Old 27th January 2015, 00:51   #91
Default Re: Suzuki Fiero - Passion Reignited
Originally Posted by Mr.Boss View Post
That's what running in my mind. As you mentioned they were 2014 packed we could only get the clutch springs for the price that you mentioned earlier. BTW what brand are they?
They are TVS brand. I did enquire with a known person at a SS in Pune and he said that TVS has not compromised on quality and all parts are at par with what Suzuki offered in the initial days.
Intrepidspy is offline   Reply With Quote
Old 29th January 2015, 20:56   #92
Graven5's Avatar
Thanked: 36 Times
No compromise on quality by TVS - Mostly yes
But, ask any Fiero nut or specialist and they always have three inferior spare parts to name on the TVS Fiero.
1. Clutch plates
2. Engine block (cylinder build)
3. Exhaust pipe (Does not sound as crisp as the Suzuki)
Graven5 is offline   Reply With Quote
Old 5th June 2015, 16:49   #93
PatienceWins's Avatar
Thanked: 282 Times
I just got the bike serviced. I had to change the accelerator cable, clutch cable and tail lamp bulb. Went for shell advance engine oil. The bike feels as good as new.
The battery is weak, have to get it changed. The bike has run close to 45,500 kms.
PatienceWins is offline   Reply With Quote
Old 5th June 2015, 16:51   #94
Thanked: 282 Times
Pictures of my newly painted Fiero (2000):
The front dome looks great. Which one is that?
Old 8th June 2015, 19:11   #95
The dome is from Fiero FX. Went through a lot of running around for that.
The beam spread is superb for a 35/35 Watt due to the larger diameter.
Intrepidspy is offline   (1) Thanks Reply With Quote
Old 21st July 2015, 13:05   #96
agd19682's Avatar
Thanked: 18 Times
Hi All,
Can someone let me know where can I source a fiero FX headlight assembly in bangalore? I know that J C Road is the place to go to for such items but knowing which store to go to would be nice. Also, has anyone tried replacing the stock wheels with alloys? If yes, then, could you kindly share your experience?
agd19682 is offline   Reply With Quote
Old 22nd September 2015, 21:10   #97
kishoryk's Avatar
Re-igniting the passion, I have recently done the paint-job (black) on my 2000 model Fiero.
Hi Intrepidspy, where did you finally get the gold color Suzuki stickers? I have a Fiero with similar decals and the tank has lot of scratches, I guess, I do need these, if I have to go for complete paint.
@ Friends, can someone please suggest a good place to get my Fiero re-painted (black)?
In addition I have following immediate things to get it fixed:
- Rear shocks. Will explore the suggestion by @mashmash for gas based shock absorbers. What was the total cost, BTW?
- Oil leak from engine block. Like @fieroid/Joel mentioned, it could be the gasket issue. Need to look for a good mechanic (Service at authorized TVS showrooms so far - around HSR/Koramangala/Marathahalli and including Castrol bike zone on ORR - did not help)
- Broken plastic parts (side covers, etc.), If I can get them fixed to ensure original decals, will be great.
Once these essentials are done, I'd like to see, if I can replace stock head-lamp with a projector one.
Any details/help around this in Bangalore and a suggestion for a mechanic would be great.
I did ~70K on my 2001 model fiero and except the above minor issues, it still runs very well. Pick-up is good and I still clock 50-55 Kmpl. I service it every 2K KM with an oil-change.
Glad to know, there are still good number of Fiero owners!
Thanks,
Kishor
kishoryk is offline   (1) Thanks Reply With Quote
Old 24th September 2015, 16:54   #98
Hi Kishor,
I did search for the original Fiero decals before the paint job but the Golden color decals are no longer available. I settled for a closest match (without the glitter) procured from one of the number plate artists here in Pune.
You can replace the stock headlight with a round one from Fiero FX (difficult to find) or Suzuki Samurai. Stick to a 35/35 H4 setup if you don't plan to upgrade the coil.
Old 28th March 2016, 18:35   #99
Mine is all Stock Fiero.
Can someone suggest an appropriate replacement for the rear shocks without changing the swing-arm? What are the available options and prices involved.
Also where can i source FCC-rico clutch plates? Do the plates of any of the current Suzuki bikes (Zeus, Heat, Gixxer, GS 150R or Hayate) can be fitted??
Please give your inputs.
Old 31st May 2016, 14:50   #100
Any Passionate fiero guy who can help!
Old 28th August 2016, 20:35   #101
Thanked: 282 Times
I tried starting the bike after a gap of six months as I was out of station. It was not firing and I started it after a lot of effort. It was jerking a lot and I took it to a nearby mechanic. He said that the petrol is spoiled as the bike was unused for long and drained the petrol - still there is some mild jerking.
The air screw on the carburetor is jammed and he says the only option is to replace the carburetor. Which is the carburetor I can get for Fiero?
My old mechanic has become an enfield mechanic. Any competent mechanic or place near Marathahlli that is good with Fiero?
The seat lock is jammed and is not turning. If it does not work after lubricating, I need to break it and fit another lock.
Planning to go with gas shocks in the next service. Another modification in mind is to get a swing arm.
PatienceWins is offline   (1) Thanks Reply With Quote
Old 6th September 2016, 20:20   #102
kishoryk's Avatar
I have a 2000 model Suzuki Fiero (the first set of bikes with Suzuki insignia). I have been getting it serviced at regular TVS showrooms but I am not satisfied. The bike has lost it's sheen around plastics and metal parts of the body. Also I need to change the shock absorbers too.
I go to Enfield showroom once in a while but every time come back satisfied with what I have in Fiero - as such it runs very well from pick-up, mileage, comfort - no issues at all. But it needs a little sprucing up. It got bruises at some places!
In Bangalore, can someone please suggest a mechanic who can take the bike in and return it in a completely revamped one? Getting denting, painting work done, replace parts, fix any minor issues, covert the electricals into DC, add any useful accessories (like better head lights w/o changing the original shell), etc...
I'll be grateful any recommendation for a Fiero expert mechanic please.
Thank you!
Old 7th September 2016, 07:14   #103
rakesh_r's Avatar
Thanked: 737 Times
Thank you!
The Fiero shares some of the basic mechanicals with the RTR. Once the current bore wears out, you can replace it with the parts that of the RTR series. In this way you can get better performance with stock parts. Since you want to have better lights, you can convert the electricals to DC and mount LED aux lights. There is a shop called ruby electricals, dont know if it is still functional.
rakesh_r is offline   (2) Thanks Reply With Quote
Old 24th March 2017, 18:43   #104
Thanked: 282 Times
Changed the stock carburetor to Pulsar as there was missing and the bike is running as good as new. I plan to change the shock absorber to the gas shocks from RTR soon.
Old 12th August 2017, 16:21   #105
Thanked: 282 Times
I got the bike serviced. The service cost came to R.1600, with clutch overhaul and the usual service.
Fixed gas shock absorber from Apache 160 and the ride/ handling has improved a lot. The bike is more composed on bad roads. The cost of Shock absorber is 3800.
It is reliable, as good as new after 17 years, and hope it will stay so.
The odo reading now is around 45000. It should be easily around 55000 as the odometer did not work for a long time.
Suzuki Fiero Original Spares rk5578 Motorbikes 3 15th July 2012 09:16
Suzuki Fiero mis-fires GreenDay Motorbikes 11 15th February 2011 22:10
Gas shocks for Suzuki Fiero? rock18 Motorbikes 2 9th December 2008 17:54
Suzuki Fiero (2000) Clutchplate Mack Motorbikes 8 11th October 2006 11:40
Suzuki Fiero F2/Fx byke raja_ys Motorbikes 3 29th October 2005 18:41
