Old 17th August 2014, 00:27   #16
B O V's Avatar
Thanked: 237 Times
Default Re: Electra 5S Modification
Originally Posted by rbppt View Post
Part 16 in the below link. I guess the name varies..
Allright I will enquire about it on monday.
So basically is the entire front end gonna be of TB type or are you modifying the electras front end with the parts to make it adjustable headlamps et al.
You want the trials look right.Yeah you do get smaller headlamps.You'd have to look aftermarket though.I do not know if the RE models have any smaller than the standard sizes.
I think if you start a fresh thread(with pics),a lot more opinions will come in.Lots of bullet gurus here on the forum.
B O V is offline   Reply With Quote
Old 18th August 2014, 12:01   #17
Here are two pictures of my Bull as it stands at present. One photo has the Clubman handle fixed to the front assembly, but it'll shift a little ahead after I fit in the head-bracket with the handle risers. Since I can't really turn well with the Clubman attached, the second photo is the Bull with the stock handle (wasn't tightened completely when I took the photo which is why it's inclined at an unnatural angle ). But I just got my K&N R1100 and I intend to fix it as soon as I figure out a substitute for the (tool)box containing the fuse and other electricals. Hopefully, after the rear part of the chassis opens up, the bike will look a little more brat.
Electra 5S Modification-10583880_10204460042684028_5621478198833373807_n.jpg
rbppt is offline   (1) Thanks Reply With Quote
Silencer Modification for Electra 4S thimappa Motorbikes 13 10th May 2012 14:52
Differences between RE Electra X and the New Electra Twinspark bornin70s Motorbikes 18 17th May 2010 19:23
DIY : Swift + Electra comps + Electra sub + havells power wire jithudigitised In-Car Entertainment 17 26th October 2009 16:38
Bullet 350/Electra 4S/ Electra 5S neoisme Motorbikes 23 16th June 2009 17:24
info about electra 5s chullan_no1 Motorbikes 0 28th October 2005 01:54
