Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 6th August 2008, 15:18   #1 (permalink)
ramki067's Avatar
Post Disk Brake to normal brake change?
Hi all,
My TVS Fiero F2 is a Disc version and lately i've found the disc is bent. I asked the dealer to remove the bend or what to do. He said its better to put a normal brake with brake pads which costs as much as new disk replacement which i need to do. So is good to replace a disc, or repair the disk or go for normal brake having brake pads? Does anybody repair disk bend near Rajajinagar, Bangalore? Please suggest me.
Thanks,
Ramki.
__________________
Silky Silver Maruti Suzuki WAGONR 2007 - Done 8K Kms.
2003 TVS Fiero F2 - Done 53K Kms.
ramki067 is offline   Reply With Quote
Old 6th August 2008, 18:44   #2 (permalink)
chiragh_bir's Avatar
Infractions: 0/1 (4)
don't even think of that!!
chiragh_bir is offline   Reply With Quote
Old 6th August 2008, 19:16   #3 (permalink)
JayD's Avatar
I don't quite get u, if converting to drum brake setup costs as much as getting a new disk, why bother with a drum setup? Just change the disc rotor and u'll be fine. The difference between the two setups is huge.
__________________
1957 Landmaster|1961 OHV|1985 Suzuki SS80 DX|2005 NHC GXi|2005 Pulsar 180DTSi|2007 Fiesta ZXI (P)|2009 i20 CRDi Asta (O)| ........
Old 6th August 2008, 19:56   #4 (permalink)
bblost's Avatar
Having used a Splendour without disc(of course) and now riding a tBird for a litle over 5 years with a disc.
Get your disc repaired. The advantage of a disc over drums is HUGE.
If spares are not available for a Fiero try retrofitting from any other similar bike.
__________________
Ever catch yourself listening to a nice song on the radio and dedicating it to your car.
bblost is online now   Reply With Quote
Old 6th August 2008, 22:17   #5 (permalink)
sidd_city's Avatar
Don't even think of doing that.Disc is anytime better. I don't think converting to drum will be cheaper cause you will have to change the wheel to accomodate the drum assembly. Stick to the disc dude.
__________________
Why don't they make the whole plane out of that black box stuff???
sidd_city is offline   Reply With Quote
Old 6th August 2008, 23:08   #6 (permalink)
aaggoswami's Avatar
Originally Posted by ramki067 View Post
Hi all,
Dont go to the normal durm brake setup.
Replace the disk and nothing else. If the pads are worn out, then replace them also. But dont try to go in for the drum brake setup.
__________________
Never Dream because broken dreams hurt the most.There is no market for emotions.
EVENTUALLY FATE DECIDES EVERYTHING.
aaggoswami is offline   Reply With Quote
Old 7th August 2008, 01:34   #7 (permalink)
rider60's Avatar
well there are people who do the rim bends straightening, and they might be willing to try out a hand at the disk too, it will depend on the amount of disk bent.
well i got this done once on my uni's stock disk, there was this sqeeling noise and a tik tik when braking at speeds above 40kmph i mean it was more audible and i could feel the shudder on the brake lever, so i got the bike water serviced, just to make sure there no sand or mud causing it.
the took it to this shop located at malakpet in Hyderabad, it quiet a big shop for this work and was very famous too. They too out the disk simply used a rubber hammer and straightenend it out and it was done! and i was happy to pay him 100 bucks for it.
you can give this a shot, before changing this, go to a reputed shop like this one that has some experienced guys, and give it a try.
you have nothing to lose any way at the most you will have to buy a a brand new disk!.
if you change the disk i strongly recommend you get a set of new pads too no matter when you changed the pads, this would ensure the new disk would grind uniformly.
all the best for the same hope its works good for you.
rider60 is offline   Reply With Quote
Old 7th August 2008, 01:37   #8 (permalink)
desideep's Avatar
+1 if the cost is same then why should you move to drum.
desideep is offline   Reply With Quote
Old 7th August 2008, 02:22   #9 (permalink)
Stay with your current Disc setup. Repair it and forget everything else.
It doesn't make any sense to go back to drums when the whole world is trying the opposite.
Old 7th August 2008, 03:03   #10 (permalink)
.anshuman's Avatar
Why would you do that if thats costing you the same? Disc brakes are so much superior to than drums,ive seen people plan for a rear disc and you want to go the opposite way.
__________________
Grande Punto Multijet Emotion pack
Elantra CRDi
Scorpio mhawk Vlx
Old 7th August 2008, 15:19   #11 (permalink)
while i am thinking of moving from drum to disc for my bullet, you are looking for a demotion?
anyway, pals, could you advise me as to the cost and where to get the change from drum to disc done for my royal enfield? thanks. i do not see any pre-existing thread for this for bikes.
__________________
If you're incompetent you have to be honest, and if you're crooked you have to be clever.
harsha.cs1 is offline   Reply With Quote
Thread Tools
Swift - Scratched Brake Disk, Help...! yzfrj Technical Stuff 17 4th June 2009 00:38
Brakes Catch Fire / Brake Bed in procedure / Brake Shudder : Solved Indian1979 Technical Stuff 25 4th March 2009 13:37
Brake Oil Change amtak Motorbikes 23 1st January 2009 16:51
Disk Brake problem in Bullet zoom_vroom Motorbikes 3 11th August 2008 21:57
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 6 20th August 2007 17:45
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
