Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 4th July 2008, 03:24   #1 (permalink)
BIKeINSTEIN's Avatar
Question Need specs of Pulsar alloy wheels.
If anyone has correct information on the specs/sizes of the 17" alloy wheels on the new Pulsars, then please post them here.
I couldn't find the same for a P200 in the owner's manual.
Want info on P150, P180, P200 and P220.
A friend mentioned the P180 and P200's alloy wheels are of a better make than the ones on the P150. (maybe wider too)
(His wheels got damaged in a freak accident but thankfully he is absolutely fine.)
He will be getting new wheels for his P150 soon and would love to get better ones instead.
So are the P200's wheels (especially rear) a direct fit on the P150?
Anyone who has done similar stuff or has any related information, please post your valuable comments and oblige.
__________________
Live to RiDE, RiDe to live!!
Thirst for Thrust > Need for Speed. :P
RiDe fast, RiDe safe. :)
BIKeINSTEIN is offline   Reply With Quote
Old 4th July 2008, 07:10   #2 (permalink)
arpandiv's Avatar
Yes P200 wheel is wider.
You can fit it on the P150.
arpandiv is offline   Reply With Quote
Old 4th July 2008, 15:19   #3 (permalink)
invincible7's Avatar
Guys could you please share the prices for the same.
invincible7 is offline   Reply With Quote
Old 4th July 2008, 15:23   #4 (permalink)
rider60's Avatar
well the P200 has the alloys of better make than the p150/p180 and when it comes to size its definitely bigger, i dont have the tech specs but then they do put in 120mm side tyre on it right? so its bigger.
you can surely fit the rear alloy of p200 on the p150/p180 many here have done that its kind of direct fit.
rider60 is offline   Reply With Quote
Old 4th July 2008, 17:07   #5 (permalink)
Thank you arpandiv and rider60.
I hope direct fit on the exiisting P150 rear axle kit- no need for modded spacers or some other stuff?
Or will i need to buy the P200 rear wheel axle kit/setup too?
I missed that- thank you invincible7.
Someone please post the prices too.
__________________
Old 4th July 2008, 17:14   #6 (permalink)
noidaboy's Avatar
Do check also on the bike's height if it needs to be raised from the rear shockers in order to get a p200's tyre. else the tyre might touch the upper body of the bike in bumps.
__________________
"its not WHAT i drive... its the WAY i drive"
noidaboy is offline   Reply With Quote
Old 4th July 2008, 19:45   #7 (permalink)
rider60's Avatar
there wont be any necessity for any mods its a direct fit! at most you might have to get p200's bearings thats all they will roughly around 300 for the rear thats all.
@noidaboy the stock p150's tyre the 100/90-17 very much on this alloy so we dont need to worry about that part unless he plans to upgrade!
and on the prices part i am not too sure but it should be approximately 5000 bucks or less not more! i am guessing it based on the karizma's price and its any day less as its a bajaj so good luck with that!
Old 4th July 2008, 19:51   #8 (permalink)
arpandiv's Avatar
it will be less than 3K :P
Old 4th July 2008, 22:27   #9 (permalink)
Ya- Bajaj rates are very low- maybe due to the appalling quality.
Just few days back i was chilling out with a few close pals at a friend's garage when i spotted some guy's year old but messed up P180DTSi engine being worked upon.
Almost fell off my chair when i learnt the block+piston+rings cost just Rs.1600/-.
I don't think i can get a single set of piston rings for my Shogun for that much now. (used to be 1K odd earlier).
No one has the width sizes in inches/mm as we used to get with older bikes? :(
__________________
Old 7th July 2008, 21:35   #10 (permalink)
Manoj2268's Avatar
If I recall, the mag wheels of P150 and P180 are of the same make(Some chinese brand) save the colour(P150- silver; P180-black) but on the other hand the mags of P200 and 220 are manufactured by Enkei. I think they have wider lip than the P 150 ones to accomodate the tubeless tyres. Your friend MAY have to change the wheel bearings.
My .02$
Manoj
__________________
Ridin' Alone on a HONDA.....And very proud of It
Manoj2268 is offline   Reply With Quote
Old 8th July 2008, 19:34   #11 (permalink)
Hey,
I don't think one should use the stock 100/90x17 tube type tyre on a P200 rear wheel as i feel it's motsly wider.
Shifting to P200 rear wheel may need shifting to the 120/80 tubeless tyre too.
What do you guys have to say on this?
Still waiting for someone to post the actual widths of the various wheels. :(
__________________
Old 8th July 2008, 20:20   #12 (permalink)
arpandiv's Avatar
Yes shift to 120/80 you will get to go tubeless !
i am sorry i have no idea about width. rest be assured they can be fitted on the 150.
Thread Tools
Minimalist Alloy Wheels theEnd Tyre & Alloy wheel Section 10 4th September 2006 08:31
alloy wheels cowiee Technical Stuff 0 17th April 2006 22:09
Alloy Wheels kashd Tyre & Alloy wheel Section 3 18th January 2006 19:26
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
