Old 27th December 2008, 08:19   #286
bmw_m5_titus's Avatar
Donno how that will work out since the Zma is atleast 10-15kgs heavier than the aforementioned bikes. I would stick to the shocks and get them painted black! But if you do have an option of swapping some friends apaches or Hunk s shocks to see how it works or get one cheap, it would be good.
bmw_m5_titus is offline   Reply With Quote
Old 27th December 2008, 09:10   #287
sai_ace's Avatar
Thanked: 195 Times
Never did like the red shockers much man. I ws thinking if i could go for a gas type shockabsorber from the hunk/apache. What say?
The hunk has got some good reviews for its rear shocks. The old apache's shocks arent great (personal experience), the rtr's are much much better. Good comfort and great handling (wrt to the rtr)
Why dont you look at the P200's shocks? they come in black and are superbly comfortable. Dunno about the handling part but i beleive it aint that great 'cos of a soft setup.
sai_ace is offline   Reply With Quote
Old 27th December 2008, 09:18   #288
Thanked: 175 Times
the bike is looking real nice. the indicators some how dont look nice. if i get the ZMA (that i really want to) i plan some thing same.
desideep is offline   Reply With Quote
Old 27th December 2008, 10:54   #289
praJEEP's Avatar
Don't go hunk shocks they are damn expensive and overpriced. try out the pulsar family but you have to mount the shocks upside down say like in bullet.
praJEEP is offline   Reply With Quote
Old 27th December 2008, 14:51   #290
Technocrat's Avatar
Thanked: 2,589 Times
Wow Sankar the indicators looks nice & gel well. The bike looks cool now
Sankar dont do this, ZMA has best shocks out of all the bikes that I have owned (P180,150, ZMA & RTR) Seriously there isnt anything better than stock shocks.
Old 27th December 2008, 18:40   #291
Sankar's Avatar
Thanked: 4,656 Times
Hunk is 143 kilos and Karizma is 150 kilos, both as per their websites. But my Karizma would weigh lower than a stock one by a good 10 kilos (minimum) or more since; the exhaust is much lighter, no fairing, no engine cowl, no engine cowl subframe, no kicstarter, no kickstarter stop (this is pretty heavy for it's size) and no airbox.
So Hunk rear shockers might work for me. But the height of the dampers also matter. Anyway the suspension idea is paused since performance wise i'm satisfied with the stock setup. GRS looks better.. oh my what have the Karizma done to me!! Lol
Anyway got a new goodie to play with, a Mikuni TMS32 flatslide carb. Loaned by my friend to see if it works out in my bike.
It's a big one, had to struggle to get it into the spare manifold i had. Throttle cable, the CBZ one i'm using for slide carbs, is short. I have to cut the outer to make the inner long only then would i be able to test it on the bike. Prolly tomorow will do it.
Here are coupla photos.
Have to search for a suitable filter for this.
Old 27th December 2008, 23:52   #292
Ricci's Avatar
Thanked: 995 Times
@Sankar,
I did enquire about the Hunk suspension, the HH supervisor said the lengths are different.
Ditch the Pulsar shocks idea, those cause that bobbing ( as if sailing on a boat ) on certain road undulations . Karizma shocks are pretty good stock , they match Pulsar gas shocks for comfort differing somewhat in low/high speed damping.
Ricci is offline   Reply With Quote
Old 28th December 2008, 08:48   #293
scorpian's Avatar
Thanked: 235 Times
Infractions: 0/1 (5)
@Sankar.
Thats one heell of a carb,jet it right and it will surely make you fly.....have seen those on motocross yamahas......
scorpian is offline   Reply With Quote
Old 29th December 2008, 10:25   #294
Sankar's Avatar
Fixed the TMS32 on to the bike yesterday and jetting is in progress. The results so far sounds good! Jetting is still not perfected, mains is getting closer.
Old 29th December 2008, 10:29   #295
akshay4587's Avatar
Thanked: 1,686 Times
How is the bike behaving with a 32MM flatside?
Old 29th December 2008, 15:29   #296
shazikon's Avatar
Thanked: 19 Times
Shankar, how did you manage cutting the cable outer?? I am trying to put a TM-28 on RX135, faced the throttle cable problem. Zeroed in on CBZ cable made hacks - toend of cable is RX cable becasuse RX throttle doesnt have the threads to inset throttle cable, bottom end (carb end) is CBZ, found cable to be very short, needs 3-4 mm more cable.
shazikon is offline   Reply With Quote
Old 29th December 2008, 19:22   #297
Sankar's Avatar
Behaving unlike any Karizma. Lol the throttle response is so awesome that if i whack open the throttle the bike surges ahead and if there's gravel or dirt on the road it powerslides....even with a pillion hehehe Main jet is almost correct. Have to sort out the midrange.
You have to take off the metal end cap of the cable. Then cut the plastic cladding. Now you can see the metal outer, this thing is made up of thin metal strip wound up in a spiral. You have to find the extremity of the spiral and try to poke the end outwards, so that a plier can grip it. Now with the plier slowly unwind the spiral, it's pretty hard but do able. When the desired length is unwound cut it off using a cutting plier.
Now the end where you have cut off would jut out by a bit. Use the plier to put it back in place as neatly as possible. Once that is done push the outer back into the cup! That's it!
Old 30th December 2008, 00:58   #298
redfire's Avatar
The bike is behaving entirely different. It has become a torque machine with crisp revvs. The real game is fully on throttle now as it has quick/sensitive response on engaging and leaving the throttle (it really needs quick throttle). The trial and error tuning is what we are doing and is going on. Hope will reach an optimum point soon.
redfire is offline   Reply With Quote
Old 30th December 2008, 11:50   #299
shazikon's Avatar
Thanked: 19 Times
Thanks Shankar, will try it soon..
Old 30th December 2008, 12:59   #300
Sankar's Avatar
This is a crazy carb! When i peek through the venturi when the engine is running i can see a good amount of fuel mix sucked up through the needle jet, haven't noticed this much of a suction in other carbs that i have tried on. The carb makes a nice whistle, like a turbo whistle, as the air rush into the engine.
What i have learnt when trying to jet this carb, throw the stock Karizma jetting numbers out of the window! Keeping that as a reference will never work
Rumour: Hero Karizma, Karizma ZMR production stopped Aditya Motorbikes 45 21st November 2016 11:36
Ford Fiesta 1.6 - Ideas for mods HRT_FPV Modifications & Accessories 109 23rd August 2012 10:12
Karizma mods suggestions epijay Motorbikes 34 3rd February 2009 21:14
Some ideas how I want to do some mods to my M-800 chokxxi90210 Modifications & Accessories 1 21st March 2008 08:16
