Old 21st February 2006, 13:35   #16
Try n get your hands on Oil based Uni filters. They are the best, cost abt 1000 bucks, better portection than stock filter, and freer flowing than K&N. K&N is useless on our bikes.
powerslave12r is offline   Reply With Quote
Old 21st February 2006, 20:34   #17
revtech's Avatar
Thanked: 35 Times
why do you say K&N are useless or indian bikes ?? in what way are the oil based filters better ?? whats the difference between the two.once i fit the oil based filter what change will i be seeing (similar to a K&N ) what about difference in sound ??
Rev
revtech is offline   Reply With Quote
Old 21st February 2006, 21:44   #18
K&N are inferior to UNIs cos UNIs are far more freer flowin, as I said before, and they are far more efficient in trapping dust. Check out RDDreams.com for more info.
Old 22nd March 2006, 03:00   #19
Question
Hey Powerslave12r,
How much do these UNI's Cost, And what all needs to be done to the bike???
I have heard about these UNI filters, My Mechanic was cribbing as soon he came to know that i bought a K&N, he also recommends UNI. Where can i get in bangalore?
adarshbr is offline   Reply With Quote
Old 7th March 2012, 10:47   #20
Default Re: Jetting For My Pulsar 150
Hi , I own a Pulsar 150 DTSi UGI model from 2004 , I have changed the original carb with a carb model(which has choke lever inbuilt on carb) which was a refurbished part right out of a sold P150 model . As the factory original one lasted for 6yrs without much glitches except the A/F screw not moving . The present part is fine but some times it gives black fumes on revving very high . I have visited the local mechanic , he washed the carb and adjusted , but the black fumes are problem to see like a Turbo whoosh from turbo diesel engine .
I have an query that can we increase / swap the carb with new 180 cc's carb ,
will there be any effect in combustion ,
any drop in average (I get 40-45kmpl)
will the bike run smoother , economical ?
frienduday is offline   Reply With Quote
K&N and carb re-jetting for bullet 500 & 350. EDIT: Chart on pg 2 jingaboysr Motorbikes 34 4th October 2010 14:04
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
RD350: Trouble after up-jetting dustDevil Motorbikes 15 14th November 2007 11:43
what is jetting devsus Motorbikes 8 17th April 2006 22:51
