Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Closed Thread
Thread Tools
Old 21st November 2008, 08:40   #1 (permalink)
Default APZoom says Check this Out :) - New 250 cc Sportsbike in India Comet GT 250
Should R15 get worried? where is the KAWA 250 R r Honda 250CBR
The most desirable motorcycle in India has arrived. If you love sportsbikes, your prayer has finally been answered. Welcome the high spec, high performance sportsbike Comet 250
The Comet 250 made by Hyosung Motors , brings breakthrough technology and performance with its 250cc, v-twin , 8 valve, oil-cooled engine that gives 27 bhp power, 21 Nm torque and a top speed crossing 140 kph. The Comet 250, India's only speedster with advance technology like upside down front suspension, 5 step adjustable rear monoshock and much more takes the motorcycles scene in India to a new level!
The first real sportsbike in India, the Comet is priced at Rs. 1.67lacs (ex showroom, everywhere except in Hyderabad where it is Rs. 1.63 lacs); and is available only as a “limited edition” bike in select cities only.
If you are interested in the Comet, please send us an email at jane@kineticindia.com for more details
The Comet sports the following world class features :
  • The large sized bike has a naked sportster styling inspired by Ducati Monster motorcycles and dazzles with its perfect proportions and a massive sculpted petrol tank.
  • The Comet 250 will be available in three striking colors red, black and yellow.
  • The Comet features a very high tech 250cc, v-twin, liquid cooled, 8 valve engine (which uses roller bearing camshafts, chain-driven DOHC valve gear operating on four valve per cylinder heads and using dual squish combustion chambers for optimum volumetric efficiency and twin down draught Mikuni CV carburettors for fuelling ).
  • high spec suspension - meaty inverted forks upfront with a magnesium finish to the outer tubes and a monoshock rear suspension.
  • Rectangular steel cradle frame finished in silver chassis
  • The most powerful brakes - 300 mm front disc, 230 mm rear disc.
  • 6 spoke alloy wheels finished in white .
  • Massive tubeless tyres (110 section up front and 150 section at the rear).
  • Standard electric start.
  • A sporty riding position that keeps most of the riders weight neutral and importantly off the wrists.
  • The Comet project initially started as a 250 and 650 based around the same cycle parts and hence (for the 250) every bit is oversized and over specced. Swing a leg over the Comet and she feels more like a 600 than a 250.
  • 1430mm wheelbase.
  • The differences in rim size (3-inch front to 4-inch rear) make for a quick turning bike.
  • The preload is adjustable on the rear suspension. The suspension of such mono-shock bikes can be set up for individual riders.
The Comet, technically :
ENGINE TYPE : Twin Cylinder Vee – Oil cooled
4-stroke Displacement : 250 cc Cylinder arrangement : Vertical V – 2 ( 75°) Maximum Power : 20.0 kw ( @ 27 bhp) @ 10000 rpm Maximum Torque : 21 N-m @ 7500 rpm Bore x Stroke : 57 mm x 48.8 mm Compression Ratio : 10.1 +0.2 : 1 Carburettor : MIKUNI BDS 26 Valve train : SOHC - 2 Valves per cylinder : 4 valves x 2 cylinders Power to weight ratio : 0.159 bhp/kg Starting : Electric start Ignition : Electronic CDI : Spark ignition Clutch : Wet Mechanical Multi plate type Transmission : 5 speed Gear Box CHASSIS Type : Steel Super Rectangular Section dual cradle perimeter frame SUSPENSION Front : Inverted type Telescopic Hydraulic, with magnesium finish to the outer tubes
Rear : Monoshock rear Hydraulically damped, 5 - stage Adjustable BRAKES Front : Dia 300 mm DISC Rear : Dia 210 mm DISC Brake fluid WHEELS AND TYRES Rim size (Front) : J17xMT 3.00 Rim size (Rear) : J17xMT 4.00 Tyre size (Front) : 110/70 - 17 Tyre size (Rear) : 150/70 - 17 Tyre makes : Imported (shinko, tubeless) DIMENSIONS Length : 2080 mm Width : 760 mm Height : 1120 mm Wheelbase : 1455 mm Saddle height : 795 mm Ground clearance : 180 mm Kerb weight : 170 Kg ( Dry 155)
Where and how can I get the Comet:
  • The Comet is available in select cities at select Kinetic dealerships only:
    • Bombay
    • Delhi
    • Bangalore
    • Chennai
    • Kolkatta
    • Guwahati
    • Coimbatore
    • Chandigarh
    • Pune
    • Hyderabad
  • Kinetic will take care of all import related and homologation related formalities
  • EX showroom price of the bike is Rs. 1,67,000( except Hyderabad where it is 1,63,000). This price will include all import customs duties, but registration, insurance are extra.
  • The bookings are open only for restricted time.
  • For list of authorized dealers, please email us at: jane@kineticindia.com
What the press speaks:
  • "Easily the most desirable two wheeler money can buy in India"
    Autocar India
  • "world-standard sportsbike bristling with value"
    - Autocar India
  • Life on the Comet begins where tacho needles on other bikes die of vertigo. And the surge of power can be seriously addictive.
    - Business Standard Motoring
  • "Those of you who cry hoarse for true sportsbikes, quit making excuses save up and make trails on your personal Comet.."
    - Autocar India
  • "The comet GT250 is superior to anything weve seen"
    Autocar India
  • Finally a pukka sport bike !
    Overdrive
  • There is no doubt that the Comet is by far the best looking performance bike ever sold in India
    Auto India
  • "The long wait is finally over. The wait for a genuine top drawer sports bike that has the pace and dynamic ability to finally live up to the sports tag."
    - Overdrive
  • Plainly put, the Comet doesnt have any competition in the country!
    Overdrive
  • Heres the thing with the Comet its really rather good. It will be when introduced the best looking motorcycle in the country.
APZoom is offline
Old 21st November 2008, 10:52   #2 (permalink)
devil_in_flesh's Avatar
Ok i dont get this? Is comet being launched again? or is this old news? Please throw some light as i fail to understand the meaning of this post.
__________________
RIDE TILL I DIE!!
devil_in_flesh is offline
Old 21st November 2008, 10:54   #3 (permalink)
have they launched it again or this is just the old website? cause the sebsite does mention the date.
dinar is offline
Old 21st November 2008, 11:14   #4 (permalink)
Spitfire's Avatar
The site even shows the Aquila and the Stryker (long dead) as being available too.
Duh? Didnt Mahindra buy Kinetic over?
Spitfire is offline
Old 21st November 2008, 12:24   #5 (permalink)
niks_devil666's Avatar
This link has been on the site for ages .....
niks_devil666 is offline
Old 21st November 2008, 12:50   #6 (permalink)
ssjr0498's Avatar
so what is it! Has the comet been relaunched?
__________________
It's not the triumph!! But the struggle!!
ssjr0498 is offline
Old 21st November 2008, 13:01   #7 (permalink)
^ no , just that they haven't uploaded the site for quite some time now.There has been no news of a relaunch of comet.
Old 21st November 2008, 13:04   #8 (permalink)
Spitfire's Avatar
No, Nahi, Non, Nein, Het
Spitfire is offline
Old 21st November 2008, 13:17   #9 (permalink)
Technocrat's Avatar
Seems like he discovered the website a few years late
__________________
The Holy Trinity: Traction, Torque and Tarmac
Technocrat is offline
Old 21st November 2008, 13:30   #10 (permalink)
hillram's Avatar
i checked with a showroom and Comet and aquila are made on order.there is a wait period.
But Comet is an awesome bike..some offered me a 2006 Comet for 90K and i refused.Now i regret.
__________________
Man On Many Wheels
hillram is offline
Old 21st November 2008, 13:35   #11 (permalink)
Are you sure? because i am 99.9% certain that this info is incorrect.
Moreover they were never made here , but imported.
@Mods : shouldn't this thread be closed?
Old 21st November 2008, 13:52   #12 (permalink)
hahahhahahah!
hillram Which showroom ? They never made in India,the bike was imported in small numbers to promote the kinetic brand
Gregory is offline
Old 21st November 2008, 14:59   #13 (permalink)
Technocrat's Avatar
The website is old & no new Comets are getting sold
@hillram: They probably told that because at that time(if it was last year or so else its a lie) they might have had some unsold stock.
Thread Closed
__________________
Closed Thread
Thread Tools
Yamaha RD350 or Kinetic Hyosung Comet 250 ac 427 Motorbikes 47 26th May 2009 19:01
250 kmpl car - made in India !!! bikefreak The Indian Car Scene 19 23rd May 2008 23:45
Transcend Launches 16GB JetFlash V85 In India @ Rs 4,250 nishantgandhi Gadgets, Computers & Software 18 4th April 2008 20:38
Yamaha Fazer 250" and the Honda CBX 250 Twister devil_in_flesh Motorbikes 9 27th November 2007 02:48
Where are the 250+ cc bikes??? sajeeth Motorbikes 2 12th February 2005 19:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
