Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 18th September 2008, 17:14   #1 (permalink)
VSG12777's Avatar
Default White lighting & wider rear tyre for Pulsar 220
Hi guys
One of my close friends has just bought a blue Pulsar 220 last month and after seeing the HID kit on my Avenger 200, he’s pretty much attracted to the white light and wants to go for a white lighting system for his bike too.
However I have told him that the Pulsar 220 has excellent lighting already, with projector headlamps which is a first for any Indian bike. Also, as per my knowledge I have informed him that since the Pulsar 220 uses a projector type lighting system, the bulb type may be different compared to a normal H4 which is used in bikes like the Avenger 200 and cars like Santro, Cielo etc.
I told him that I would post a message on Team BHP to get some information on this, so here I am with the message being posted.
I’ve clearly told my friend that HID is not required for his bike since the lighting is already very good with excellent focusing, brightness and beam spread. However comparatively my HID’s brightness and beam spread are better. But I’ve advised him against fooling around with the Pulsar 220’s electrical system since it’s already more advanced than any other Indian bike. Plus the bike itself has been an expensive one – I think he’s paid around 93k on road in Chennai for the Pulsar 220.
Well, now it’s up to you guys to suggest what would be best for my friend.
He seems to want only the white lights – not HID. So for the projector type lighting in his Pulsar 220, maybe if we could get a white light bulb which is a direct fit like a Philips Vision Plus or Philips X-Treme Power etc (but a type which would be compatible with the lighting system in the Pulsar 220), it would suit him.
Anyhow, we look forward to your suggestions on this guys.
And he would also like to fit a wider rear tyre on his Pulsar 220. Which is the maximum size that can be fitted without any modifications ? I think right now it has the stock 120/80 MRF tubeless tyres.
So 2 things we need your inputs on:
* White lights for the P-220
* Wider rear tyre for the P-220
Look forward to hearing from you all on the above soon.
Thanks and warm regards,
Venkat
VSG12777 is offline   Reply With Quote
Old 18th September 2008, 17:18   #2 (permalink)
Spitfire's Avatar
Sound more convincing to him.
Your friend just wants to show off. Next he will be asking for the fairing of the R15. I think this thread is useless.
Spitfire is offline   Reply With Quote
Old 18th September 2008, 17:45   #3 (permalink)
VSG12777's Avatar
No SpitFire, he doesn't want to show off. He's quite a simple person and has been saving up for quite a long time to buy this P-220. He bought it with full cash. Not even on EMIs. He likes riding and enjoys the engine but never shows off. That's the kind of person he is.
Somehow he's attracted by those white lights, even more after seeing the HID on my Avenger 200. Me being a person who doesn't advise people if I know myself that I'm not knowledgable enough to do it, I decided that Team BHP would be the best place to get more info on this. And hence this post.
Looking forward to your inputs guys.
Warm regards,
Venkat
Old 18th September 2008, 17:55   #4 (permalink)
Technocrat's Avatar
fitting HIDs on P220 is a bit tricky as in you would need to put a 55w HID set(if they are available in bulb type that P220 uses). The normal 35w ones will simply not work & will need to be routed directly from Battery which will void the warranty.
The rubber at rear is sufficient, at the max change the tire to a better compound, no need to go wider.
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 18th September 2008, 18:05   #5 (permalink)
Spitfire's Avatar
If he has bought it with his hard earned labour, please ask him not to mess around with the electricals on the bike. Since its a FI bike it will be more complex.
White light can be done - but he needs to understand the worth over the projector headlight if there is any.
And please dont go for a fatter tyres, totally useless, will increase weight, reduce mileage. Not worth it.
PS: sorry if i came across as being rude, no intentions. I reread my paost above and felt i should have worded it better. Meet almost one person everyday who wants to mod his wheels for no apparent reason or just because someone else has it.
Old 18th September 2008, 19:07   #6 (permalink)
VSG12777's Avatar
Technocrat: No he doesn't wanna go for HID. If possible, just white light bulbs of the same type that is there in his P220. I for one, have been pretty impressed with the projector headlamps of this bike. Excellent design. The worst part of this bike are the rear view mirrors which are almost useless, as we can see only our arms/shoulders taking up 70-75% of the mirrors.
SpitFire: No problem man. I understand. Some people just want to do something to their bikes just for the sake of it. Even I have met such people.
* Yes, regarding messing around with the P220 electricals, I've already advised him not to do it since it's a complex system and since the bike itself is such an expensive one.
* As for the point on whether it's really worth getting the white lights, well I am not sure on this. Perhaps someone else on this forum could shed some light on this. Whatever type of bulb there is in the P220, if we could get the same type but one which produces white light instead of the yellow light, that would be fine. There is no desire here to increase the wattage etc. Just a direct swap from yellow to white light - ie like a normal 55W H4 halogen to a Philips X-Treme Power H4 bulb.
* For rear tyre, point taken. Maybe the existing tyres can just be used for a year or 2 before changing to a different brand but same size.
Thanks for your inputs guys. I'd love to hear more on the white light bulb swap for the P220 though. That's the main thing.
Also, what about some better cushioning for the seats ? They are quite hard. And in Chennai, which is the best place to get this done ? Guys from Chennai, please do give your views.
Warm regards,
Venkat
Old 18th September 2008, 19:10   #7 (permalink)
Technocrat's Avatar
just a direct swap from yellow to white light
Well the light isnt yellow the projector one is slightly bluish & upper beam is more white than yellow. I will update here if I come to know of a whiter bulb
__________________
Old 18th September 2008, 20:56   #8 (permalink)
phamilyman's Avatar
You need a H7 bulb.
Alternatively, the HID has issues, since the 35W HID (regular kits) confuse the sensors with lesser current drawl. You will need some minor jugaad, but for the sake of reliability, don't do it. Plus you void your warranty - the darn thing has a 5 year unlimited km engine warranty (first lots had). A HID is not worth that much. Just find a bulb.
And check the R15's tyre - 16 or 17. Or check the FZ16's tyre. Either should fit and give your friend the poser look he wants to get I fully agree with Spitfire here.
Old 18th September 2008, 22:02   #9 (permalink)
Veelubai's Avatar
One of my friend is using 140/70 mm MRF tyres.Its a direct fitment and he is quite satisfied with the perfomance of the same.
__________________
M O N S O O N DRIVE - IAm GAMe 4 IT.....
Veelubai is offline   Reply With Quote
Old 18th September 2008, 22:12   #10 (permalink)
phamilyman's Avatar
Just another thing - if your friend is truly a nice guy and not a poser like so many of us are surmising - kindly ask him to consider the public nuisance he will be with the HID/white light - the upside is that the projectors minimize the glare but white light is neither better visibility nor good for oncoming traffic.
Suggest he upgrades within the yellow 60/55 setup only.
Old 19th September 2008, 07:53   #11 (permalink)
Sk8erboi's Avatar
The easiest thing to modify in any bike is electrical..
You can easily fit 35w or 55w Kits no issues wat so ever the only thing is the alternator/dynamo has to be recoiled so that it produces more electricity even at idle so that battery doesn't wear out fast. HID kits need DC so it has to be connected directly to battery for DC... or put a better rectifier to supply DC...
Mostly bulbs for projector headlamps are 9005 and 9006 depending on high or low beam...
__________________
Sk8erBoi
H Accent CrDi
M Scorpio slx/glx/dx-4x4
M Bolero slx/slx turbo/sle/glx
MS Esteem LX '95
H City 1.5exi
T Innova 2.5V
Sk8erboi is offline   Reply With Quote
Old 19th September 2008, 10:43   #12 (permalink)
tell him that he can fix a superbike rear tire . BUT he will need to change the swing arm for it. A single sided swing arm looks better. And the tire itself will cost abt 9-10K. Swing arm and fixing charges extra. ps: I a not really sure if a SUV tire can be fixed or not on this bike, but if your friend is really serious, I am sure, there are ways. Advantage will be that he will not need to use central stand.. remember, even after all this, it still remain as a bajaj Pulsar
renamo is offline   Reply With Quote
Old 19th September 2008, 11:42   #13 (permalink)
Technocrat's Avatar
You can easily fit 35w .
Thats not true with the Pulsar's new range of bikes which has a BCP module which apart from other things makes sure you never ride without light in case one of the filaments(or bulbs in 220) gets kaput.
So if put anything that consumes less power than 55 w the system detects it as bulb failure & switches to the other bulb\filament. So for this you need to to some alterations to the wiring which voids the warranty & hence not advised.
__________________
Old 19th September 2008, 17:42   #14 (permalink)
praful's Avatar
1. For getting a HID on the 220, you would need a H7 55W HID kit. I know a guy in Chennai who can do it for you, he's expensive alrite, but does a good job. All this at a loss of the warranty of vehicle. Now being a 220 owner for slightly over 10 months I can tell you that warranty is not something you want loose out one. Esp in the first 2 years. My advice stick to stock or as you mentioned in your later posts, your friend wants only white light, he can get a white bulb from Philips/Osram in the H7 55W format.
As far as lighting being enough, well that all depends on ones needs and riding style. I personally feel that its enough within the city, but for highway riding at speeds over 80 is a bit dicey.
2. Wider tyre, why why why for heavens sake do you want to slow down the bike, loose out on mileage, loose out on top end??? The current 120/80 is anyways a size over than whats really needed on the bike, try putting a 110/80 and see how the bike flies. Anyways a size up might foul with the swingarm too. Absolutely not recommended. Again, if your friend is doing it for aesthetic purposes and has no qualms about loosing out on functionality....thencheers:
praful is offline   Reply With Quote
Old 19th September 2008, 20:18   #15 (permalink)
Thumbs up
WELL WELL WELL, PHAMILYMAN, & I thought we wre discussing lights for P150 & here you are giving contradicting statements.
CHEERS,
G D
Last edited by Technocrat : 20th September 2008 at 12:55. Reason: Only two smilies per post allowed, please read the rules carefully
P180V1 is offline   Reply With Quote
Thread Tools
Rear tyre for pulsar 150 classic venkatesh_t3 Motorbikes 15 21st July 2009 12:03
Used Pulsar 220? Kaustuv Motorbikes 24 25th February 2009 13:40
Pulsar 220 kailashnj Motorbikes 26 5th January 2009 15:52
Swift Vxi : Wider Tires At The Rear D1ISTHE1 Tyre & Alloy wheel Section 3 3rd November 2007 01:00
Pulsar 150 type1 rear tyre Veelubai Motorbikes 8 17th April 2006 13:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
