Old 17th June 2008, 09:27   #1
satansvalet's Avatar
Unhappy DIO refusing to start
As the monsoons has arrived so has the problem in my scooter.
Since the last 4-5 days i ve been trying to start my scooter (self/kick)
it turns on for a few seconds and then coughs up and turns off.
I ve even tried using the choke ,but that has no effect whatsoever.
I got it serviced a month and a half ago (including de-carbonisation and engine flushing).
I ve got my ride for a little over 3 years and done around 8.5k Kms. on it, but ve never faced such a problem.
Also,when I took it out for a ride it turns off immediately as soon as I let the accelerator go.To avoid that I had to use the rear brake and little throttle simultaneously at signals or at nakas.
Please help.Thanks.
satansvalet is offline   Reply With Quote
Old 17th June 2008, 10:21   #2
bblost's Avatar
Thanked: 6,662 Times
check if the hose from the air filter is connected to the carb correctly.
Old 17th June 2008, 10:26   #3
Thanked: 515 Times
Better show it to service advisor, could be related to fuel lines/carb.
Fine as a workaround, but not good in long run. Better adjust idling.
sukiwa is offline   Reply With Quote
Old 17th June 2008, 16:43   #4
Default thanks
tnaks a lot for the advice,you all !
will get it to the service centre asap.
Old 19th June 2008, 18:49   #5
aaggoswami's Avatar
Thanked: 1,426 Times
Clear Air filter, overhaul the carb and things should be fine.
Also after three years, although short of official spark plug change interval, changing sparkplug will be a good thing to do.
aaggoswami is offline   Reply With Quote
Old 19th June 2008, 18:55   #6
invincible7's Avatar
Thanked: 131 Times
I suggest check your spark plug...might be gone.. replace or clean it properly.
invincible7 is offline   Reply With Quote
Old 19th July 2008, 11:58   #7
Default DIO fixed.
I got my DIO fixed.spark plug was changed and fuel lines were
also checked.the oil gasket was damaged so it was changed.
It cost me 100/- for the gasket but they charged me 350/- labour
charge for replacing it.Does it really cost so much.
Old 19th July 2008, 20:15   #8
anjan_c2007's Avatar
Thanked: 4,699 Times
Yes Honda dealers often put up four figure repair bills for scooters. A friend had to cough up Rs 2100/- to get his 4 year old Dio in usable condition after some rough and tough times the machine had faced.
anjan_c2007 is online now   Reply With Quote
Car Refusing to Start.. cotterpin Technical Stuff 4 14th July 2014 17:17
Manza Quadrajet - Car refusing to start. sajanjohn Technical Stuff 27 24th April 2012 14:40
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
RE Standard 350: refusing to start EDIT: Resolved. rajeshshenoi Motorbikes 5 12th February 2010 11:27
