Old 6th October 2008, 14:45   #106
fieroid's Avatar
Thanked: 287 Times
You can either remove all the masala from the stock exhaust or build a freeflow. Just removing the CAT cannot make any hell of a difference.
If I were you, I'd just leave the stock exhaust alone and build my own pipe and thats what I always do. Might build a pipe for the R15 also soon.
fieroid is offline   Reply With Quote
Old 6th October 2008, 16:20   #107
Sankar's Avatar
Thanked: 4,656 Times
Joel, my folks are very sensitive regarding exhaust sound and i had to change the goldie type pipe from the Bullet due to this. So a proper free flow exhaust and removing the masala from the stock exhaust could again create trouble That is why i asked about using the pre cat con CBZ exhaust which won't be too loud since it's an OE pipe, but at the same time might flow better than the Karizma pipe.
Old 6th October 2008, 16:31   #108
fieroid's Avatar
Thanked: 287 Times
Do one thing. Get the CBZ non cat canister and use a Karizma's bend pipe. The CBZ has a slightly smaller dia bend pipe and that will tamper top-end performance although lower rpms will improve. Or get a larger 30mm bend pipe and weld to the CBZ canister.
It will be a lot better than the OE zma exhaust.
Old 6th October 2008, 20:30   #109
WiZ
Woah ! Pipe for the R15 ?
Please do tell on what all you're planning on the R15.I don't think any other guy in the country is set to blow that bike other than you ! You're da MAN !
WiZ is offline   Reply With Quote
Old 6th October 2008, 21:23   #110
WiZ
That's my exhaust.Better revving,mass centralisation and weight reduction and it didn't cost me a penny.When my dad is around,i just bolt on the original exhaust's cover (But he does enquire about the strange exhaust note )
[ Sorry for the pic quality.It's from a very inferior phone cam ]
Old 6th October 2008, 23:25   #111
Sankar's Avatar
That's what I plan to do. Gotta find an old CBZ exhaust now. If not the 30mm pipe i can atleast weld it to the Karizma pipe.
Wiz, i can't see the picture mate. Please repost.
Old 7th October 2008, 11:08   #112
WiZ
Old 7th October 2008, 13:03   #113
fieroid's Avatar
Thanked: 287 Times
Will surely let you know if I come-up with something.
And I will do something. The stock engine is hopelessly feeling under powered, although its pretty fast. I'm riding my Group D spec RTR these days, feels more lively and does a true 125+ everyday on the outer ring road. The R15 would takes ages to do the same.
Old 8th October 2008, 18:45   #114
Sankar's Avatar
Few pics from my side...
Jets from jetsRus: 4 Main jets with 2 pilots (40 & 42) Now the bike runs on 135 mains and 35.5 pilot (38might be perfect!). I might have to fit the choke cable back since starting has become tougher with the stock pilot.
These two Mikuni main jets are very much similar to the Keihin main jets, one is 107.5 and the other one is 118. I haven't checked if these two would fit the Keihin carb. Anyways not gonna try now.
Jets collection: Few have been gifted to friends.
Carburetors: Dellorto & VM28
Pirelli Sport Demon 110x90 18. It's heavy but grip is very good.
Chain cover is off. Never liked full chain covers on any of my bikes. I bought a pulsar plastic chain cover, the rear fitting is perfect, the front rather falls short of the required length. So i might have to make a 5cm long straight patti clamp to fix it. It will not be visible outside anyways. Pulsar 200 sprocket kit costs 1100 bucks, sprocket not available separately. I'm not changing anyways.
Headlamp bulb: Phillips Xtreme +80 55/60W. Beam is very good. If you look hard you'll notice that the bulb is infact slimmer than regular halogens.
jetsRus sticker
Airfilter is yet to come.... this loong wait is getting on to my nerves. Strangely when i did a plug chop the porcelain was white as if it's running lean, mind you this is with the 130 mains. The main jet has been replaced with 135 and the pilot is back to stock (35.5). Even with the 135 there is no fluttering or brick wall effect on higher revs, i wonder if i can put a 140 mains There is a lot less popping from the exhaust now while decelerating with closed throttle. Accleration is linear and smooth with this setup. Coasting enrichner is connected.
That's the Stebel windtone horns which has been shifted from my Bullet. They sound nice and goes well with the looks of the bike since it's black and small.
Old 8th October 2008, 19:09   #115
Technocrat's Avatar
Thanked: 2,589 Times
nice detailed Pics Sankar. Thanks for sharing
Please do post a detailed post on before & after performance
Btw how many kms on ODO so far?
Old 8th October 2008, 19:31   #116
akshay4587's Avatar
Thanked: 1,686 Times
I have that SPACO dellorto carb on my bull works like a charm.
@Sankar I would need a little detailed review as how it performs on zma,I had tried it once,low end was superb,but the bike refused to go past 90.
Old 8th October 2008, 19:43   #117
Sankar's Avatar
You're most welcome Kedar! Bike has done around 17xx kms till date. I will post the review after the mods have reached a final stage.
I had the original Dellorto on my Bullet which i sold. This Spaco Dellorto is as good as the original Dellorto. All the circuits are identical. The difference is original Dello has a plastic float bowl and a plastic top cap held down by two size 8 bolts. Choke lever is plastic and different. This one is as good as the original and suit the Bullet very well.
The problem you had with bike not exceeding 90 was due to the lean main jet. I did 120+ with the Dello after a drilled mains has been installed. But the drilled mains was too rich so had problem at the top end.
Old 8th October 2008, 19:55   #118
Technocrat's Avatar
Sankar we would also like to know how much improvement each mod did
Old 8th October 2008, 20:06   #119
akshay4587's Avatar
@Sankar if I am not wrong SPACo(Dellorto) Carb has a stock #105 main jet?
Any possibility of finding a bigger jet for this Carb?
Old 8th October 2008, 20:25   #120
Sankar's Avatar
Hehe... you know when it comes to writing i'm lazy But i'll post a review after the airfilter has been installed.
Anyways here's a brief in chronological order.
TPS off, stock carb & jets: Bike lost some midrange, revs up more easily
Dellorto, 105 mains and 38 pilot: Low end rocks, bike doesn't cross 80 to 90. Lean mains
Dellorto, drilled (approx 150) mains: Low end rocks, a mild bog in the midrange, acceleration vastly superior after the mid range bog. Crosses 120 quite fast, but bike surges in wot. reason mains is too large.
Keihin with 130 mains & 40 pilot with drilled slide and cut springs: Throttle response off idle has improved a lot and nearly comparable to the Dellorto. Acceleration is improved and the throttle reaction lag of CV carb is reduced. Mid range could do with a slight jetting down (but not possible with stock needle). Top end is good for 135 on level flat road and rider not crouching. No brick wall effect and plug looks lean.
Keihin with 135 mains and 40 pilot, modded slide and spring: Low end reduced and comparable to stock. Midrange is linear. Top speed not checked but again no fluttering or brick wall.
All speeds speedo indicated. Airbox snorkel has been removed for all runs. Intake resonator again removed couple of days back.
You have to import it. And it's costly since Dellorto jets are to be found on European and British shops. Anyways it's possible to drill the stock 105, thats what everybody with these carbs do. Go to the power tools shop and ask for drill bits 1.5mm for a 150 jet, 1.3 mm for a 130 jet. I bought a 2.9mm drill bit to drill the slide. (Anyone else reading this kindly note than this works for only round jets and not for hex jets)
Rumour: Hero Karizma, Karizma ZMR production stopped Aditya Motorbikes 45 21st November 2016 11:36
Ford Fiesta 1.6 - Ideas for mods HRT_FPV Modifications & Accessories 109 23rd August 2012 10:12
Karizma mods suggestions epijay Motorbikes 34 3rd February 2009 21:14
Some ideas how I want to do some mods to my M-800 chokxxi90210 Modifications & Accessories 1 21st March 2008 08:16
