Old 30th May 2008, 18:14   #16
Thanked: 3,508 Times
Originally Posted by Sandeep_K_Ram View Post
What you will NOT find in any spares store is a original 5speed head and carburetor . Having said that , the 4sp carb on a 5sp setup does ok-ish .
Originally Posted by silver_shadow View Post
you can also get larger carb jets if i'm not mistaken... so that problem should be tackled.
The larger jets won't equal the 5 speed carb. The 5 speed carb has an oval venturi and the 4 speed has the normal round venturi.
4 speed carb will work better in some cases as i have observed. But on a stock 5 speed engine it's better to have the 5 speed carb.
For the 4 speed head to work on a 5 speed barrel get it milled and re profiled. 4 speed head on a 5 speed barrel will give very poor compression ratio and thus poor performance.
Old 30th May 2008, 18:15   #17
ScarySkulls's Avatar
Thanked: 19 Times
Originally Posted by rascalangel View Post
dear scaryskulls what is the difference between barrel and skull?any mods required for gearbox change?
Barrel:-
Barrel also means the cylinder head. i.e. within which the piston means.
Cylinder (engine) - Wikipedia, the free encyclopedia
Skull:- Skull - Wikipedia, the free encyclopedia
Not sure how this helps in RXG topic though.
ScarySkulls is offline   Reply With Quote
Old 30th May 2008, 19:28   #18
Thanked: 35 Times
oops i meant head and barrel.sorry!
rascalangel is offline   Reply With Quote
Old 30th May 2008, 19:30   #19
that's for you bro
anyway, at the OP: do keep us updated on what you do finally including the mods if any (with pics will be sweet )
silver_shadow is offline   Reply With Quote
Old 1st June 2008, 12:30   #20
Thanked: 35 Times
yeah sure.hope i find a bike soon.
Old 2nd June 2008, 13:15   #21
Thanked: 7 Times
ACtually the RXG and 4sp carb is a 4TL4 00 which has a #165 main jets. And the actualy RX135 5 sp carb is 4TL4 20 with a #135 main jet. So bigger jets are not the issue . The 5sp carb has a oval bore compared to round ones fro the 4speeds.
Its a pain to get original parts for the 5sp and ofc ...many ppl have got a 5th cog mod .
Sandeep_K_Ram is offline   Reply With Quote
Restoration - 1997 Yamaha RXG Mr.Boss Motorbikes 71 20th April 2017 09:56
Workshop for Rebuilding My Yamaha RXG (135) aadil23 Motorbikes 1 30th April 2013 13:53
My Yamaha RXG 135 - Facelift & Performance modifications zacs Motorbikes 30 18th November 2011 17:17
my yamaha rxg 135 vickedv4 Motorbikes 9 30th April 2007 13:35
Yamaha RXG ravi_28_8 Motorbikes 2 19th August 2004 15:26
