Old 21st September 2008, 22:51   #181
Sankar's Avatar
Thanked: 4,654 Times
Pradeep,
In due course of time i suggest you do this:
1) Replace the current stamped metal upper triple clamp with the older type much better cast aluminium unit.
2) Change the headlamp ear clamps to the older type.
3) Put lower triple tree chrome caps along with the above suggested mod.
4) Change the round meter console to the old three piece unit.
Do all that and your bike will have that real RX charm. Yamaha made all these changes to the later model RXes to economise and share parts across other models. When they did that it lost a little bit of character of the original RXes. Looks wise the sore parts are the round pod meter and the stamped metal upper triple clamp. I hope you take this in the right sense. Your decision to fix the older type indicators is good! And the bike is shining!
Old 29th September 2008, 17:48   #182
Shakensoul's Avatar
Thanked: 222 Times
Cool number plates.
Where did you get them made and how much ?
Shakensoul is offline   Reply With Quote
Old 29th September 2008, 22:49   #183
pulsarmaniac's Avatar
Thanked: 9 Times
hey prajeep! i wanted to know how much those rx indicators cost you? we found the duplicate one in nagpur for 120 rs but couldnt get the original ones. thats what is missin in our bike i guess. but your bike looks cool man. and yeah even i want to know how much those number plates cost you... will get one for my pulsar but in a different font maybe...
pulsarmaniac is offline   Reply With Quote
Old 30th September 2008, 00:24   #184
Shakensoul's Avatar
Thanked: 222 Times
I recently got the RX indicators for 45 each, original is 100 each. But the 45 ones are not bad, they are of decent quality.
Old 30th September 2008, 06:54   #185
SunnyBoi's Avatar
Thanked: 2,832 Times
I got myself 4 original indicators and 4 original RD red lenses have to put them on...
SunnyBoi is offline   Reply With Quote
Old 30th September 2008, 09:30   #186
Awaiting Email Confirmation
Nice bike praJEEP. Didnt like the instrument console though. No offence meant, just my opinion. Any idea where in Bengaluru/Hyderabad I might find original RX100 butterfly crashguard?
NitinGirish is offline   Reply With Quote
Old 11th October 2008, 11:42   #187
Thanked: 9 Times
i agree with you man.the only thing missing seems to be the rectangular console of the rx135.and shift the toolbox below the battery to the other side.the acid leaks common in the rx may spoil all the documents you keep in the box
Old 11th October 2008, 12:10   #188
praJEEP's Avatar
Sorry for the late reply guyz
Originally Posted by Shakensoul View Post
Cool number plates.
It costed me 550 for a pair
300 for 4 indicators, number plates 550 for a pair this is the standard font available afaik there are no other choices available.
RD lenses yen guru adhu !! brief explanation needed
Thanks nitin try JC road, RX 100 original i am trying from ages let me know if you find one.
Thats not reqiuired i am using a dry amaron battery, so no acid leaks
EDIT : P.S Above the tool kit there is airfilter the battery is on the left side, i wonder what you are talking about !!! huh
praJEEP is offline   Reply With Quote
Old 12th November 2008, 16:05   #189
praJEEP's Avatar
*Bump*
Could any one tell me what model is this unknown filter its lying around with me since 1 year ( i have lost the box and forgotten the model number ) so planning to use it. need inputs.
A pic of it.
Last edited by praJEEP : 12th November 2008 at 16:13. Reason: Edited after sankar said its not a K&N thanks sankar.
Old 12th November 2008, 16:07   #190
Sankar's Avatar
It's not a K&N filter Pradeep. it is a steel mesh filter with no cotton layer in between. It looks similar to the HP steel mesh filter i had on the Bullet.
Old 12th November 2008, 16:27   #191
praJEEP's Avatar
Thanks for clarifying sankar, can i use this filter ! sorry if i sound dumb
Old 12th November 2008, 17:00   #192
Ajaybiz's Avatar
Thanked: 141 Times
You can mate but be careful with high flow air as it leans the mixture and the engine life will compromised, do a plug chop to see that if its makeing the mixture lean and milage is increasing after that do the jetting part with some expert if you cant on your own.
Ajaybiz is offline   Reply With Quote
Old 12th November 2008, 18:12   #193
Sankar's Avatar
Don't use it mate, go for UNI or K&N. The filter won't filter well and will screw up your engine.
Old 13th November 2008, 10:41   #194
praJEEP's Avatar
thanks for clarifying ajay, its better i don't use it.
Which K&N model to be used ? any idea about the prices, its better you give me some 2 or 3 options.
Regarding sound does uni sound less than K&N.
Old 13th November 2008, 16:00   #195
Ajaybiz's Avatar
Thanked: 141 Times
I am getting 5 speed RXZ in couple of days and very first thing is going to be Uni filter, upjeting and CDI, porting, chambers, new piston with con rod after some time.
The Joy of Living a Dream - Honda Civic S MT (Pre-Owned) arvi86 Test-Drives & Initial Ownership Reports 292 13th July 2016 21:03
200 days of Living a Dream. My i20 Diesel Asta ! Kimified Test-Drives & Initial Ownership Reports 91 28th June 2012 11:02
Realization of a dream - Living with my VTEC avinash_m Test-Drives & Initial Ownership Reports 77 29th June 2010 14:56
The story of how I have lived with my dream for 8 years. The YAMAHA RX-135, 5 Speed. 4strings Motorbikes 5 11th April 2009 10:56
