Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 29th May 2008, 11:07   #1 (permalink)
Unhappy Pulsar 150 Wobbling!
Hi all,
i own a pulsar 150 DTSi DEC 2004 model. When ever i ride it around 60-65 kmph and leave my both hands the front goes into ever increasing wobbling.
the following has already been tried:
1) the cone is replaced with new one.
2) thee bend in fork(if there was ever) was removed.
3) the tire tube checked for any packings.
4) shock abs oil changed and levels corrected.
5) the rim removed and any bend straightened out after which there was improvement for 3 days only.
can you guys please throw some light on as to why this is happening and suggest a possible solution? has any one of you experienced this kind of wobbling?
Please help as i want to get rid of this problem for once and for all. its my first bike and i love it a lot.
rascalangel is offline   Reply With Quote
Old 30th May 2008, 00:29   #2 (permalink)
aaggoswami's Avatar
First of all, never ever take your hand off.
1) Does the steering wobble when you have your hands on it ?
2) Is there any problem regarding the handling under normal riding ( with hands on steering wheel ) ?
I have experience in Caliber ( original with 7.7bhp and round headlamp ) and still experiencing it with Zeus. I did testing on lonely road in Hostel Area and just for a couple of seconds. The normal handling in my Zeus is not affected and the bike handles brilliantly.
__________________
Never Dream because broken dreams hurt the most.There is no market for emotions.
EVENTUALLY FATE DECIDES EVERYTHING.
aaggoswami is offline   Reply With Quote
Old 30th May 2008, 00:45   #3 (permalink)
CorsaLove's Avatar
From the looks of it, it could be the wheel bearings which is causing the problem. I'm no expert, but just check:
If there is a spoke loose in the wheel, which could be the problem, or if there is uneven tyre wear. Also, it could be the wheel bearings, one bearing on my shogun had ruptured and i was facing the same problem.
__________________
Gautam
''The ordinary man looking at a mountain is like an illiterate person confronted with a Greek manuscript.”- Al Crowley
CorsaLove is offline   Reply With Quote
Old 30th May 2008, 01:05   #4 (permalink)
aaggoswami's Avatar
Considering that the thread starter has already got his job done in the rims department, the problem of spoke tightening could not be a cause.
If spokes came lose, then the person will experience unstable handling even with the hands on the steering.
__________________
Old 30th May 2008, 01:05   #5 (permalink)
Sankar's Avatar
Originally Posted by rascalangel View Post
Hi all,
These are a few things you could check to narrow down on the problem.
1) Has the rim gone out of true after three days?
2) Is the front steering head set too tight after you have got the cone & ball set replaced?
3) Are the front and the back wheels straight in a line? Is any one wheel offset to the left or the right?
4) Are the rear chain tensioners adjusted equally at the left and the right side?
5) Has the wheel been trued perfectly with the correct offset or no offset? (At times it happens that the rim is true but the rim would be offest to either the left or the right. For most front wheels there shouldn't be any offset and it should be aligned centrally. But in the case of rear wheels there are some bikes which has a specific offset which needs to be maintained while setting the wheel. If your wheel smith is experienced he would know it.)
6) Are the wheel bearings good?
7) Is there any brake binding issue?
8) Hope the chassis and the swingarm is perfect.
9) Is the air pressure correct?
10) Hope the lower fork holder (triple tree) doesnt have any bend.
Old 30th May 2008, 12:18   #6 (permalink)
okay first i forgot to mention that i have alloy rims.
i will be taking the bike again tomorrow to the guy who removed it.
no its not, infact i feel its too smooth compared to my cousins CBZ.
got to check these.
can u elaborate?its something i havent heard before.
the previous mech supposedly removed the bend, but will get it checked this time.
Dear sankar,
thanks a lot. i've been looking for these kind of points to chack upon.
Old 30th May 2008, 15:19   #7 (permalink)
Sankar's Avatar
You're welcome rascalangel, i scribbled down all the possibilities that came to my mind.
Since you've got ally wheels you need to worry about offset. But still check the trueness of the wheels.
Brake binding means the front brake still sticking on to the disk in such a way that it causes the front wheels not to rotate freely.
Old 30th May 2008, 15:33   #8 (permalink)
As a matter of fact my front disk brake does not allow wheel to move freely.Also it doesn't apply properly and i get a jerky feeling when i apply them.my brake disk was once machined cause of this but still its the same.
what causes this? is this why the wheel wobbles or vice versa?
Old 30th May 2008, 15:41   #9 (permalink)
DirtyDan's Avatar
Default Silly question maybe
You are riding with no hands on the bar? Wobble is not your main problem here but:
Are you also changing your seating position when you do this, especially, are you moving back on the seat toward the rear? This will tend to lighten the load on the front wheel and perhaps cause it to wobble. Or, are you sitting up more straight and therefore putting more weight on the rear and off the front?
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
Old 30th May 2008, 15:47   #10 (permalink)
bblost's Avatar
If you are willing to try then remove the disc assembly.
Let the plate remain.
try your stunt and see if the wobble persists.
needless to say Be very careful.
riding without hands - Fun
riding without brakes- Lots of fun.
riding without hands and brakes- Lots of amazing fun.
If you fall and break something, it will hurt.
It will hurt bad for a real long time.
Wear protective gear all the time.
__________________
Ever catch yourself listening to a nice song on the radio and dedicating it to your car.
bblost is online now   Reply With Quote
Old 30th May 2008, 16:30   #11 (permalink)
i will try that too. btw lot of guys talk about me riding with my hand off the bar well i do it just to see if it wobbles not otherwise. the main problem is that even when i ride with hands on the bar and say a pass of a edge in the road it feels as if its turning on its own, it kind of shakes. this is the concern cause i feel i dont have complete control of my bike!and in rains when it gets slippery god save me
Old 31st May 2008, 20:54   #12 (permalink)
yogesh sarkar's Avatar
Check for uneven tyre wear
yogesh sarkar is offline   Reply With Quote
Old 1st June 2008, 13:55   #13 (permalink)
bblost:
The problem persisted.
after that took the bike to the guy who trued my wheel earlier. when went to receive it he said the leg of the triple tree which fits into the chassis had bent and also the part of the chassis which holds it.he said its been cleared now and he also replaced the ball bearings so took a test and found it had improved a bit but i still get that feeling of it moving in my hands. one good thing happened is that it seemed to get of the brake binding problem..at least now the front wheel is 95% free. as for the little wobble which still exists the guy said its because of the tire wearing. will most probably get the tire replaced tomorrow. should i go for MRF or Ceat?
Old 6th June 2008, 16:50   #14 (permalink)
Hi all,
it seems my rear tire is not aligned properly. will get it done. as of now the problem exists to little extent.Also i want to change both my rear and front tire's.the rear one is already smooth after 4 yrs, the front one is ok but changing both. any suggestions for good grippy tires?for rains especially.
Thanks a lot in advance.
Old 6th June 2008, 17:07   #15 (permalink)
bblost's Avatar
Mrf or Ceat.
What I know and I may be wrong is that the rubber in ceat is a litle softer.
This translates to better grip but the tire wears out faster.
personally I suggest you go with whatever is available.
Note: The tire will have a code indicating the week and year of manufacture.
Buy the youngest tire. This code is a three digit number. 1 digit for year and 2 for the week of manufacture.
More info on tires codes: Tire code - Wikipedia, the free encyclopedia
__________________
Thread Tools
Pulsar 150 for SALE Elito11 Shifting gears 0 16th September 2007 20:47
Jetting For My Pulsar 150 nikibusa Motorbikes 18 22nd March 2006 03:00
pulsar 150 classic for sale manaa45 Shifting gears 0 16th March 2006 17:37
My Pulsar 150 vs Merc E220 nikibusa Street Experiences 24 10th June 2005 12:06
Pulsar 150 DTSi or Unicorn?????? 1000bhp Motorbikes 5 28th February 2005 21:21
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
