Old 22nd August 2008, 09:43   #106
akshay4587's Avatar
Thanked: 1,686 Times
Coil rewinding, not yet done. The battery is holding up without any issues. But i might go for a 9Ah battery. Will a 14Ah battery fit in the ZMA batt compartment? I have a almost new 14Ah with me.
@sankar that was for fountainheader
Zma has Dc electricals it does not require coil rewinding,a 9A can be fitted in a zma i am also going for it soon since i need it for HID and hella horns
Old 22nd August 2008, 10:41   #107
Veelubai's Avatar
Thanked: 31 Times
sorry about that, dont have much idea about Ekm.Better get in touch with Zak,Aswin or Jaydev.IN Thrissur the 110/90 is easily available for around Rs1600 I guess.ITs a very nice fit for the Zma.
Veelubai is offline   Reply With Quote
Old 22nd August 2008, 11:35   #108
praful's Avatar
Thanked: 442 Times
PP220 is a good bike, but i believe that the Karizma would age gracefully than the P220.
^^So true.....
I remember saying something similar a few months back before I bought the 220.
praful is offline   Reply With Quote
Old 22nd August 2008, 14:56   #109
sammyboy's Avatar
Thanked: 351 Times
Hi Sankar, we are still waiting for pics and report Guess you are understandably busy completing the run in period heh heh
Need some advise on the RTR Fi, posting it in another thread. Look fwd to your suggestions.
sammyboy is offline   Reply With Quote
Old 22nd August 2008, 22:06   #110
Sankar's Avatar
Thanked: 4,655 Times
Today i bought a TVS headlamp relay with wiring kit, It's meant for cars and other vehicles but i will have to adapt it for the bike. Cost me 400 bucks. I didn't want to splice/slice any wire or use too much insulation tape for the relay kit i was planning that's why i bought the wiring kit. It's basically plug n play, i might have to extend the wire going to the battery thats all.
Hey Sammyboy i have posted few pics in the previous page. Anyways here's few more
Cancelled RTR Fi booking going for ZMA EDIT: ZMA now Bought-pdr_0026.jpg
Cancelled RTR Fi booking going for ZMA EDIT: ZMA now Bought-pdr_0029.jpg
Cancelled RTR Fi booking going for ZMA EDIT: ZMA now Bought-pdr_0031.jpg
Cancelled RTR Fi booking going for ZMA EDIT: ZMA now Bought-pdr_0033.jpg
Cancelled RTR Fi booking going for ZMA EDIT: ZMA now Bought-pdr_0038.jpg
Cancelled RTR Fi booking going for ZMA EDIT: ZMA now Bought-pdr_0043.jpg
Old 26th August 2008, 20:11   #111
Sankar's Avatar
Installed the TVS headlamp relay kit without cutting or splicing any of the stock wiring. From the TVS wiring kit i removed one set of holder and wire because there aint no second headlamp like in the car. That's the only thing i did and rest everything was just plug and play!
There's a lil bit difference in beam quality, but feels slightly more brighter and the best part is that the headlamp doesn't dim as much as it used to while the brake is applied. Only problem after this kit is installed is that the low beam and the high beam is mixed up. Got to swap out two leads of the wiring kit to rectify that.
So with headlamp, two indicators and brake light. The total consumption of power is 100w+21x2w+21x2w = 184w. Plus there are other lamps like 2x pilot lamps, 2x tail lamps & meter console assorted lights which are LEDs. So that is 184watt+3wx2+5wx2+6w(approx) = 184w+22w = 206w.
So the total approximate consumption can be estimated as 206w when all the lights are working. The stock alternator is rated at 188W.
Old 27th August 2008, 10:18   #112
Technocrat's Avatar
Thanked: 2,589 Times
Yes with the relays even stock light would be better since the bulb gets constant power.
You can take off the pilot lamps if you want the cosumption to be within the alternators capability.
btw did you notice that the LCD light is always on
Old 27th August 2008, 22:18   #113
roopakr's Avatar
Sankar , Congrats . The black beauty is looking great.
roopakr is offline   Reply With Quote
Old 27th August 2008, 22:24   #114
Sankar's Avatar
Roopak thanks! Btw does you car have a WRC sticker on the back windshield? I saw a white KL7 palio at around 930am at Poojapura roundabout two days back.
Old 1st September 2008, 13:22   #115
roopakr's Avatar
yes Shankar .You spotted it right.You may find it often in Poojapura area.Looking forward to meet you and your new ride in the coming season of ONAM .
OT
: I got my RX ported from NMW, thanks for the help and Info .
Old 5th September 2008, 00:26   #116
Sankar's Avatar
As mentioned in this thread i was running Phillips Rally 100/90 hadlamp bulb on my Karizma.
I replaced the 100/90W Phillips with Phillips Xtreme Power +80% 55/60W bulb. I'm pretty amazed by the light output and range, it very closely matches the 100/90 i replaced!
Now there is no dimming of headlamp when brake lamp lights up or when the indicator is switched on.
Old 5th September 2008, 00:53   #117
black12rr's Avatar
Thanked: 274 Times
^^ Does it come in pairs ? cost ? ,is it better than 60/55 rally ?
black12rr is offline   Reply With Quote
Old 5th September 2008, 08:42   #118
Sankar's Avatar
It's almost as good as the Rally 100/90 the bike had previously. So obviously this should be better than the Rally 60/55.
Yep it comes in pairs, it cost me 850 for a pack of two.
Old 7th September 2008, 16:42   #119
Sankar's Avatar
Got the lower engine cowl removed and installed a pair of Stebel Windtones in it's place. I like the look without the engine cowl, it looks functional and in my eyes aesthetically more balanced. Rear tyre in the picture is Pirelli Sport Demon.
In the picture the bike is half washed using Formula1 car wash, only front and top done, and it started raining so i took a break and shot this photo. Formula1 carwash was beading water pretty well. After the wash i wiped the bike dry and polished it with Formula1 wax polish. (I was looking for Tutle Wax when i went shopping but didn't get it).
Cancelled RTR Fi booking going for ZMA EDIT: ZMA now Bought-pdr_0048.jpg
Need Urgent Advice: 1.7K done Audi Q7: EDIT booked Toureg Edit: cancelled, now Q7 entropy Luxury, Imports & Niche 160 27th April 2010 07:27
what is the difference between OLD ZMA and NEW ZMA R ? deepclutch Motorbikes 18 7th November 2008 11:42
Passion Panther( Getz CRDi) on the way to my Home EDIT: Cancelled Booking now aks_karthik Test-Drives & Initial Ownership Reports 28 25th July 2008 20:58
Atlast booking a Swift VXI + ABS Edit: Bought Black VDI Now pitchucold Hatchbacks 37 30th May 2008 20:56
which wildlife sanctury(cancelled: going to Narkanda now!) tsk1979 Route / Travel Queries 24 7th December 2006 01:14
