Old 31st January 2010, 20:19   #76
rrahul_2778's Avatar
Guys, what happens when you put a 20W40 engine oil in the bike (electra 5s)? When my bike was runnign low (almost dry coz of my 700 kms long trip) on oil, my mech didnt have 20W50 and he put 20W40 and said nothing will happen. I was not sure if letting my bike run dry would do any damage so I allowed him to put the 40 oil. Pls help folks!!!
rrahul_2778 is offline   Reply With Quote
Old 31st January 2010, 22:41   #77
masterblader's Avatar
To get out of jail you had no option but to settle for the 20/40 viscosity.
Replenish ASAP with the recommended 20/50 which is slightly thicker oil to sustain higher temperatures. Thereafter monitor the oil consumption to ensure no permanent damage has been done. Here in the UK while being snowed under we run on 10/30 and in the summer a 10/40
masterblader is offline   Reply With Quote
Old 1st February 2010, 13:29   #78
GreaseMonk's Avatar
Thanked: 87 Times
All my gear box grease has leaked out overnight while parked in the garage. On inspection it seems that one of the screws had vibrated itself off!
Now to get it to my mechanic about 10 km away, what are the options i have?
I cant make the grease + oil combo my mechanic normally puts.
Should I stick with SAE 90 or would I be able to get away with some spare 20w50 i have lying around just for the trip to the mechanic?
Also, how do I check the gearbox oil level during filling?? The Snidal manual wasn't very helpful on this.
GreaseMonk is offline   Reply With Quote
Old 1st February 2010, 15:14   #79
ac 427's Avatar
Thanked: 114 Times
20 x 50 is what i use for my bull.
cheers,
ac
ac 427 is offline   Reply With Quote
Old 1st February 2010, 17:06   #80
GreaseMonk's Avatar
Thanked: 87 Times
cheers,
ac
In your gearbox!? Are you sure? I would think that it's far too thin for extended usage, as SAE90 is recommended. Also, many tend to use a mixture of 20W50 and grease as an alternative to avoid leaks.
What my question was is it alright to use 20w50 straight up in the gearbox for a 10km trip to my mechanics place?
Old 2nd February 2010, 11:41   #81
ac 427's Avatar
Thanked: 114 Times
my bad, in my gearbox i use a mixture of grease and 20 x 50 oil.
and yes its okay to use it for a short distance, but ensure you get your gearbox greased, as the last thing you want is a notchy gearbox.
cheers,
ac
Old 2nd February 2010, 19:06   #82
Does this cause any permanent damage too????? . Had I known I would have never allowed the mech to add a 20/40 oil.
Old 2nd February 2010, 19:16   #83
Rennjit's Avatar
Thanked: 84 Times
.. What my question was is it alright to use 20w50 straight up in the gearbox for a 10km trip to my mechanics place?
yes. be gentle with speeds & shifts if incase you feel a rough box as its used to grease-oil emulsion.
Rennjit is offline   Reply With Quote
Old 2nd February 2010, 19:42   #84
Born 2 Be Wild's Avatar
Thanked: 175 Times
Relax Bro it wont cause any damage. Infact During my Initial days as a Bullet owner i was also skeptical about what oil would be best for My bike but after 5 years and umpteen Oil Changes i have finally found Something that the bike likes and its cheap too, have used it since the last 2 changes and the result so far is good. Its called lal Ghoda i know, i Know some people will fall over Laughing but believe u me its the thickest Oil i have come across so far and Its damm cheap too At 120rs a Litre.
Born 2 Be Wild is offline   Reply With Quote
Old 2nd February 2010, 20:00   #85
Running low on oil after a 700kms is not a good sign so somewhere along your journey the engine was either consuming or dumping it. Stick with the recommended viscosity to ensure all is back to normal and to have peace of mind have the oil pressure checked out.
Old 2nd February 2010, 20:01   #86
GreaseMonk's Avatar
Thanked: 87 Times
Thanks Rennjit.
ROTFLOL@ Lal Goda
Old 2nd February 2010, 20:30   #87
Hi Grease Monkey mixing engine oil 20/50 and grease is not a good practise.
Engine oil contains cleaning agents to manage the build up of carbon and sludge in the sump/oiltank. Gearbox oil like SAE 80/90 has gumming agents got from the Guar Gum plant used in cooking (known to us as Asofoetida or Ing) to deal with a different level of loading. Mixing in grease will not cure your leak a good
even mating surfaces and a good dollop of silicone gasket sealant will do the trick.
Old 2nd February 2010, 23:30   #88
Rennjit's Avatar
Thanked: 84 Times
Lal Ghoda, ain't that for diesels ?
Old 3rd February 2010, 14:26   #89
Thanked: 175 Times
Yes it is a diesel engine oil.
Old 3rd February 2010, 21:17   #90
I guess maybe I am just paranoid. I am trying to come to terms to understand this bike and am no where close to doing that
The story of another Green Bullet in my life - My Enfield Bullet 500 arjithin Motorbikes 35 20th February 2016 20:26
Need opinions on Shell Helix 20W - 50 Oil for the Royal Enfield Bullet Electra 4S ron_9191 Motorbikes 14 3rd November 2013 15:01
"irish" royal enfield 350 bullet ozy Post-War 23 29th June 2010 14:31
For Sale:Royal Enfield Bullet Machismo binz Shifting gears 0 24th September 2006 12:54
