Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 5th April 2008, 16:56   #1 (permalink)
praJEEP's Avatar
Default Problem with my CBZ's reflectors, Please help !!!
My CBZ's reflectors are covered with mist, i am facing this problem from quitw afwe months,i have no idea how to over come this problem, please help out guyz.
The first picture is with low beam and second one with hi beam.
praJEEP is offline   Reply With Quote
Old 5th April 2008, 17:01   #2 (permalink)
We cant make out with night pics.
Are you sure it mist ? Seems absurd. Might just be that the reflectors plastic is tainted. Get them removed and clean the in-and-out.
amitwiz1 is offline   Reply With Quote
Old 5th April 2008, 17:45   #3 (permalink)
praJEEP's Avatar
ok will post some day pics too, how to clean it ? i am sure it should not be cleaned with a cloth. there is something else..
Old 5th April 2008, 23:12   #4 (permalink)
zenopio's Avatar
yes we can clean it but i think its a risky job because you need to seperate the glass which will be sticked to the reflector ..and again stick it back.....
zenopio is offline   Reply With Quote
Old 6th April 2008, 00:12   #5 (permalink)
PatchyBoy's Avatar
If it is mist, obviously the seal between the Lens and the reflector is leaking and it is the water vapour in the air that leads to fogging. It is a labourious and delicate process to seperate and clean the inside and once again make it airtight.
Best option would be to replace the helamp assembly.
Cheers,
Rajan
__________________
Monsoon D R I V E!!! - When is the next One???
_________________________
FIAT PALIO 1.1 SLX Dec 2007
PatchyBoy is offline   Reply With Quote
Old 6th April 2008, 08:17   #6 (permalink)
or use the bike at night for some time. This heats up the interior of the light assy and helps decrease the mistyness
chvvkumar is offline   Reply With Quote
Old 6th April 2008, 12:35   #7 (permalink)
straight6's Avatar
That must be moisture. Drill a small hole at the back so that it escapes, but it will also get dusty more often. Installing HID's(though an expensive option)will also help because they run at a higher temperature which will make it evaporate quickly.
straight6 is offline   Reply With Quote
Old 11th April 2008, 17:37   #8 (permalink)
praJEEP's Avatar
Sorry for the late reply guyz.
yes it can be cleaned but how, should the reflectors be cleaned with plain cloth ? i am confused.
Cheers,
Rajan
Rajan, dont you think its an costly affair change the head lamp assembly for the sake of mist.
Kumar, my bike is running on philps 60/55w i hope the heat produced by that bulb is more enough to decrease the mistyness. but still the problem has not been solved.
where exactly you are pointing out to drill the hole, could you please point out in the picture above. i love hid's but the thing is i am highly satisfied with my 60/55w bulbs. is there any other way in sorting out this problem.
P.S: Sankar where are thou ???
Old 11th April 2008, 19:43   #9 (permalink)
straight6's Avatar
Drill the hole's at the back in the plastic part.
Old 11th April 2008, 20:09   #10 (permalink)
Nitin's Avatar
I remember seeing the same problem in my friend's CBZ,way back in 1999. A mechanic he knew helped him fix this problem. They actually pulled the whole unit apart,and then using 3M filling paste (if thats what its called),they made sure the gap b/w the glass & the rubber beading was filled up.
Apparently, this happens in some bike,due to the intense heat when parked in direct sunlight for extended periods of time. Didn't make much sense,since all these things are taken into account & fixed right at the assembly line.
Anyways,its worth giving a shot.
Nitin is offline   Reply With Quote
Old 15th April 2008, 10:41   #11 (permalink)
Sankar's Avatar
Pradeep, it's not mist, it's dust settled on to the reflector and glass. It has happened to my bikes too.
Buy a kilo of cotton waste (white grade) and make sure it's free of dirt and other contaminants. Take out the headlamp from the fairing, and remove the rear bulb. Through the headlamp bulb hole stuff in the cotton waste (make sure you keep the cotton waste clean and not on the ground before you do this). Once you have a fair amount of waste inside the headlight beam and use your fingers to move the waste inside the headlamp to wipe clean your lens and reflector.
It might seem a bit difficult but it works. And it will not screw the reflector or lens. I specifically asked to buy white grade because it's much softer compared to the multicolored cotton waste. White costs a bit more too.
__________________
"Auto racing, bull fighting, and mountain climbing are the only real sports... all others are games."
Ernest Hemingway
Old 15th April 2008, 10:46   #12 (permalink)
praJEEP's Avatar
Thanks sankar, which cotton are you exactly reffering to...
Old 15th April 2008, 11:09   #13 (permalink)
Sankar's Avatar
White cotton waste.. what painters use.
Mechs use the multicolored type.
__________________
Ernest Hemingway
Old 15th April 2008, 12:22   #14 (permalink)
straight6's Avatar
You will get it at any spare parts shop. That where I have bought it from a couple of times.
Thread Tools
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 81 10th February 2008 11:58
NHC - BullKit Problem :EDIT: now detected to strut problem ibcool Technical Stuff 13 9th September 2007 12:02
problem with ac zenopio Technical Stuff 4 5th April 2007 20:22
R1 problem..... vidurc Motorbikes 2 8th March 2006 17:02
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
