Old 18th July 2008, 17:47   #151
Shakensoul's Avatar
Thanked: 222 Times
Oops, then its going to be halonix
Shakensoul is offline   Reply With Quote
Old 19th July 2008, 00:52   #152
Originally Posted by Shakensoul View Post
Pradeep, some more small queries for you
Which headlight bulb have you installed now ? I was not able to find the normal philips 60/55 bulb in all the car accessories shop I asked, they only stock the crystal vision sort of bulbs which are available only in pairs, costing 800-1000.
However the Halonix 60/55 bulbs were available.
Originally Posted by straight6 View Post
I have never seen a 60/55 Philips bulb. The stock bulbs in most cars is the Halonix.
Kawasaki Bajaj Eliminator came with Philips 60/55 bulb as oem fitment for the headlight.
Was Rs 160/- or more in 2001 and i was too glad to pick up a few and keep them for later.
Philips 60/55 was there in the catalogue but a rarity in Indian market- only 100/90 available and that too with quite some difficulty then.
Check with a Bajaj authorised workshop- they may have some still.
Pulsars and Avengers definitely use cheaper options imho.
BIKeINSTEIN is offline   Reply With Quote
Old 19th July 2008, 01:11   #153
Sankar's Avatar
Thanked: 4,654 Times
Hmm... is it that hard to source 55/60 Phillips bulbs there? These are available (P43T type) off the shelf in most shops here. My Bullet has a Phillips halogen.
Old 19th July 2008, 04:02   #154
straight6's Avatar
Thanked: 118 Times
All Maruti cars come with the Halonix as standard.
straight6 is offline   Reply With Quote
Old 25th July 2008, 10:59   #155
praJEEP's Avatar
Just got this carburettor through a very well known contact this carburettor runs on 145 size jets. can i use it ? need your inputs and suggestions..
Adding some pics for reference.
praJEEP is offline   Reply With Quote
Old 25th July 2008, 11:38   #156
hillram's Avatar
Thanked: 981 Times
These are not Carburators..but Objets d'art
hillram is offline   Reply With Quote
Old 25th July 2008, 11:39   #157
praJEEP's Avatar
I would defenetly blame my ignorance here could you please care to explain the same for me.
Old 25th July 2008, 17:29   #158
straight6's Avatar
Thanked: 118 Times
What he meant to say is that they are damn good! Its definitely a carb and my friend was using it in the RXZ. Take it to Joe.
Old 25th July 2008, 19:37   #159
For lighting , if you use a yezdi dome , then try the OSRAM silverstar or even the Halonix+60 which is 60/55W. Very good bulb - 110 bucks I think.
Sandeep_K_Ram is offline   Reply With Quote
Old 9th August 2008, 11:40   #160
praJEEP's Avatar
Another snap of the carburettor i just removed it to check the jet size
its 145. Can i use it ?
Old 10th August 2008, 16:02   #161
chiragh_bir's Avatar
Thanked: 70 Times
145 jet looks like Rd 350's carb!!
you have to modify needle of that carb..
chiragh_bir is offline   Reply With Quote
Old 11th August 2008, 11:00   #162
praJEEP's Avatar
How is that done buddy please care to explain.
Old 11th August 2008, 12:11   #163
Sankar's Avatar
It's not an RD carb Pradeep. So don't bother with anything at this moment. And you haven't yet told me the diameter of the venturi.
Old 11th August 2008, 15:11   #164
Thanked: 70 Times
so which carb is that?
Old 11th August 2008, 17:44   #165
praJEEP's Avatar
Here you go its 28.4mm.
i was told that rd carbs jet size is 140
@sandeep this is what is imprinted on the carb 2YA00
The Joy of Living a Dream - Honda Civic S MT (Pre-Owned) arvi86 Test-Drives & Initial Ownership Reports 292 13th July 2016 21:03
200 days of Living a Dream. My i20 Diesel Asta ! Kimified Test-Drives & Initial Ownership Reports 91 28th June 2012 11:02
Realization of a dream - Living with my VTEC avinash_m Test-Drives & Initial Ownership Reports 77 29th June 2010 14:56
The story of how I have lived with my dream for 8 years. The YAMAHA RX-135, 5 Speed. 4strings Motorbikes 5 11th April 2009 10:56
