Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 19th March 2005, 17:20   #1 (permalink)
revtech's Avatar
Question brake switch??
hey guys iw as just riding my bike the other day when my friend sitting behind asked me if it was possible to chenge the location of both the brakes. i mean on a bike the left hand controls the clutch and the right hand controls the front brake and the right leg controls the back brake so he wanted to know if it was possible to make the right HAND the BACK brake and make the right LEG the front BRAKE..
revtech is offline   Reply With Quote
Old 20th March 2005, 02:27   #2 (permalink)
merve_extreme's Avatar
i dont think.it is placed like that because of ergonomics.
still if u try it will be easy to take the rear brake up on the RHS leaver because it is cable operated but it will be difficult to fit the oil chamber for the front brake(disc) so far below at the back.drum brake would be easier.
__________________
No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz
merve_extreme is offline   Reply With Quote
Old 20th March 2005, 03:24   #3 (permalink)
Akkiben's Avatar
Originally Posted by revtech
on a bike the left hand controls the clutch and the right hand controls the front brake and the right leg controls the back brake ..
Well, it is designed so because the leg is capable of exerting more force on the brake pedal which is required to bring the rear brake into action and hauling the mass of the bike.
Now, if you swap the brake levers as your friend wants it to be!!! Here's what will happen, as evolution has it, the hand is more developed and sensitive than your leg hence, the pressure you are exerting from the foot will make the bike topple or unless you're good at stoppies you can try swapping the brake levers.
So, the hand being more sensitive is capable of exerting the required pressure hence it controls the front brake lever.
Hope that clears your doubts and realize the reason behind the placement of the brake levers.
__________________
Car is a necessity, biking is passion.
Akkiben is offline   Reply With Quote
Old 22nd March 2005, 00:00   #4 (permalink)
revtech's Avatar
yeah i got that but before the bike he used to ride a scooter which didnt have a leg brake so he is not used to the leg brake and thats why he wanted to know ifthe shift was possible..
Old 25th August 2006, 13:20   #5 (permalink)
If its a bike, then changing brakes will be difficult, becuse the back brakes are down by a rod link and not a cable link. However, if the braking is not done via rod, and its a scooter kind of vehicle, then may be its possible to try to get an alternate arragnement done.
However this is not really a good idea because right leg braking is one of the best way and it also allows for good control than a hand lever. Its a good idea to drive in slowly and get used to the vehicle before trying hard driving requiring more often use of brakes.
vincentt is offline   Reply With Quote
Thread Tools
Disk Brake to normal brake change? ramki067 Motorbikes 10 7th August 2008 14:19
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 6 20th August 2007 16:45
Only brake OR clutch+brake swiftcrazy Technical Stuff 8 10th July 2007 23:19
How About A Detachable AC Switch? directinjection Technical Stuff 17 18th May 2007 21:04
Cayenne: What does this switch do?? v12 Technical Stuff 12 1st April 2004 14:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
