Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
LinkBack Thread Tools
Old 1st November 2008, 14:04   #1 (permalink)
Karizma Fan
Exclamation A Tip To Increase Your Bike's Mileage
Hi, I am a new member here and I just want to start out with some useful content for the members here...
I talked with Sudarshan from Chennai and was surprised to know that his Hero Honda Karizma R gives a mileage of 41 in the city and 49 in highways.
His bike is in perfect health. To keep the engine healthy all you have to do is, let the engine warm up before you take it to real performance. Small engines like that of Splendor NXG and Passion Plus have a horizontal engine, so as soon as the bike is started, the oil flows easily into the engine. But bikes with a high bore and stroke find it difficult to circulate the oil throughout the engine as soon as it is started.
Sudarshan recommends bikers to put the choke, self start the engine and leave it for 10-15 seconds so that the oil gets heated up and the luke warn low density oil finds it easy to circulate through upto the top of the engine. Do not leave the choke for too long as it would flood the engine with fuel. Do not open the throttle until it has run for atleast 5 km distance and the engine comes to a normal operating heat range.
If you gun the engine in cold conditions as soon as you start it, there would not be enough lubrication in the engine and it leads to more friction which ultimately damages the piston and the engine and hence your mileage will be low.
If you go to a gym, your coach will ask you to warm up before you do some heavy lifting and iron pumping… this is just like that. Your bike is not much different from your body!
Another good tip worth mentioning is to remove the saree guard if there is no use for it. It reduces dead weight by 4-5 kg and would definitely improve the performance of the engine and increase fuel efficiency.
This is not the greatest tip, but just my opinion. Let me know if you have tried something which has significantly increased your bike's mileage.
Deepak
Karizma Fan is offline   Reply With Quote
Sponsored Links
Old 3rd November 2008, 11:25   #2 (permalink)
mithun
mithun's Avatar
Straight lift from : Bike Mileage Tips... Increase Mileage of Your bike | BikeAdvice.in
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 3rd November 2008, 19:06   #3 (permalink)
hyper123
hyper123's Avatar
Deepak
Good points but...
show me one saree guard that weighs 5kgs!! It is made in the stone age or what? Come on man, max it will weigh 1.5 kgs.
The above mentioned points must be well known to 'bikers' who care about their bikes and read the bike manual.
For morning starts, kick start is recommended rather than self.
hyper123 is offline   Reply With Quote
Old 3rd November 2008, 19:19   #4 (permalink)
SuperSyn
Awaiting Email Confirmation
The most important: tire inflation.
Other thing that's important is riding style. Minimize braking. Change gear before peak HP, but somewhere after peak torque. Drive like a 50 year old uncle going to his office.
SuperSyn is offline   Reply With Quote
Old 3rd November 2008, 19:25   #5 (permalink)
Technocrat
Technocrat's Avatar
Deepak have you posted the original article too or you simply copy pasted it here?
Well for better oil circulation you should kick the bike 3-5 times with ignition off & clutch pressed this too helps in oil circulation before starting the bike & other tips are correct although removing Saree guard wont have much impact.
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 3rd November 2008, 19:45   #6 (permalink)
Sankar
Sankar's Avatar
Originally Posted by mithun View Post
Guys, it's his article
__________________
Present: A-Star, i10, HH Karizma.
Past: Contessa 1.8, Maruti SS80, Bullet 350, RX135 5Speed, Honda CB750 SOHC, Hero Puch.
Old 3rd November 2008, 22:01   #7 (permalink)
akshay4587
akshay4587's Avatar
So is there any new rocket science in this?????
If I had wished for 50kmpl and crusing at 80 i would have been better of with 150CC's
whats the point of riding a Zma at 60 for 49kmpl.
Idling the engine and removing the saree guard wont give you any gains in KMPL figures-Period.
__________________
1978 RE STD 350
1997 Gypsy MG410W(Sold)
1999 RE Machismo 350
2001 Bolero GLX(Sold)
2005 Zma 225
2006 Accent GLE
2010 Scorpio SLE
Old 4th November 2008, 10:23   #8 (permalink)
Technocrat
Technocrat's Avatar
@Sankar: I thought so but wanted to confirm.
Not at all, probably he just wanted to share with all what he heard
& yes you are right I really dont understand why people buy ZMA when they want such high mileage figures.
__________________
Old 4th November 2008, 10:27   #9 (permalink)
Spitfire
Spitfire's Avatar
Tip: To further improve the mileage of your bike you should try walking
PS: Its a joke. also isnt the above mentioned in the owner's manual. I remember the above tip or recommendation in my CBZ manual. Well it didnt say it increases mileage but more of a good practise.
PSS: And why only Karizma. Any bike(mostly 4 strokes) have a better engine life because of this.
Spitfire is offline   Reply With Quote
Old 6th November 2008, 23:30   #10 (permalink)
_abhay_
_abhay_'s Avatar
using break and throttle judiciously is the the most practical way to extract Mileage out of a bike, but if i buy a ZMA that will be the last thing on my mind.
sometimes when I run out of fuel and running on reserve for a long time, I use clutch and close the throttle (though this might not be healthy for the clutch plate) till she loses her momentum
KEEP the bike well maintained , regular service , clean filters , correct carb settings , correct Tyre pressure , etyadi
finally a killer trick - get her on main stand everyday after retuning home from office. ask some one to push her down from rear end. Then rotate the front wheel till you get tired ( swap position with the helper and repeat) . You will see the odometer moving up without you burning any fuel
_abhay_ is offline   Reply With Quote
Old 7th November 2008, 15:00   #11 (permalink)
ac 427
ac 427's Avatar
I have a wonderfull tip to increase your bikes mileage :
1) Do not buy a bullet (no offences meant to any bullet owner)
cheers,
AC
ac 427 is offline   Reply With Quote
Old 7th November 2008, 15:09   #12 (permalink)
bblost
bblost's Avatar
cheers,
jay
I ride a 5 year old tb with around 70k kms.
In March I did a 900 kms round trip with a pillion.
Onward journey was completed in 9 hours. That is an average of 50 kmph. Includes breakfast and tea breaks. First long trip for my pillion, meant more breaks than I normally take.
Return journey was in rain. Some 300 kms was ridden in pouring rain. It took us more time because of these conditions.
MILAGE 40 KMPL
So next time think before you write about a bullets milage.
It has a certain role. It does that in a fabulous way.
__________________
Just an ordinary guy, living an ordinary life.
When I am riding my bike, I am one of God's favorite kids.
QUIT SMOKING.
Before its KILLS you.
Old 7th November 2008, 15:15   #13 (permalink)
ac 427
ac 427's Avatar
Return journey was in rain. Some 300 kms was ridding in pouring rain. It took us more time because of these conditions.
MILAGE 40 KMPL
Dear Mr. BBlost,
I am a existing owner of a Std Bullet 350. She is wonderfull, and i love her. She is 1984 Make.
This post was supposed to be taken in the right spirit.
I too have had long trips mumbai - bangalore, mumbai - Ahd. .. . .
And i too have got mileage of around 30 - 35.
This post was just a take on the bullet, it was not mean't to be taken against ones pride and honour. It was a gentle 'poke'
I apologize if i did so.
Mods: Sorry to take this thread off topic.
AC
Old 7th November 2008, 15:15   #14 (permalink)
Technocrat
Technocrat's Avatar
cheers,
AC
Care to explain What has increasinga bike's mileage got to do with buying or not buying a bullet?
__________________
Old 7th November 2008, 15:16   #15 (permalink)
srijit
srijit's Avatar
^jay, that is silly advice. Thats like me saying you are a fool (no offense meant). The fact that you have to mention "no offence mean" means that you will offend someone. Better to say nothing in that case.
On topic: I have gotten about 40 kmpl from my father's 20+ year old bullet 350. I now drive a pulsar 180 and I get about 40-42 kmpl from city riding. So I dont understand why I shouldnt get a Bullet. I mean a 2006 year model bike is still getting the same mileage as a 1981 year old bike. And the newer one doesnt also have the charm of the older.
srijit is offline   Reply With Quote
Thread Tools
Accessories for Mileage increase narayanan Technical Stuff 23 14th August 2009 14:55
Increase ground clearance of Civic & improve mileage vivek_sharma20 Modifications & Accessories 32 8th June 2009 10:44
How to increase mileage of my Alto ? Tapan Technical Stuff 17 9th October 2008 16:24
Painting my bike's wheels. What should I go for? Rtech Motorbikes 31 5th July 2006 20:59
My bike's engine keeps running. turbo_v12 Technical Stuff 12 16th April 2005 07:39
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698
