Old 20th June 2008, 17:11   #1
Default Question Regarding Horn On Kinetic Blaze
Guys....i need your help actually i hate blaze's horn and i wanna change it with something loud .....can i put a skoda octavias horn ...is my battery able to bear this load...
sunsand2000 is offline   Reply With Quote
Old 20th June 2008, 17:30   #2
straight6's Avatar
Thanked: 112 Times
Yes, just make sure you install a relay(cut out).
straight6 is offline   Reply With Quote
Old 20th June 2008, 17:39   #3
ok any idea how much will the octavias horn cost and whts this relay sorry i dont have any idea on this
Old 20th June 2008, 17:46   #4
thanks buddy but whts a relay
Old 20th June 2008, 19:19   #5
sansand2000, you can get yourself a Roots horn at any automotive accessory shop which should run on your bike. I had two big ones on my bullet and everybody used to move out the way thinking an ambassador was behind them ;-)! Well it wasn't that harsh but was loud and clear.
Sparkie is offline   Reply With Quote
Old 20th June 2008, 19:25   #6
straight6's Avatar
Thanked: 112 Times
If you don't install a relay the battery will get drained fast. Just go to a spare parts shop and ask for a "horn cut-out". They will know what you want. Your mechanic will be able to install it.
Old 21st June 2008, 01:07   #7
thanks sparkie but can u tell me how much will this horn cost
and thanks straight ill ask my mechanic
Old 21st June 2008, 03:00   #8
ravi@64bhp's Avatar
You need two-horn combination to get good amount of voice. The big dome at the front suppresses the tone 'significantly'. Moreover, removing the dome and fitting is a PAINFUL job. U have to unscrew at least 14 screws.
Most probably, as I remember, fitting skoda horns or root horns is highly impossible due to very less space inside the dome.
One mechanic in Koti, with very difficulty fitted two normal horns with relay. The cut-out generally costs around 50 bucks. Horns around 300-600 bucks depending on the type.
ravi@64bhp is offline   Reply With Quote
Old 21st June 2008, 15:02   #9
thanks ravi actually i dont want that front fiber ie. dome to be removed and refitted bcoz company fitting is the best and i dont want that dome in future to wobble at high speeds ....isnt ther any other place to fit skoda horn
kinetic's new blaze test-ridden heelntoe Test-Drives & Initial Ownership Reports 13 7th April 2015 13:18
Want to modify my Kinetic Blaze samloveu123 Motorbikes 14 27th April 2014 16:08
Pre-Owned Kinetic Blaze??? D.V.R Motorbikes 2 25th April 2013 18:39
Kinetic Blaze; 165cc, 11.6bhp scooter jkdas Motorbikes 20 30th April 2006 10:53
hot new kinetic blaze sunilbakshi Motorbikes 4 18th March 2006 12:14
