Old 19th September 2008, 21:51   #1
vis-racing's Avatar
Angry Shogun - water seeping into the engine
Hi All, I have this very weird problem. Every time i send my bike for a water wash .. Somehow water seeps into the engine. This further causes the engine oil to become soapy white in color.
is this normal in all shoguns.. Need your advice on this.
vis-racing is offline   Reply With Quote
Old 19th September 2008, 23:39   #2
SunnyBoi's Avatar
Thanked: 2,767 Times
Check the oil filler cap. thats the only place where water can seep in.
SunnyBoi is offline   Reply With Quote
Old 20th September 2008, 00:41   #3
Raccoon's Avatar
Thanked: 105 Times
It certainly does NOT happen in my Shogun!
Do you mean it gets into the transmission oil? Yes, the oil filler cap would be the 1st suspect. If there was some other opening, you would probably find oil seeping out of there... so you could check for that too.
Old 20th September 2008, 01:37   #4
Thanked: 52 Times
Water will enter the engine through the oil filler cap or the engine breather hole.
dinar is offline   Reply With Quote
Old 20th September 2008, 14:42   #5
2StrokeJunkie's Avatar
Thanked: 13 Times
^ spot on dinar. get an O ring onto ur oil filler cap. change ur gearbox oil . check ur breather hole and connect a pipe to it.
2StrokeJunkie is offline   Reply With Quote
Old 22nd September 2008, 23:31   #6
vis-racing's Avatar
Thanks Guys, Will try this, And post the update.
Smoke On The Water, Fire In The Sky (Into Lonar Lake And Crater) genesis Travelogues 43 19th February 2017 00:21
Rain water leaking into the car (Getz Prime) on the front passenger side mohan41 Technical Stuff 13 24th May 2015 13:07
Swift 2011 Petrol - Water Seepage into the Engine jaaz Technical Stuff 3 18th March 2012 14:10
Can sea water turn my Civic into a rust bucket? smartcat Technical Stuff 22 18th May 2011 10:45
Modifying a shogun engine? sam_freaks2814 Motorbikes 1 1st June 2006 13:03
