balancing | amit2036 | Tyre & Alloy wheel Section | 2 | 12th June 2006 10:13 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
