Old 25th October 2008, 13:22   #1
topend_hooligan's Avatar
Default Dynamic camber on motorcycles
Its widely used in hot cars to improve grip in cornering, but I was wondering what if there's a way to get the same on the front wheel of a bike (the rear too if it has a chain drive). What we effectively do when we hang off during cornering is try to keep the wheels as straight as possible, by lowering cg. why not have a suspension which inherently helps in doing that?
topend_hooligan is offline   Reply With Quote
Old 27th October 2008, 11:24   #2
Thanked: 161 Times
Wheels straight as possible? as far as i know i try and get as much lean angle as possible through a corner as traction permits, this is aided by having a low c of g. By "keeping the wheels straight" im assuming you mean as perpendicular to the road surface as possible?
howler is offline   Reply With Quote
Camber Adjustment query & Camber Adjusting Bolts? hell_rider Technical Stuff 18 2nd January 2009 22:43
Perplexed with camber readings swathyd Technical Stuff 12 23rd June 2008 21:47
Negetive Camber in Rear Wheels: Indica extreme_torque Technical Stuff 4 12th December 2006 20:39
No camber to avoid wandering? ajinkya Technical Stuff 1 6th August 2006 20:44
Help With Camber / Castor readings moralfibre Technical Stuff 7 22nd October 2005 10:34
