Old 7th November 2008, 23:40   #1
motocamp's Avatar
Thanked: 99 Times
Default Building a classic drag bike
Hi guys.i normally dont post much in the bike section.I am rebuilding my royal enfield 500 drag bike.
I have started a blog which i will be updating reguarly. i thought it might be interesting for all the motor heads to see the bike as it progresses.
monster dog
motocamp is offline   Reply With Quote
Old 1st December 2008, 08:56   #2
motocamp's Avatar
Thanked: 99 Times
I have updated my blog monster dog
Things are just starting to get interesting, Check it out.
Old 31st December 2008, 08:50   #3
motocamp's Avatar
Thanked: 99 Times
Default my classic drag bike
An update on my 500cc based royal enfield drag bike "monster dog".
The bike is finaly on the road, and we are in the process of running the engine in.
I couldn't upload any pictures because of the size restraint,so you can check my blog monster dog
Old 31st December 2008, 10:15   #4
chiragh_bir's Avatar
Thanked: 70 Times
amazing stuff there..
if u want a bettter start ..shift to discover's 17'' steel rims + good set of tyres .
what carb & filter are you using?
Shift to Motul 300 v fully synthetic oil and see the difference by your self
chiragh_bir is offline   Reply With Quote
Old 31st December 2008, 10:23   #5
reddy6980's Avatar
Good one,
How fast does it Go.
125km in the third gear means it may cross 160km in the fifth.
reddy6980 is offline   Reply With Quote
Old 31st December 2008, 10:26   #6
akshay4587's Avatar
Thanked: 1,686 Times
Amazing
What mods she is running?
what are the quartermile?
0-60 and 0-100 figures?
Last but not the least how much power does she make?
Old 31st December 2008, 20:01   #7
motocamp's Avatar
Thanked: 99 Times
The bike is still in the break in stage so we are not riding it hard, and i would not like to talk about figures i dont have right now like the top speed and Hp, but i will have all the correct data by the 2oth of next month and i will post it then.
This is just the begining
Old 15th January 2009, 21:03   #8
motocamp's Avatar
Thanked: 99 Times
It's official! At 12 noon on the 14th of Jan 2009 on a test run to see how the Veypor functioned we clocked a 100mph or 161.8kmph on the veypor motorcycle computer.
The run started off slowly, i was'nt planning to open the throttle.I still had the stock speedo bolted on to see how inaccurate it is.I revved monster dog up past 3000rpm and suddenly decided to push the bike a little.The acceleration was instantanious and fast, before i knew it was blasting down the road. So used to the older albion 4 speed gearbox,i changed into 5th only after i began to slow down.
The run was fast but for the short distance and slow start i was not expecting the bike to hit a 100mph so easily.
I Dont have the correct cable to attach the veypor to my laptop and download the data as yet, so i have a screen shot of the data you can see it on my blog.
The future looks bright for monster dog
Old 16th January 2009, 15:10   #9
Brutus's Avatar
Thanked: 45 Times
Any info on the motor mods you've done,dude. Or is it a trade secret??
Nice Job you done there.
Bikram
Brutus is offline   Reply With Quote
Old 16th January 2009, 19:54   #10
Sankar's Avatar
Thanked: 4,641 Times
Good work man, 160 is really fast for a Bullet. I see you have used the 535 high comp piston What other goodies in there?
Why didn't you lighten up the bike - lighter fork assy for example, and thinner & lighter wheels, if it's going to be an all out drag bike?
Old 16th January 2009, 20:49   #11
Mpower's Avatar
Thanked: 1,687 Times
What exactly is your goal with this bike? You call it a drag bike but you are talking about a top speed run.
The gearing and sproketing requirements are different and conflicting for both. If you want top speed, you might want to build a fairing.
Old 19th January 2009, 21:41   #12
motocamp's Avatar
Thanked: 99 Times
It is a drag bike,who said that was the top speed?we are currently testing the bike the finished product would take another year.
I am building a unstreamlined bike, no fairing!
Too many to list right now, some still only on my list, things will become clearer as i proceed
I dont want to change the major components, my goal is to use as many royal enfield designed parts as possible.the bike should be easily recognisable.i will be lightening the bike further.
this is a long project these things tend to take time.
Old 19th January 2009, 23:05   #13
might be a OT, but I guess from ur chasis desings an all you can actually build a batpod.... btw the speed is really amazing
cfnamic is offline   Reply With Quote
Old 20th January 2009, 00:10   #14
Gordon's Avatar
Thanked: 197 Times
Thats one of the major goals one must have when modifying/converting a bike. It brings more elegance, simplicity and style. Which is what we've always looked forward to in our cafe's.
I completely agree on this one. When you're doing it the first time, it always takes time. And in the end, all you'll get to hear is "oh this is so simple to make". Its not just what you made, its how you made it.
Congratulations on your achievement to attain the ton!!
Gordon is offline   Reply With Quote
Old 20th January 2009, 07:22   #15
Sankar's Avatar
Ok. For a landspeed bike stock doesn't hurt that much. But on a drag bike lighter definitely helps.
Bullet's identiy is manly split between two parts - 1) the engine, clutch, gb combo and 2) the casquette. Retaining any or both of these two components will preserve the identity of the machine. For a drag bike go light everywhere possible. Just my 2 paise.
Building a 'Pocket Bike' out of a TVS Scooty ES Mr.Boss Motorbikes 16 2nd March 2017 08:51
Advice on building a faster Dirt Bike for Racing rhuturaj Motorbikes 7 13th June 2014 18:45
The building of a concept bike... Tyagi Motorbikes 14 15th January 2010 13:44
Bike and Drag Questions ashwingop Motorbikes 3 18th March 2006 03:00
Toms drag bike pic Jaggu Indian Motorsport 25 10th January 2006 18:08
