Old 16th February 2005, 01:28   #1
Akkiben's Avatar
Lightbulb Tubeless tyres for Karizma
Hi Guys,
Its question time. I don't know where to start from. Let me cut short a long story.
I recently went to B.R hills, around 160kms from here. You would not beleive it guys, I had two Daaaaaaaaaamn punchers, one at the front(which was fixed really quick) and one at the rear(it was a damn nightmare). The rear wheel got punchered at B.R hills which is a desolate place, nearest village was a good 45mins away( around 12kms), anyway the puncher was fixed.
Now, the moment I got back to B'lore I set out to search for tubeless tires. Now what I found out is, that these tires are daaaaaaaaaaamn expensive. Pirelli are most expensive at around Rs.3000+ then comes FKR, Vee rubber, kings and what not.
Now here is the deal. Pirelli has a 110/80 configuration but no 120 size.(120/80 is made by Pirelli, dealer did not have that size). Would a 130/80 size be too big for the Karizma?? Vee rubber looked good and has a 120size, cost is Rs.2700. 110/80-pirelli is Rs. 3100. Anyway lets forget the prize for now.
The big question is, are these tires worth the money spent???
Considering that punchers caused by screws and nails can be easily fixed using plugs.
I need suggestions and reviews real quick as I wanna get this job done a.s.a.p. I know, what hell I went through pushing the bike through the Ghatt sections, THAT WAS EXHAUSTING, guys.
Akkiben is offline   Reply With Quote
Old 16th February 2005, 20:30   #2
Akkiben's Avatar
While I was shopping for tubeless tires, I asked at one shop if there are tubeless front tires avaliable, GUESS what the guy said, he said he'll convert the existing front zapper tire to a tubeless by changing the neck on the rim!!!!!!!
What is that all about, I know that tubeless tires can do without a tube because they are designed so, with steel belts and additional side wall strength, so what would happen if an normal tube tire is made to work without a tube, only time will tell
Old 16th February 2005, 21:53   #3
speedsatya's Avatar
Thanked: 712 Times
dont do that.i.e making a tube type into tubeless.
i think u can put any tire in 18 inch be it 110/80 or 120/...with your OD ur gearing will change .but you wont be able to notice the diffrence.wider and lower profile tire will give better grip ,but take care so as not to create a drag by putting very large tire .
speedsatya is online now   Reply With Quote
Old 16th February 2005, 23:17   #4
Akkiben's Avatar
Thanks Satya. So what would be an ideal size for the rear?? What about the brand?? and prize?? I hope I don't loose out on top end speed and pickup!!!
Old 17th February 2005, 00:02   #5
Rtech's Avatar
Thanked: 221 Times
Why don't you check out the Duro's? They are inexpensive and you can get a front and rear set. Pretty good tyres IMO, certainly better than the stock zappers.
Price no object, go for the Pirelli's. No doubt about that!
Old 17th February 2005, 08:25   #6
speedsatya's Avatar
Thanked: 712 Times
the OD for the following tires are:
120/80r18 =649.2mm
110/90 r18=655.2
130/80 r18=665.2mm
110/80=633.2mm
now whats ur original tire configuration
if it's 100/90 r 18 =637.2mm,
then 110/80 will give you the closest upsize .go for it.
Old 17th February 2005, 10:39   #7
Technocrat's Avatar
Thanked: 2,589 Times
A 110 pirelli is perfect for zma, 130 wud look awesome but may decrease performance slightly. If u can source a Michelin M4 then go for them coz they are lighter than the Pirellis & which result in better top end & mileage than stock zappers + the amazing grip
Old 17th February 2005, 15:10   #8
the pirelli tubeless cost 1700 for 110/90 in chennai.
i am using a michelin m45 110/90 not a tubeless .
sk8er is offline   Reply With Quote
Old 17th February 2005, 15:14   #9
speedsatya's Avatar
Thanked: 712 Times
Originally Posted by Akkiben
. . 110/80-pirelli is Rs. 3100.
:WTF: how can there be such a big diffrence in the two cities.
Old 3rd August 2007, 00:00   #10
vinfriend
Posts: n/a
Is tuff-up / Puncture proof tyre available for Hero Honda Splendor 94 model? How much does it cost?
Old 15th September 2008, 10:34   #11
krish3's Avatar
Thanked: 21 Times
I've got a Karizma R, bought 4 months back.
I would like to change to tubeless tyres , as it provides some safety in case of punctures as they don't deflate suddenly.
The tyre size should remain same as the stock Karizma as I'm not interested in going for broader tyres i.e. 100/90, 17 inches.
Please pour in your suggestions and place to get it from (I'm in Bangalore)
krish3 is offline   Reply With Quote
Old 15th September 2008, 16:31   #12
praful's Avatar
Thanked: 442 Times
Krish bhai saab I hope your ZMA is still running with 18inchers and not the 17"'s that you've just mentioned.
Doesn't the Zapper Vyde come in the 18" variant thats in a tubeless flavour?
Btw, why the sudden change...any issues on the Thanjavur ride?
praful is offline   Reply With Quote
Old 15th September 2008, 23:14   #13
ravi@64bhp's Avatar
Me too am looking for tubeless tyres. Of late, I have been doing lot of off-roading. Luckily nothing happened as of now. Now i am fearing a lot about punctures. Will keep a close watch on this thread.
ravi@64bhp is offline   Reply With Quote
Old 15th September 2008, 23:22   #14
SunnyBoi's Avatar
Thanked: 2,832 Times
buy tuff up tubes for both tyres. costs ~400 per tube. better than going tubeless.
SunnyBoi is offline   Reply With Quote
Old 16th September 2008, 13:03   #15
Even I'm on the look out for good tubeless for my Kari.. preferably stock size.. am also ok with one size up on the rear tire (110/80)
solly is offline   Reply With Quote
Rumour: Hero Karizma, Karizma ZMR production stopped Aditya Motorbikes 45 21st November 2016 11:36
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
Tubeless Tyres? Not Enough! How about Airless -Michelin TweelTyres mohit Tyre & Alloy wheel Section 44 10th December 2011 09:06
tubeless tyres navin Tyre & Alloy wheel Section 64 2nd February 2010 11:11
Tubeless tyres for Corolla novice Tyre & Alloy wheel Section 9 21st December 2004 13:30
