| Motorbikes Everything related to the two-wheeled breed. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Feb 2005 Location: Bangalore
| OK, so I've searched various places on the web, and I cant get any manual or non-technical guide to tuning the micarb for my roadking. My mechanic does it, but I cant understand which screw is which, which one is the main jet and where the jet needle is, etc.etc.. Can someone please help me out, maybe with a diagram pointing out which csrews will affect what, which way to tune for power and which way to tune for efficiency, what to do if the carb floods, etc... Any help would be appreciated. Cheers..
__________________ Skill is, sucessfully tightrope walking across the Niagra Falls. Intelligence is, having the sense not to do it. |
| | #2 (permalink) |
| BHPian | Mickarb is a copy of Mikuni, so the Mikuni manuals you find on the web will help you get a broad idea. The big screw that you can turn with your fingers is the idle screw, turning it clockwise will increase the idle rpm(it pushes the carb slide slightly upwards). Another small screw you find towards the rear of the carb(which can only be turned by a screwdriver or long fingernails) is the air screw. It adjusts the air fuel mixture at idle. Tighten it fully(do not use too much force) and then unscrew 1.5 turns. Should be enuff for a roadking. If you feel idling is not smooth enough, you can try turning this screw quarter turns this way or that way, until you find your sweet spot. Does not make much difference in actual riding. main jet and idle jet are inside the float bowl, better you don't mess with them. further tuning tips are byond the scope of this post. Just get this in your mind that playing with the screws alone is not going to matter much, with power or mileage. |
| | #3 (permalink) |
| BHPian | The actual process of finding the right idle rpm is as follows. Start the bike. warm it up to actual riding temperatures(10 minutes at good clip round the block). Come back, pick your screwdriver. Turn the big screw(idle screw) clockwise, you can see the rpms rise. Turn it enough so that the bike will not shut off when you close the air screw(this comes with experience, if you close the air screw and the bike is shutting off, then you need to turn the idle screw further in). With the bike idling away at a fairly high rpm(not screaming rpms, mind you), close the air screw(turn it fully shut by turning clockwise - if the bike shuts off, see above). Now start turning the airscrew slowly, listening to the bike. You can hear the revs gradually rise and will reach a crescendo and then taper off. Try to keep it at the crescendo(a tachometer helps to find the peak rpm, but then roadking does not come with one). Then, turn the idle screw(BIG ONE) anticlockwise, slowly, very slowly, until the idle rpms come down and reach a point where the bike dies. If you want the bike to idle, you have to turn it a quarter clockwise, else leave it as it is. Some people prefer the bike not to idle. You can now turn the air screw a quarter of a turn clockwise(for better idling when cold) or leave it as it is. or even turn it a quarter anti clockwise, hoping for better mileage. You may have to adjust the idle screw in the morning, if you want idling after an early morning start. |
| | #5 (permalink) |
| Senior - BHPian Join Date: Jul 2007 Location: Delhi
| contact praveen.sathaye on gmail - he runs a pune yezdi club, owns two of them beasts. he's your man!
__________________ My dream: An india where even a CD100 runs HID to teach insensitive full-HID dudes that HIDs are a zero sum game. |
| | #6 (permalink) |
| BHPian | good explaination kuttapan. I have a Mikuni carb on my bike(Kinetic GF170). I am facing a problem lately. I get a big jerk (as if fuel supply is stopped for a second) while revving hard. This happens while riding as well as if bike is in neutral. While riding this happens if I rev hard in lower gears or if I apply full accelerator when in top gear or while climbing . How can I solve this problem?
__________________ If everything seems under control, you are not going fast enough! |
| | #7 (permalink) |
| BHPian | I am not really sure if the carb is at fault here. Have you cleaned your carb already, if not get it thoroughly cleaned...All the jets etc using pressurized air. If the jerk is not momentary - i.e bike loses power and you have to roll of throttle for a few second before it will accelerate again, check float height and the fuel tap for flow. Get ur electricals checked as well. Spark plug(clean and adjust gap), HT wire etc. Maybe the more knowledgeable fellas can help better. Last edited by kuttapan : 25th April 2008 at 15:04. |
| | #8 (permalink) | |
| BHPian | Quote:
the jerk is not momentary, I have to reduce rpm either by changing to higher gear or by slowing before I get some power back. I am planning to get fuel tank cleaned this weekend, lets see if anything changes after that.
__________________ If everything seems under control, you are not going fast enough! | |
| | #9 (permalink) | |
| BHPian | Quote:
__________________ Miata Turbo Is GO!! | |
| | #11 (permalink) |
| BHPian | Thanks ananth and kuttapan. Its a CV carb. I did get it cleaned but didn't ask specifically to check for diaphragm damage. Will get it checked again this weekend and update.
| | #12 (permalink) |
| Thanks Kuttapan, phamilyguy... update is as follows; I followed your idle adjustment technique, and it worked really good - the bike stopped giving the jerks and splutters it used to earlier when cold starting. A short time later, however, the bike would not start using the kick-starter - I had to push it to start, which, aside from being a little embarrassing in front of all the neighbours on a monday morning, was getting quite tiring. So I went and got the whole thingamalajig checked up at Abdul Razzaks garage, and now the bike runs really smoothly. Thanks for all the input though! Cheers! ~
| | #13 (permalink) | |
| BHPian Join Date: Nov 2007 Location: Hyderabad
| Quote:
I like the bike not to idle, we call it Dead Beat. It has some other advantages too, the bike cant be started nor can it be driven around by anyone not used to the dead beat, I believe in One man machine, i.e. no borrowing or lending. A similar problem my activa was giving me since the 1st servicing, getting the carb bowl cleaned solved the problem.
__________________ FIAT! 65'JAWA|95'Rking|56' FIAT 1100|59' FIAT 1100(No longer have this, my fav)| '97 118NE(FIAT 124+NISSAN engine)|07' Ikon. Last edited by gendarmee : 11th May 2008 at 02:03. Reason: adding 2nd quote | |
| | #14 (permalink) |
| BHPian | [quote=aveek;822973]Thanks Kuttapan, phamilyguy... update is as follows; I followed your idle adjustment technique, and it worked really good - the bike stopped giving the jerks and splutters it used to earlier when cold starting. A short time later, however, the bike would not start using the kick-starter - I had to push it to start, which, aside from being a little embarrassing in front of all the neighbours on a monday morning, was getting quite tiring. quote] That's coz you are a novice, and could not figure out the ideal setting for a cold start. The mechs have been doing it for donkey's years, they know what setting will work. You should not have given up, as I said in my earlier post, cold starting requires minor tweaking of the ideal setting. |
« Ducati -OFFICALLY lauched in INDIA - 15 to 50 lakhs :O
Bullet 350 - Roll on acceleration in 2nd gear. Video! »
| Thread Tools | |
Similar Threads | ||||
| Bought : Yezdi Roadking 1994 | ad75 | Motorbikes | 68 | 24th April 2008 23:09 |
| My Roadking has arrived, but badly | aveek | Motorbikes | 62 | 8th February 2008 20:31 |
| Yezdi Roadking/Suzuki Shogan | sunilchakola | Shifting gears | 1 | 22nd November 2007 22:51 |
| got a Yezdi | salil_kulkarni | Motorbikes | 7 | 11th July 2006 16:52 |
| The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box | turboindia | Modifications & Accessories | 108 | 17th April 2006 12:33 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
