Old 28th September 2008, 22:06   #61
junkishya's Avatar
Thanked: 45 Times
This post is off the current topic as it does not talk about mods to Karizma .. however I thought it's worth mentioning it here !!
I've had owned RD350 for nearly 12 years ... when my brother wanted to buy a bike for himself I suggested him a Karizma 3 years ago .. I actually used to call the bike a "KARISHMA" not a Karizma, jokingly ..
Last week I rode the bike along with my wife from Bangalore to Nandi Hills .. This was the first time I realized the Karizma's capabilities .. I was able to touch and remain steady at 120kmph .... 120kmph is not uncommon on an RD but the same on a Karizma carrying 2 people (90kg + 70kg) .. I thought it's pretty amazing !!
The speed was based on the Karizma's speedo and Verna's speedo that my Bro was driving side-by-side !!
The point I wanted to make here is "If that's what a 3 year old stock engine can do .. then I wonder what it would do with some skillful mods on it !!!"
junkishya is offline   Reply With Quote
Old 29th September 2008, 02:47   #62
muneemmk's Avatar
Thanked: 18 Times
So what exactly is the end results as of now which Carb are you running right now the Dellorto or the Keihin ? and what jets ? The Keihein is the Karizma OE Carb right ?
muneemmk is offline   Reply With Quote
Old 29th September 2008, 14:28   #63
Sankar's Avatar
Thanked: 4,638 Times
Right now the bike is sucking through the stock Keihin with 130 mains (removed the 135), 40 pilot and modified slide. At this point of time there is no conclusion or end result because the changes have not reached the final stage. The airfilter is stock so it has to be changed when the uni comes, and jetting again checked and finalised. Bike is a lot better than stock but the stock paper filter is stifling the top end. I have removed the snorkel and it makes a slight improvement.
Edit: The manifold when compared to the carb venturi is pretty small. It narrows down to about 26mm at the manifold exit. And there is a steep change of angle inside the manifold, i guess it will hurt the flow at the top. I shall update this with the correct size later.
Old 29th September 2008, 15:18   #64
fieroid's Avatar
Thanked: 287 Times
So you find the stock carb better. Good.
on the 29CV, you dont need to bore the slide man. You dont get any upsize slides too.
Good luck with your jetting.
one thing let me tell you, no amount of carb perfection can match engine works in itself. Improving the flow, compression and related mods will make the engine much better and these carb mods will work best.
All this could give you 3-5% gains on the dyno.
So with the 130 mains, you dont find any flutter even with the stock airbox?
@ CBZ X has a 128 main jet but the thread is reverse. :(
fieroid is offline   Reply With Quote
Old 29th September 2008, 15:39   #65
Sankar's Avatar
Yep stock carb is better I did some basic maths, pi r square, and found out that even with the throttle plate in the middle it should flow atleast 4.8% more than the 28mm slide carb.
There is no flutter at the top end even with the 135 jet! I have changed to 130 just to see what difference it makes in revvability. I have removed the snorkel from the airbox, that's the only change to stock airfilter setup.
I think HH have deliberately reversed the htread on the CBZx jets to prevent swapping :( What if we change the emulsion tube also? Is the carb body reverse threaded?
Old 29th September 2008, 16:18   #66
balenopower's Avatar
Thanked: 228 Times
im planning a k&n filter along with 130mm jets as well.Let me know the 130's feel.
balenopower is offline   Reply With Quote
Old 29th September 2008, 16:21   #67
fieroid's Avatar
Thanked: 287 Times
I told you, a larger dia carb be it CV or otherwise will still flow higher..even with the butterfly. This should shut a few mouths too
The carb body thread is not reverse, hopefully. Only the mainjet was reverse.
Did u check if the needle on the stock carb has slots for settings?
Old 29th September 2008, 19:14   #68
Sankar's Avatar
Yep even i was of the other opinion till you corrected me and made me think!
Yoohooo Prajeep.... where art thou? How about opening up your CBZ-X carb and leting the world know what you find
The needle in the Keihin is non adjustable. It has a thick washer kind of thing at the top in place of the circlip.
How about using another needle, for eg a BS needle, in this carb? If the taper and length are similar then i think it should work. I have access to a BS26 that's not being used.
Old 29th September 2008, 19:54   #69
fieroid's Avatar
Thanked: 287 Times
Its always expected on these OE Keihin CVs. makes tuning even more hell.
But but, to use the BS needle, you need the needle to lock-up with a plate + washer + screw system which wont probably be an option on the Keihin. If the needle is not locked rightly, it would not control the main jet in the right angle..could lead to offset issues. I'm sure you know what night mares a badly set-up/screwed carb can lead to.
Also the stock keihin carb has no flow angle. The BS has a 15 deg flow rake which can give a mild draft to the fuel flow and can work along the flow lines of the inlet port. A contoured port is the best thing you can have. These are a few things that make the BS29 so much tempting over anything else. You can play with almost everything in that carb and no worry of damaging parts too, everything is available. Risk as much as you want while tuning.
Old 29th September 2008, 20:39   #70
Sankar's Avatar
The Keihin has the lock plate and spring arrangement that will hold the needle in place. But a small washer, of the same size as of the present one, has to be put above the circlip so that the spring could apply pressure on the needle.
Wow flow rake is new to me! Could you tell me what it is? Does the carb angle the flow better.. when looking through the carb it's almost straight!
Old 29th September 2008, 21:24   #71
fieroid's Avatar
Thanked: 287 Times
Flow rake and port is a whole different subject. They will matter with radical set-ups. I think I should not have mentioned this.
Just wanted to say how much better the BS29 is over the others. You can try one and see the difference.
Old 29th September 2008, 21:36   #72
Sankar's Avatar
Er.. ok But tell me is it related to the angle of the throttle plate at WOT? Anyways lemme see if i can source a BS29 to try on!
Old 29th September 2008, 21:46   #73
Mpower's Avatar
Thanked: 1,687 Times
Whats the stock compression ration on the Zma? Maybe there is some scope for improvement there. Also, intake vavle size anyone?
trying to understand why the stock bike is low on power even through it has the largest displacement.
Old 30th September 2008, 08:10   #74
scorpian's Avatar
Thanked: 235 Times
Infractions: 0/1 (5)
have a look at this,
scorpian is offline   Reply With Quote
Old 30th September 2008, 11:14   #75
SunnyBoi's Avatar
Thanked: 2,832 Times
Ummm a RXG carb? whats so special in that?
SunnyBoi is offline   Reply With Quote
Rumour: Hero Karizma, Karizma ZMR production stopped Aditya Motorbikes 45 21st November 2016 11:36
Ford Fiesta 1.6 - Ideas for mods HRT_FPV Modifications & Accessories 109 23rd August 2012 10:12
Karizma mods suggestions epijay Motorbikes 34 3rd February 2009 21:14
Some ideas how I want to do some mods to my M-800 chokxxi90210 Modifications & Accessories 1 21st March 2008 08:16
