Old 2nd December 2008, 15:08   #226
fieroid's Avatar
Thanked: 287 Times
BBR Rev box wont work on the Karizma/CBZ wiring. It needs a whole new set-up. so forget it. We have one lying since over a year now.
Forget upgrading the CDI and its a lon stroke motor, no point in making it rev higher and kill reliability.
fieroid is offline   Reply With Quote
Old 2nd December 2008, 20:25   #227
jkdas's Avatar
Thanked: 1,436 Times
Rode it last week. Better torque. I was very impressed the way it pulled when we accelerated while climbing a hill. Couldnt test it much as time was limited and I didnt take it outside city. Use first gear to startle pillions.
Old 4th December 2008, 07:31   #228
Sankar's Avatar
Thanked: 4,656 Times
Yep just as i thought. Thanks for clearing that up Joel. Imo it's best to build up on the torque rather than trying to make it a screamer.
Old 4th December 2008, 20:21   #229
fieroid's Avatar
Thanked: 287 Times
That long stroke can never become a screamer. The gyroscopic effect will ensure that.
Old 5th December 2008, 21:12   #230
Sankar's Avatar
Latest stuff:
1) Bought Amaron 9Ah maintenance free battery to replace the stock 7Ah
2) Got a Philips 100/130W bulb. Philips Xtreme power 55/60 is temporarily taken out of service.
Installation of battery. Many have installed 9Ah batteries in their Karizmas but from what've been told they had to cut and weld the battery holding clamp to make it fit. I wanted to avoid this. They also reported right hand side panel not closing properly after they installed a 9Ah battery. This had to be sorted out. Now a few photos of the installation.
Instead of cutting and welding the clamp was bent to take up the extra width of the battery.
Using a plier the end of the battery box where the retaining nut is present was bent inwards at an angle that match the bent clamp.
See this is how it bolts up. Perfect!
But there was a problem. The side panel wasn't closing properly leaving a large gap near the tank. It was found out that the battery retaining clamp's bolt's head was causing this. So that bolt was replaced with a flat screw head type bolt. Problem solved!
Side panel is now perfectly seated.
These are the boxes.
Old 6th December 2008, 01:25   #231
akshay4587's Avatar
Thanked: 1,686 Times
Sankar 100/130W???
even a 100/90w burns the reflector
Btw how is it performing any pics of the headlight beam at night?
Old 6th December 2008, 10:47   #232
praJEEP's Avatar
Originally Posted by akshay4587 View Post
Sankar 100/130W???
Nopes no issues if he is not a rider who rides non stop for 3 hours in night, if you take that into consideration even a 60/55w melts the reflector in continous riding say for about 3 hours. so one has to be carefull after they upgrade the bulbs and not use it for continous riding in night. these plastic reflectors are too sensitive when it comes to heating, whereas in rx its a different story overall.
EDIT : Sankar why didn't you try mico the light spread is better then philips though.
praJEEP is offline   Reply With Quote
Old 6th December 2008, 11:45   #233
Sankar's Avatar
I'm planning to do a major ride with a lot of night riding involved. Let me see how the reflector holds up
Will take a few pics at night and post.
Old 6th December 2008, 23:54   #234
Ricci's Avatar
Thanked: 995 Times
Sankar,
You have fitted a relay I presume . I found the 100/90 didn't run as well , apparently not getting the full 8.3amps from the stock 7AH battery . That alternator is rated at 188W, account for losses , consumption for ignition,other lamps and tacho/speedo and you might be running in narrow margin. Not to mention, can the stock wiring hold up to nearly 4 times the stock current , if the battery can supply that much juice ?
Ricci is offline   Reply With Quote
Old 7th December 2008, 07:52   #235
pratap007's Avatar
Originally Posted by Ricci View Post
Sankar,
Good to see you here Ricci.
Even accounting for the losses I think there should be enough juice to sustain the 100/90, never tried the 130/100 though. But you're right.. the stock wiring for atleast the headlight needs to be upgraded. I'm alternating between the 60/55 and the 100/90 with no battery drain felt except if I have the headlight on while I'm braking and I try to use the horn at the same time it seems feeble but the headlight never dims.
pratap007 is offline   Reply With Quote
Old 7th December 2008, 08:56   #236
Sankar's Avatar
The pics don't show you the real intensity of the bulb. While taking these pics almost all the vehicles that came from the opposite side dipped their headlights even when the bike's beam was dipped
High
Low
Sankar,
Ricci, i have installed a Bosch headlamp relay, so the stock wiring would be safe! Did you mean to say not getting full8.3Amps from the stock 7Ah battery or the 9Ah battery? I know, with this headlamp bulb i have far exceeded the alternator's rated capacity. With the headlamp+brake lamps+tail lamps the draw would be 130W+40W+10W=180W, very close to or maybe beond the capacity. Using indicators would add another 40W to it and will take it definitely beyond alternator's capacity. Console lamps would draw only in Milliwatts since they're LEDs. Unless i use the headlamp+braklamp+indicators together i don't thin i should worry... or should i? How much current does the ignition system need?
Old 7th December 2008, 09:50   #237
sreerama's Avatar
hi whats the price for amaron 9ah battery & philips bulb?
sreerama is offline   Reply With Quote
Old 8th December 2008, 00:00   #238
Ricci's Avatar
Thanked: 995 Times
@Sankar,
As I understand it, a relay only takes the load off the switchgear , using the switch only to turn the relay curcuit on. But the relay wire doesn't run the full length of the circuit upto the headlamp itself , or does it ? I hadn't used a relay , but even with 60/55 the headlamp would dim when the brake lamps came on. The Pulsar has a 9AH battery and runs a 55W with no problems, but can't say when you have a 130/100 . Heck I read here some car/SUV guys melted their reflectors or burnt the bulb contacts .
Yes the LEDs consume < like 0.5-1 W each , but the ignition circuit should be a major client ! And there are CDI, RR unit , the few electronics that would also take up 10-20W combined , plus the inherent losses across the circuit length. The rated 188W is at 5000RPM and it's a nominal value again, actual could be less ( or more ) .
This is one interesting thread , do keep up posted .
Old 8th December 2008, 00:03   #239
Ricci's Avatar
Thanked: 995 Times
@Pratap
From the snap it looks like you've changed the wires. What guage is the new wire and did you manage to find the OEM wire guage ?
Old 8th December 2008, 09:59   #240
Sankar's Avatar
@Sankar,
Ricci, It runs the full length from the Battery to the headlamp. Load is taken entirely off the stock wiring.
I have changed back to Philips Xtreme Power 55/60 yesterday, can't afford to have a burnt bike while on the impending long ride
I have to somehow find out what's the current draw by the ignition circuit!
1500 bucks for the Amaron 9Ah battery. Philips bulb - it depends on which one you want.
Rumour: Hero Karizma, Karizma ZMR production stopped Aditya Motorbikes 45 21st November 2016 11:36
Ford Fiesta 1.6 - Ideas for mods HRT_FPV Modifications & Accessories 109 23rd August 2012 10:12
Karizma mods suggestions epijay Motorbikes 34 3rd February 2009 21:14
Some ideas how I want to do some mods to my M-800 chokxxi90210 Modifications & Accessories 1 21st March 2008 08:16
