Old 22nd March 2008, 03:48   #31
Psycho's Avatar
Thanked: 95 Times
Psycho he has a Thunderbird, it has a BS carb. With the BS carb if you screw in then the mixture becomes lean because it's a fuel screw and not the air screw.
I am going senile.
Old 24th March 2008, 13:09   #32
bblost's Avatar
Thanked: 6,980 Times
Default Update
I took off on a ride from Hyderabad to Lonar on Saturday.
Total Distance about 900+ in two days.
The jerks come back on the way to SangaReddy.
After breakfast there replaced the spark plug and the power become smoother.
However there are 2 issues that remain.
Issue #1
I need to keep toggling my headlight(High Beam).
With it ON the ride is real smooth for about a 100 kms.
Switch it OFF, ride becomes smooth for the next 100 kms.
I am guessing its something to do with my CDI or my 4.5 year old battery.
Issue #2
I would sometimes get turbo lag kind of feeling on heavy acceleration.
Since FFE is not a co-requiste, K&N has MANIFESTED itself in my mind shopping list.
I rode 12 hours in the rain yesterday and my bike never stalled.
Ride write up as soon as I get the time.
THANKS
Old 24th March 2008, 15:06   #33
bblost's Avatar
Originally Posted by abhi View Post
How much mileage do you get?
Long ride meant the roads were counting.
I got an average of 40kmpl riding with a pillion at speeds generally on the 85+ side.
Old 25th March 2008, 12:10   #34
bblost's Avatar
Detailed ride story
http://www.team-bhp.com/forum/travel...-big-hole.html (Lonar: A wet ride from the big hole)
Old 10th November 2008, 11:35   #35
bblost's Avatar
I did not want to create a new thread for this question of mine.
CLUTCH.
Some slipping has started coming thru and I am replacing the clutch.
I ran google and found this
Royal Enfield Motorcycles - Motorcycle India | Custom Motorcycle Kit | Custom Harley Davidson Accessory | India
At Rs 41000 it is 100 times the cost of a stock clutch.
Any alternatives.
Old 10th November 2008, 12:17   #36
Spitfire's Avatar
Thanked: 707 Times
40K? What is it made of? titanium?
Why the need to go for an aftermarket? Stick to Stock.
Spitfire is offline   Reply With Quote
Old 10th November 2008, 12:36   #37
bblost's Avatar
I can only wonder what its made up of.
A correction to my earlier post.
and its price is 30k.
Still way over what I am prepared to pay.
@Spitfirel: No reason per se. Would like to evaluate available options.
Since the stock clutch is quite cheap at 400 bucks, I don't mind experimenting a little.
Old 10th November 2008, 16:11   #38
deepclutch's Avatar
Thanked: 110 Times
I got a 2005 electra 4S.the air filter is fitted in RHS box.I didnt felt any missing apart from once when filled from a spurious source.
I am not into modding.but If I fit a K&N filter for my bull ,what things can I expect?
@bblost :I think 40kmpl constant mileage is possible with AVL engines.but at 80kmph ?
deepclutch is offline   Reply With Quote
Old 11th November 2008, 23:12   #39
Hi... Guys I need some help.. My bull is not doing good these days... On a highway flat road she goes like a rocket...but on a ghat she fails to run... she losses her pressure.. I got it checked but still i feel the same... Any Bright Idea's!!!!!
prem_j is offline   Reply With Quote
Old 7th April 2009, 13:16   #40
bblost, how did you resolve this issue ?
Issue #1
shldn is offline   Reply With Quote
Old 7th April 2009, 13:22   #41
bblost's Avatar
Since last reported the issue no longer occurs on my bike.
These have happened to my bike since then:
3rd battery.
Twice changed as the Amaron was faulty and I got a replacement from them.
The manifolds on both sides of the carb are new.
New clutch plates. Bike was 5+ years old when changed.
I don't know which of these is responsible for fixing the issue.
Mercedes E280 CDI: Jerky with heavy throttle inputs Naman_Ferrari Technical Stuff 39 19th July 2018 15:34
Steering jerky after wheel balancing and alignment zaks Tyre & Alloy wheel Section 7 5th January 2015 12:15
Chevy Optra 1.6 Help: Jerky at times rajismine Technical Stuff 8 9th January 2011 20:34
Esteem jerky acceleration starting problem...help devp24 Technical Stuff 27 18th November 2010 12:50
Jerky braking in the DiCOR. Dragonov Technical Stuff 5 1st April 2007 03:12
