Old 28th May 2009, 16:08   #16
Thanked: 54 Times
Originally Posted by golem View Post
P150 CL ES. Going to use only one MAP sensor. Still to source parts and a old carb for construction. Based on help and ideas of many people round the net.
Initially may prototype is to start with 555 timer configured it as one-shot instead of a continuous multivibrator. When the
CDI sparks, the 555 timer adds fuel for the next firing, since
it's triggered at the same time.
The injector would be from Maruti Et el.
No EGT, No Pyro
In short it would be a eletronic carb like thing
Dude , I think you got the concept wrong . The fuel needs to be added first and only then does the firing happen . If you plan to inject the fuel much before the spark , then the fuel will be used only in the next cycle which will be useless and actually the efficiency will be much worse than a carb .
Bajaj ,TVS and Hero Honda have tied up with an australian company which does the fuel injection kits for them . May be you could google .
Palio 1.9D Fuel injection problem Rodeo Technical Stuff 29 10th January 2011 17:40
Bajaj Auto is going for fuel injection RoaringEngine Motorbikes 8 22nd May 2006 19:59
Does Fuel Injection really give that much of an advantage? Steeroid Technical Stuff 48 8th May 2006 21:59
Pre Fuel injection treatment by Electronic Convertor for Diesel and Petrol Suryam Technical Stuff 0 1st February 2005 11:39
Tuned port fuel injection kakx Technical Stuff 4 17th April 2004 14:37
