Old 11th August 2008, 05:25   #16
rider60's Avatar
Thanked: 47 Times
what is the point of k&n on a Unicorn, if its just for the sound effect then its fine, but you wont have any performance increase.
its just that the initial pick up would become a little better and the top end would just die out.
and trust me trying to get the jetting done on a uni is just a waste of time and money, just go through this thread, i took the plunge and i know.
http://www.team-bhp.com/forum/motorb...tml#post671446
i tried all the jets i could lay my hands on but its all gone in vain.
rider60 is offline   Reply With Quote
Old 12th August 2008, 11:58   #17
Kushanth's Avatar
I recommend RC1060 coz i use the same airfilter for my karizma and i have no issues with it
Kushanth is offline   Reply With Quote
Old 19th April 2009, 06:10   #18
muneemmk's Avatar
Thanked: 18 Times
Default K & N just for the sound effect and the initial placebo effects ?
Rider60's Observations seems to be spot on, The filter is all about the sound effects , once you get past 85kmph, then you have to wait all day to gain any more speed and there was a little missing too when in the higher revs, and now I am worried about re jetting too since he have already mentioned about the jets being able to do nothing for the bike. So what should I do now ? is there anyway of increasing the top end grunt ? or should I put it up for sale in Classifieds ?
muneemmk is offline   Reply With Quote
Old 20th April 2009, 08:26   #19
pratap007's Avatar
K&N's work best when fitted on the carb, RC1060 is the appropriate one for Unicorns and karizma's, the larger R1100 only has a larger flange and is offset by 40 degrees, rest of the dimensions are the same(as per K&N website) and is recommended for larger capacity bikes like Bullets etc...
I would'nt even suggest an air filter change even with larger jets etc... Manufacturers have tested jets at different altitudes and conditions and this might have seemed the most neutral and efficient hence these bikes are jetted in a particular way.
Unless you got your engine ported with a positive change in your port velocity, increased compression etc... such modifications(K&N) are useless in attempting to "gain power", either go all the way or stay stock(is best).
Unrelated Question - What is the price and weight of the front and rear spoked rims of the Unicorn??
pratap007 is offline   Reply With Quote
Unicorn Tyre Change: Suggestions? asault11 Motorbikes 99 4th March 2015 13:32
Unicorn GP Edition - Helmet suggestions needed ramv Motorbikes 11 6th February 2013 11:53
Honda CB Unicorn/Unicorn Dazzler - Technical Specifications & Feature List bluevolt Motorbikes 0 25th September 2011 15:35
RTR/Unicorn or Avenger - which one? Edit: Bought Unicorn - Dealer woes manish7 Motorbikes 34 24th April 2008 11:53
FUEL FILTER for unicorn? rider60 Motorbikes 8 31st October 2007 07:47
