Old 26th November 2008, 03:00   #46
YamahaBoy's Avatar
Hi Ankush. So your lighting issue is resolved. Great! Guess i will do the same thing for my P-150 too. Kindly let me know the foll:
1)Did u change the Stator plate & Bulb only? what about the rectifier? was that changed too?
2)Was the stator plate from the new avenger 200 or the old ave 180 or 180 Dtsi?
3)How much for the avenger stator plate?
4)Is higher Gauge wires required after the mod?
Thanks. cheers:
Originally Posted by ankushmulay View Post
Hi All,
Last week I changed the stator plate from the stock one to Avenger 180's stator and put a Halonix 55/60w bulb( spare bulb from my car set). Gives very good brightness.
Yesterday while returning from office an Indica was going parallel with me, so I tried to compare the brightness and I realized it almost equivalent!!!!!cheers:
Still, I will be trying out Philips Xtreme Vision or a normal Philips Halogen. Will let you all know about @ the results.
Till then Bye n Take Care...
Safe Driving
YamahaBoy is offline   Reply With Quote
Old 3rd December 2008, 12:41   #47
Thumbs up Success:Operation Lighting Upgrade
Hey folks,
I successfully upgraded the lighting of my P150-2006.(Non LCD one)
Its a pretty straight forward change, Just plug n play.
Items brought:
Avenger 180ís coil (part no. DV111005) 525.00 Rs/-
OSRAM H4 55/60 watt halogen bulb: 65.00 Rs/-
labor costs 70.00 Rs/-
Lighting has improved drastically...
Thanks a ton guys
cnureddy.b is offline   Reply With Quote
Old 5th December 2008, 21:45   #48
pkk_84's Avatar
Thanked: 42 Times
Smile Upgrading of Headlamp in Pulsar DTSI 180 Digital ver.
Hi Folks,
I am new to this forum. And I own a Pulsar 180 DTSI 2007 (Digital Version). As I m not stuff enough technically on this, I request your suggestions.
I wanted to upgrade my head lamp to high wattage more than what I have now (from current 35/40 W to 55/60W - If I am right) with a white Halogen bulb. Can any one please spoon feed me on what to be done on this. And what are all the spares to be changed for this small mod. Also please let me know if any impacts is there on the scoope glass if we upgrade to higher wattage, like the glass getting faded or blurred etc,.
Thanks in Advance,
Karthik
pkk_84 is offline   Reply With Quote
Old 19th January 2009, 16:36   #49
Originally Posted by cnureddy.b View Post
Hey folks,
Items brought:
Thanks a ton guys
do you feel any changes in the power and the overall perf of the bike. As the coil is thicker will there be any increased loading on the engine.. plz som1 explain
cfnamic is offline   Reply With Quote
Old 19th January 2009, 16:54   #50
Jaggu's Avatar
Thanked: 7,461 Times
Power and Performance of the engine: NO.
Load on engine: Very very very negligible, one cant make out.
Use a relay circuit for the headlight circuit to avoid premature burning of the switch gear and reduce the OE wiring load.
Old 19th January 2009, 18:39   #51
thebagchi's Avatar
Hey folks,
Items brought:
Thanks a ton guys
you have installed normal Osram Bulb
try Osram Silver Star or Osram Night Breaker.
there is nothing like NightBreaker. It lives upto its name.
thebagchi is offline   Reply With Quote
Old 19th January 2009, 22:53   #52
this relay circuit is it similar to the one Sankar has done in his zma... and more question any mechanic cab do this job right
Old 20th January 2009, 10:59   #53
mithun's Avatar
Thanked: 49 Times
What is the price of Osram Silver Star & Osram Night Breaker ?
Old 20th January 2009, 12:59   #54
thebagchi's Avatar
Osram Night Breaker is priced at Rs900, SilverStar is cheaper 200~300.
Old 31st January 2009, 08:07   #55
pkk_84's Avatar
Thanked: 42 Times
Smile
Hi All,
Safe Driving
Hi ankush,
I have enquired my mechanic regarding changing of Avenger 180 stator Coil to my Pulsar 180 (Digital Version), He says it will not set and not to waste money by buying it. Is it so?
More over I enquired in a Bajaj original spare parts shop, they say that there are two types of avenger stator plates one cost Rs 550/- and other cost Rs 750 /- they can give the spare if we provide them the old stator plate. I cannot provide the old one as I have pulsar 180.
Kindly suggest please.
Thanks in Advance,
Karthik
Old 31st January 2009, 08:14   #56
pkk_84's Avatar
Thanked: 42 Times
Question
Hey folks,
Items brought:
Thanks a ton guys
Can you please let me know whether the Avenger 180 Coil with the part No. DV111005, will do for Pulsar 180 DTSI (Digital Version) too...?
Need help Folks.
Cheers,
Karthik
Old 20th June 2009, 07:09   #57
Default Avenger stator plate installation failed
hey guys,
I tried to install the stator plate for avenger into my pulsar 150 dtsi (no self start). There was actually a green wire for neutral coming as extra in the avenger stator plate. In my sock one, this wire is combined along with the wiring harness itself. I suppose the above method will not work with the pulsars with out self start. Any suggestions..............
Old 15th December 2009, 16:58   #58
Hi Guys
I want to upgrade headlamps for my pulsar 150 - Kickstart , could someone point the mechanic shop in bangalore who has done this alteration successfully with out any issues? i have my cars 50/65 W bulbs spare with me, can i use these on my bike and where can i find the relay circuit for the upgrade in banglalore. Guys please suggest
challa is offline   Reply With Quote
Old 1st December 2010, 15:46   #59
Thanked: 36 Times
Guys!
Have a query.
I own a Pulsar 200 and I am thinking of using a 200W headlight relay meant for cars and use it in my bike with a 100/90 or 130/90 or maybe even 55/60 bulb from Philips.
Would there be any problem because as far as I know the car's headlight run on DC and not the bike's?
Or should I just buy Avenger's Stator Plate and use higher wattage bulb?
What wattage would the Avenger's Stator Plate be able to handle? 100/90?
abhipuru16 is offline   Reply With Quote
Old 1st December 2010, 22:43   #60
sagarpadaki's Avatar
Thanked: 1,256 Times
Originally Posted by abhipuru16 View Post
Guys!
Have a query.
Dont even think of putting anything above 55W.you will burn the headlamp glass!buy the avy 180 stator plate and a good 55W bulb like philips xtreme power.the avy stator plate can support max 60W thats it.
PS: I have done this mod in my 180 UG3 and it works flawlessly!
sagarpadaki is online now   Reply With Quote
Bajaj Pulsar 150 DTSi Series 2- Test Drive islero Motorbikes 17 22nd July 2016 10:02
Pulsar 150 DTSi 45k report cutdcrap Motorbikes 2 3rd January 2014 12:39
Apache 160 FI or Bajaj pulsar 150 DTSi ashwanth Motorbikes 42 20th November 2012 20:26
Pulsar 220 DTSi with R15 headlight sam_sant2005 Motorbikes 13 15th October 2010 21:49
Pulsar 150 DTSi or Unicorn?????? 1000bhp Motorbikes 5 28th February 2005 21:21
