Old 15th October 2008, 10:10   #1
viky_s's Avatar
Thumbs up Best Engine Oil for RTR 160
hi guys,
my rtr160 has just completed 450kms . its first service was done earlier(about 300kms) so the oil wasn't changed.
Now i would like to change the oil.
Please suggest some good oil brands and the grades.
Should i go for full synthetic or semi ?
awaiting your valuable comments
regards
viky
viky_s is offline   Reply With Quote
Old 15th October 2008, 10:54   #2
praful's Avatar
Thanked: 442 Times
Stick to the company recommended mineral oil atleast for the first 2K kms, you can then consider switching to a semi-synth oil.
Go for a fully synth oil only after 5K kms are over.
praful is offline   Reply With Quote
Old 20th October 2008, 14:46   #3
Aston.Martin's Avatar
Thanked: 33 Times
Which is the best synth oil ?
Aston.Martin is offline   Reply With Quote
Old 20th October 2008, 14:59   #4
praful's Avatar
Thanked: 442 Times
And that deserves a new thread all together!
Well I have personally just used Motul 300V, reviews off the net talk a lot about the fully synth oils from Mobil and Amsoil.
As far is 300V is concered, well its amazing. Shifts remain smooth even after 4K kms of riding. But it doesn't work in the VFM aspect for me.
Old 7th December 2008, 20:19   #5
sreerama's Avatar
Yes as above said stick to the recommended engine oil at least for 2000kms as the engine has to break in & the rings should be sealed completely for future use.
If u use synthetic oil earlier the normal break in will not happen at all.
After 2000kms use any 20 50 oil as it will cut the engine vibes of rtr much better. Valvoline premium is a very good oil for rtr.
sreerama is offline   Reply With Quote
Old 8th December 2008, 19:37   #6
Raccoon's Avatar
Thanked: 105 Times
I believe TVS has its own branded oil made by BP. You could consider using that, at least for 1 - 2 thousand km. After that you could consider a fully synthetic. Motul should be a good option.
Please stick to the viscosity grade recommended by TVS! If I remember correct, it is SAE 20w40 for the RTR. Also, dont use oils of lower API rating than the one recommened. Dont evaluate an oil just by the smoothness it provides... there are too many factors involved!! Do NOT use 20w50 if a 20w40 is recommended.
Also do NOT use a car oil in bikes!
Old 8th December 2008, 20:45   #7
Why do you say that we shouldnt use 20w50 on a bike which has a recomendation of 20w40?
As far as I know the 20w has to be the same but the 40/50 the higher the better?
Gregory is offline   Reply With Quote
Old 8th December 2008, 23:04   #8
crazydiablo's Avatar
Thanked: 21 Times
Motul 300V or Castrol Power 1 racing. I would prefer Motul 300V.
crazydiablo is offline   Reply With Quote
Old 8th December 2008, 23:16   #9
Sankar's Avatar
Thanked: 4,639 Times
It's the other way around. Unless you live in very cold regions you need not bother about 20W/15W/5W or whatever that comes before the W. It's the rating the precedes W (for eg: 50 in 20W50) should you be bothered about.
Old 8th December 2008, 23:58   #10
aaggoswami's Avatar
Thanked: 1,541 Times
Just a query. My Suzuki Zeus has done 8K kms +. The dealer puts in " Idemitsu " from " Savita Chemicals ". I would like to put in synthetic oil.
But I think the clutch life will be reduced because of this.
So how come bikes like RTR and Karizma are able to digest the Synthetic oil ?
What brand oil can I put in my bike ?
aaggoswami is offline   Reply With Quote
Old 9th December 2008, 00:29   #11
Raccoon's Avatar
Thanked: 105 Times
Cant get into it right now, for want of time... but in a nutshell, just stick to the manuf recommendation! Do some research online if you want to know why.
Why do you think Zeus cant 'digest' fully synth oil? There should be no poroblem if you use a fully synth bike oil (JASO MA certified). Fully synth is anyday better than mineral oil. But personally, I dont find them cost effective, and havent used them. But thats upto you to decide.
Old 9th December 2008, 08:04   #12
sreerama's Avatar
hi for my unicorn honda recommends honda 2040 mineral oil. Its good for normal riding. Once you ride it hard you will feel the difference of performance of oils & honda oil is very bad for that i feel. Mostly i get engine heating problems if i ride 100+ continiously for 15 min in the highway. After that 40grade oils become like water & i donot feel the viscosity & engine runs harsher like water poured into it & even get tappet noise in the lower gears itself. Tried many oils mostly only 20w50 withstands hard riding.
RTR is a high reving bike & gets vibes,tappet noise,engine heating easily.
So i recomended 20w50 valvoline premium which is a synthetic blend oil specially for motorcycles & even reduces above all said & engine heating at high speeds considerabally than many oils which i have tested so far.
But i have not tested fully synthetic oils. It damages clutch a long run only when u use oils like eg mobil 1(not sure) which are designed for cars,not for bikes as i think car doesnot have wet clutch(not sure).
You can use synthetic oils after 2k specially for bikes like new castrol synthetic,motual etc which has some additives specially to reduce clutch slipage for motorcycles.
Old 9th December 2008, 17:58   #13
Raccoon's Avatar
Thanked: 105 Times
Strange that the Honda oil does not seem to be performing well. What is the API rating of the oil, btw?
Try the new bike oil from Tide Water (cant recall the name)... I believe its 20w40 and semi-synth. Not used it myself, but have heard good things about it. Dont pay much attention to companies claiming semi-synth tho... its likely more of a marketing gimmick.
Old 14th September 2010, 11:15   #14
hey, look i have done around 4k kilometers on my Apache RTR160, one thing i would like to bring to the notice of my fellow BHPians is that the "TVS has its own branded oil made by BP" has its own share of problems, it leads to engine heating and noise when you are at high speeds and after a 1000KM certainly the pickup also reduces. I was certianly looking for a replacement.
From the Recommendation of my esteemed members i will try out the Full Synt oil and update on my findings.
bose.srijit is offline   Reply With Quote
RTR 160 vs RTR 180 rangakishen Motorbikes 42 7th January 2012 20:59
TVS Apache RTR 160 "Fi": 0to60 in 3.8secs akkii Motorbikes 20 24th September 2009 14:57
Apache RTR 160 now with Rear Disc Brake! ramki067 Motorbikes 0 7th January 2009 13:42
New Rear tyre for RTR 160 viky_s Motorbikes 7 29th August 2008 21:52
