Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 30th April 2008, 14:08   #1 (permalink)
svsantosh's Avatar
Default Riding with a Cut Accelerator Cable?
Guys, Have you experienced any cable cut situation in your bike. Recently I managed to get my throttle cable cut on my Bullet and to Ride 40Kms with the cable being pulled by my bare hands. Painful thing to do..!!
Any one managed to live through such a experience, share how you over came it.
I once rode a samurai back home without any back brakes. Had to disconnect them manually since they were in the danger of cracking up the hub, So rode only with the uselss Front Hub brakes.
God forbid anyone manages to cut his Clutch wire. There is nothing one can do, they are impossible to pull even on a 100CC bike, let alone a enfield or even a car..!!
__________________
Dont wear Helmets & Seatbelts to reach Heaven Faster
You hardly have any time left in this world to be a sinner
svsantosh is offline   Reply With Quote
Old 30th April 2008, 15:12   #2 (permalink)
gendarmee's Avatar
I've done it once in despration to get to the mechanic. made a loop of the throttle cable(inner+outer) that i could hold in the fist, and the pulled that from under the tank on the jawa. was tough coz the bike is set to a what i call, a dead beat. the konks off if one doesnt hold the throttle. Once in motion it wasnt a problem,not a lot in distance, 3 kilometers.
Clutch wire breaking on the jawa isn't much of a problem though, its got an auto clutch, can change the gear w/o the clutch at the right speed, can push it and engage the gear. but braking becomes a problem, the 2nd neutral comes in handy then. But it takes a good amount of learning.
Once the accelerator cable on on the 118ne broke, 12 in the night. no mechie available at that time of the day...the button had broken off the wire, so the connection to the carb broke. was impossible to get a new wire too, I didn't want to leave the car and go, all i wanted to do was find a way to make the wire work, aleast to a relatives place.
I opened the boot and check out the nuts & bolts, one bolt didn't have grooves on the neck and nut fit it well loosely onto it, after tightening the bolt to the neck such that it got free at the neck, there was enough space to slip the wire in through the nut-bolt.
I fit the bolt where the cable's head fit on the carb, slipped the cable in and fixed the bolt onto the grooves, the wire got stuck b/w the grooves of the bolt and the nut.
a little adjusting of the cable made the idling motor able, was advanced otherwise.I used it for a week like that before getting the cable replaced.
__________________
FIAT! 65'JAWA|95'Rking|56' FIAT 1100|59' FIAT 1100(No longer have this, my fav)|
'97 118NE(FIAT 124+NISSAN engine)|07' Ikon.
gendarmee is offline   Reply With Quote
Old 30th April 2008, 15:18   #3 (permalink)
bblost's Avatar
Make a loop with the cable.
Insert a pen or stick or spanner thru it.
Makes it easy to ride and handle.
I have ridden bikes with
1. cut accelerator cables.
2. jammed acc cable, using ignition off for control.
3. cut clutch cable.
4. zero preasure in front disc.
5. torn air filter hose.
I once towed a bike some 75 kms using my foot on the disabled bike' footrest.
Keep Thumping.
__________________
Be your own Hero.
RE TBird 2003, no speedo, no range limits.
Wagon R, 2004.
Old 30th April 2008, 15:55   #4 (permalink)
desmoquattro's Avatar
riding with a cut-clutch cable is relatively easy.
Did it 2 weeks back. You can ride the way you ride normally.
Probably because i'm accustomed to clutch-less shifts.
__________________
180 DTSi V1 | Palio 1.2 ELX
desmoquattro is offline   Reply With Quote
Old 30th April 2008, 16:08   #5 (permalink)
Location: Chennai (formerly Madras, even more formerly Chenna Patnam)
...God forbid anyone manages to cut his Clutch wire. There is nothing one can do, ...
I once had to drive our Bajaj Cub scooter (more than 10 years ago), with a cut clutch cable. I would start it, push it little using my legs, and after it gained a little momentum, engage the first gear : it would jump forward, and continue moving . Once it started moving , I could change gears normally (there would be a jerking movement , of course). Whenever I had to stop at a signal, I had to quickly bring it to neutral : it was quite some fun.
Blue Thunder is offline   Reply With Quote
Old 30th April 2008, 16:23   #6 (permalink)
prabhuav's Avatar
My bullet used to lose its clutch cable fairly regularly. Remedy: Pull the cable out of the sleeve. tie it around the left side of the crash guard. Use your feet to push the clutch like a car - you are in business
__________________
Empty slot in garage full - elantra crdi it is :)
prabhuav is offline   Reply With Quote
Old 30th April 2008, 16:28   #7 (permalink)
svsantosh's Avatar
One of the best ideas I have heard. I will surely remember you the day I meet this dreaded situation.
__________________
Old 30th April 2008, 18:17   #8 (permalink)
bblost's Avatar
Fantastic.
almost tempted to get someone else to snap off thier clutch cable so I can try this out.
__________________
Be your own Hero.
Wagon R, 2004.
Old 30th April 2008, 18:55   #9 (permalink)
vabs78's Avatar
Better solution. Maintain your bikes properly.
__________________
If everything seems under control, you are not going fast enough!
vabs78 is offline   Reply With Quote
Old 1st May 2008, 08:00   #10 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Some really great ideas in this thread!
The only question i have is - who took the picture??
cya
R
__________________
The memory of you will ride by our side forever.
Old 1st May 2008, 08:05   #11 (permalink)
clevermax's Avatar
Riding a bike with a cut acclerator cable... Hmm... How about driving a bus like that?
One I have seen this KSRTC (Kerala State RTC) driver driving the bus like this. He tied a plastic rope onto the cable from where it got cut, held the other end in his hand and managed to drive.
And yes, one car ride a Bajaj Chetak even if there's no clutch cable. Only difficult thing is to get the scooter moving from standstill. Afterwards, you don't need the clutch at all!
__________________
Bangalore - The city with no power
clevermax is offline   Reply With Quote
Old 1st May 2008, 19:45   #12 (permalink)
highwayblaze's Avatar
I've done this on my 1976 yezdi once. I had a friend of mine sit on the front seat and reach the naked accel cable near the carb below the gas tank and pull. while i behind and some how managed to reach the handle bars to control the bike. we rode it 2 kms to my house !
__________________
Chill Pill
Blaze
highwayblaze is offline   Reply With Quote
Old 1st May 2008, 21:36   #13 (permalink)
srijit's Avatar
Cool. Kinda like a suicide clutch
srijit is offline   Reply With Quote
Old 1st May 2008, 23:04   #14 (permalink)
Nitin's Avatar
cya
R
You beat me to it,Rehaan. I was going to ask Santosh how he managed to take a pic of the whole situation. A pillion rider on such a bike?
Nitin is offline   Reply With Quote
Old 2nd May 2008, 01:07   #15 (permalink)
airfoil's Avatar
Ahh, this brings up memories...
A snapped throttle wire on my RX100 when I was 150 km from home resulted in my rigging up the wire to my front brake lever, with the help of those cable lock nut thingies found on the likes of the TVS50. Worked like a charm!
airfoil is online now   Reply With Quote
Thread Tools
A new style of riding. amit Shifting gears 21 24th June 2008 17:20
Vibration of Accelerator and Steering PatienceWins Technical Stuff 6 15th April 2008 10:19
Santro: Return spring for Accelerator and brake pedal? ajith Modifications & Accessories 18 2nd April 2008 20:20
Vibration on accelerator pedal while using the horn kaushik_s Technical Stuff 2 8th September 2007 13:59
Single gear riding iamkapilb Street Experiences 5 31st August 2006 12:04
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
