Old 20th May 2008, 17:14   #106
praJEEP's Avatar
There is a small problem in the bike ? i had been to sarjapur on sunday the route i took is the inner ring road via marathalli, to and fro i was maintaining a steady speed of 60/70km while coming back near hebbal lake the bike stalled as if it is out of fuel and came to halt . i started the bike and observed no problems at all. everthing was fine the engine was running smooth as it was earlier.
My doubts :
Did the bike came to an hault ( over heating ) coz i was running continously non stop from sarjapur without any stop or breaks.
When we ride the bike on the highway should we add 2T in the petrol directly ? if yes how does this procedure help ?
This problem is quite new to me as i am used to 4stroke bikes a lot.
praJEEP is offline   Reply With Quote
Old 20th May 2008, 19:18   #107
mail4ajo's Avatar
Thanked: 261 Times
Did the bike stop all of a sudden or did it lose pickup and then stalled gradually? Did it get heated more than normal? Check the oil delivery from the pump. Is it even? I just suspect some dirt in the fuel lines.
I have ridden 85+kms without stop. So that shouldnt be an issue. Adding a little 2T in the tank doesnt hurt. About 20-30 ml for a litre of petrol should be ok. Will give a smoother ride and keep the tank from rusting, but expect more smoke.
mail4ajo is offline   Reply With Quote
Old 21st May 2008, 11:30   #108
ScarySkulls's Avatar
Thanked: 19 Times
Yes true. But till he starts modifying the engine and take it outside the stock operating RPM and powerband range there's no real need for an advanced digital cdi.
It's a necessity once the engine has been worked upon and starts going way beyond 8krpm.
makes me wonder from where people come up with theories like that
My doubts :
If you tried starting the bike immediately and it started, then extremely funny.
Probably a the carbs need servicing. Check if the breather pipe is clogged.
Happens a lot with Karizmas. Bike starts and dies down/refuses to start.
Open tank, shut it again and it runs great.
ScarySkulls is offline   Reply With Quote
Old 21st May 2008, 11:33   #109
praJEEP's Avatar
Ajo i was cruising at 60/km the bike jerked as if it was out of fuel and came to an hault. engine was not overheated. the oil pump is fine i even cross checked it. it is been set to either low or high ( midrange ) .
In highways more smoke doesn't matter it just vanishes away, wheras in city every chap will be staring at me at every signal... cursing me is this guy nuts why cant he turn off his bike
@ scary what funny do you feel, will get the carb cleaned and keep you posted.
Old 21st May 2008, 12:05   #110
Thanked: 19 Times
Carefully observe how he's cleaning the carb. Buy a basic tool kit and start to do wrenching yourself.
I refuse to believe that anyone can have a good 2 stroker untill the guy can wrench himself. Or even a good 4 stroker.
Buy a good carb cleaning spray. Never let the mechanic clean emulsion tube etc. with wire/something sharp.
Start saving up for an aftermarket ignition if you really want the bike to run nicely.
Old 21st May 2008, 12:32   #111
straight6's Avatar
Thanked: 118 Times
How many kms did you run the bike in for after that new piston was installed?
straight6 is offline   Reply With Quote
Old 21st May 2008, 13:58   #112
praJEEP's Avatar
Even i think of it doing myself, for time being i clean the airfilters and other small things myself. i will carefully observe how he cleans and do the same myself from next time. i may sound dumb may i know what is emulsion tube ? what after market ignition you are reffering to ? is it RD chenoy from rd dreams.
950kms speeds maintained 40 to 50 km/hr.
Old 21st May 2008, 23:35   #113
Thanked: 19 Times
Good Job! My best wishes
No question is dumb. You are infact smart to come forward and ask.
First understand Emulsion.
It is a mixture of two things, petrol and air (which do not fully mix) in the carb before it is discharged and atomized.
Emulsion Tube
is the perforated, hollow, round bronze/brass coloured tube (normally). Air is introduced into the mixture through holes to help atomize it and correct excessive richness at higher engine speeds. The Emulsion Tube mixes air from the air corrector jet with fuel from the main jet, and controls the mixture from the discharge nozzle at all engine speeds that the main jet is working.
Yes. The same one. The fact that there are no substitutes to this kit that I know of, makes me suggest this even more firmly.
At those constant speeds all the time, the cylinder walls are only getting glazed. Nothing else. Do push the bike in small bursts of speed periodically (before settling down to a cruise again) so that piston rings exert proper force on the cylinder walls and seal up well in the process.....
Old 22nd May 2008, 11:07   #114
Sankar's Avatar
Thanked: 4,638 Times
This is what i've been trying to tell you Pradeep and everybody else who buys a new bike and systematically do the run in according to the manual. And the grievous mistake is made when you take the bike to 100kmph on the 1001th kilometer.
Old 11th June 2008, 16:02   #115
praJEEP's Avatar
UPDATE:
The rear tyre has been changed back to MRF Moto D 3.00 x 18 intially had the zapper q 100/90 in mind but it was scrapping the chain cover. hence went to moto d. so no more harsh ride the ride quality is butter smooth now.
I am using Motul 800 ester synthetic 2t oil from past 400kms. nothing much to say about it. its doing its job really well for the price what i have paid for !!
just got this.
Just need a feedback from you guyz, has anbody used the RD chenoys CDI kit on your bike. i need a feed back from you all. waht is the overall difference between the stock one and the chenoys cdi kit ?
@scary i have a doubt after cleaning the air filter foam how much ML of 2t oil should be added on the foam.
Old 11th June 2008, 17:28   #116
Shakensoul's Avatar
Thanked: 222 Times
How much did the NGK cost ?
Shakensoul is offline   Reply With Quote
Old 11th June 2008, 17:34   #117
invincible7's Avatar
Thanked: 154 Times
UPDATE:
I have the CDI with me, will be installing it in next couple of days, then i can comment. Overall i have heard good reviews about it, and its considered to be the best thing for a 2 stroker bike. I believe there are quiet a good numbers who have installed it and rave about it, so definately it should be a good product to say the least.
invincible7 is offline   Reply With Quote
Old 11th June 2008, 18:04   #118
srisha's Avatar
UPDATE:
just got this.
Prajeep,
Since you are from Bangalore, you may test ride my bike to see the difference, I have the RDD CDI kit along with the UNI air filter, and it does make a lot of difference.
Srisha
srisha is offline   Reply With Quote
Old 11th June 2008, 20:59   #119
praJEEP's Avatar
I got it for 530/-
Thanks invincible, please do share your reviews if possible with some pics looking forward for it very keenly.
Originally Posted by srisha View Post
Prajeep,
Srisha
Thanks shrisha, will do that you have a pm please reply back..
Old 11th June 2008, 21:06   #120
straight6's Avatar
Thanked: 118 Times
My K&N filter is giving me a lot of problems in the rain. It sucks in the overnight moisture when I start the bike and then I have to flush the carb before I ride it. But if I ride it in the rain continuously there is no problem. I'm going to install the stock filter assembly asap.
The Joy of Living a Dream - Honda Civic S MT (Pre-Owned) arvi86 Test-Drives & Initial Ownership Reports 292 13th July 2016 21:03
200 days of Living a Dream. My i20 Diesel Asta ! Kimified Test-Drives & Initial Ownership Reports 91 28th June 2012 11:02
Realization of a dream - Living with my VTEC avinash_m Test-Drives & Initial Ownership Reports 77 29th June 2010 14:56
The story of how I have lived with my dream for 8 years. The YAMAHA RX-135, 5 Speed. 4strings Motorbikes 5 11th April 2009 10:56
