Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 22nd April 2008, 12:39   #76 (permalink)
praJEEP's Avatar
Originally Posted by straight6 View Post
That timing seems to be the trend in Bangalore. Do you know Irshad bhai in Shivaji Nagar? He too opens shop in the afternoon and stays until 2 am or so.
No idea weres irshad's garage in shivajinagar, i am familiar only with joe's garage. i pass by his garage every morning on the way to office.
__________________
A wise man should have money in his head,
but not in his heart.
jonathan swift
praJEEP is offline   Reply With Quote
Old 22nd April 2008, 12:58   #77 (permalink)
straight6's Avatar
Hey, just wanted to you if you can toggle between low and high beam after the upgrade or is it just the low beam?
straight6 is offline   Reply With Quote
Old 22nd April 2008, 14:42   #78 (permalink)
praJEEP's Avatar
No you can toggle betwen hi and low. there is nothing special about it which dome (doom) you are palnning to install.
__________________
jonathan swift
Old 22nd April 2008, 14:52   #79 (permalink)
straight6's Avatar
Like Sankar said, the Mazda headlight unit which will go straight onto the bike.
Old 25th April 2008, 15:53   #80 (permalink)
praJEEP's Avatar
A sad update guyz, well there is some bad news, when i was not present in bangalore my brother in law has screwed my bike's virginity sad but true its no more a virgin. yesterday evening i just went to my in laws house to pick up the bike and saw the odo & there was a differenece of 250kms. i took the bike out and started there was a wierd sound from the engine and hell lot of vibrations. i knew i was taken for a ride, i just parked the bike inside the house. went back today morning and pushed the bike till joe's garage which is 3.5kms away from my inlaws house. i was dead tired by the time i reach the garage. infact i was expecting only the piston rings might have worn out. joe called an hour back and told the scenario just went immediatly to his garage and the worst had happened the seizure. i am very sad and dippressed after seeing my bike in that condition. i am out of words...
P.S sorry mobile cam.
__________________
jonathan swift
Old 25th April 2008, 16:09   #81 (permalink)
S@~+#0$#'s Avatar
Sad to hear that Prajeep. But don't worry you are in good hands. Joe is an excellent mechanic and your bike will be back in good shape soon.
Regarding the seizure....could be because of lack of 2T oil in the can. If the Oil Pump been disconnected, I think it is because your brother-in-law did not know that he has to mix 2T oil with Petrol.
__________________
Santhosh
U'll never lead in someone else's tracks. Cut your own!
S@~+#0$# is offline   Reply With Quote
Old 25th April 2008, 16:12   #82 (permalink)
maddy42's Avatar
Thats sad buddy. Hope she gets well soon
__________________
Life is Short Drive HARD!!
maddy42 is offline   Reply With Quote
Old 25th April 2008, 16:13   #83 (permalink)
praJEEP's Avatar
You have hit the nail, my oil pump is working fine this bugger has dissconnected the oil pump connection and driven it as a four stroke bike. i ask him why you dissconnected ? he says there was more smoke so i disconnected. more over he has ripped the bike like anything.
just see the last pic there is still 500ml of 2t oil left.
could you imagine the height of stupidity...
__________________
jonathan swift
Old 25th April 2008, 18:34   #84 (permalink)
Sankar's Avatar
Straight6: The SMazda units take regular H4 bulb. So you can have both high & low beams in one.
Fourth pic: Who's hand is that? I have that same watch
Prajeep, i would like to see the side shots of the piston so that the location of the seizures can be seen. If the seizure is on the intake side of the piston skirt it's generally due to a lack of lubrication. If the seizure is on the exhaust side then it's due to overheating.
If the con rod doesn't have any axial play leave it as it is. There is nothing to worry about contrary to whatever the mech will say. I have never resetted the crank, like the mechs suggest, after a seizure. I only get it done if there's too much play on the rod. You don't have to worry about lateral (side to side) play if it's not too excessive.
And you total cost would be:
Piston 500 (Escorts) or 1200 (ART-OEM)+
150 rebore+
Around 50 bucks for new gaskets+
Labour
__________________
Never argue with idiots. They'll drag you down to their level and beat you with their experience.
Old 26th April 2008, 10:43   #85 (permalink)
straight6's Avatar
Is he insane or something? How can you be stupid enough to not know that a 2 stroke bike cannot work without a supply of 2T oil? If I was in your place, he would be preparing to leave Bangalore before I got to him.
Old 26th April 2008, 13:48   #86 (permalink)
praJEEP's Avatar
There is nothing we can do here straight6 the relationship bonds stich our mouths.
Thats my hand the watch is fasttrack. you have bought it after seeing mine you are copycheat...
Just wait for a day will get some good snaps. just couldn't get my hands on my canon.
The con rod had some play yesterday, i visited the garage today morning now its stiff and tight. regarding resetting the crank will speak to joe and let you know. one of the engine bearings has worned out. i have told to replace both of them.
150 rebore+
Labour
So according to you 2k is the estimate, just hoping my bill will be the same. (fingers crossed)....
__________________
jonathan swift
Old 27th April 2008, 01:47   #87 (permalink)
Sankar's Avatar
Hehehe.... i bought that fasttrack almost 2 years ago
__________________
Old 27th April 2008, 16:48   #88 (permalink)
praJEEP's Avatar
whatever you say you are a copycheat.
Bike is back from the garage and he is rocking..already completed 130kms of runnin, still 930 to go. joe's work is awesome, total bill came upto 3k. i got the coil rewinded and the regulator changed. sankar the swaraj mazda's reflectors rock.
__________________
jonathan swift
Old 27th April 2008, 19:12   #89 (permalink)
OMG! Sad to know the incident. Man what a blow to the bike??
__________________
Spirit with a vision is a dream....with a mission....
metropolis is offline   Reply With Quote
Old 28th April 2008, 10:07   #90 (permalink)
straight6's Avatar
Hey, I'd like to see pictures of the new headlights in action and also the fit.
Thread Tools
Dream Come True - Our Dream Machine Safari 2.2 VTT kdeepakk Test-Drives & Initial Ownership Reports 55 4th August 2008 14:23
Living in Hyderabad fergus Shifting gears 33 8th April 2008 08:55
Living in Pune. doomsday Shifting gears 4 1st December 2007 19:50
Living in Bangalore firingonallfour Shifting gears 21 23rd November 2007 23:17
Living in Delhi Kaizer Sozay Shifting gears 12 21st November 2007 17:17
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
