Old 6th December 2008, 02:29   #1
sreerama's Avatar
Post Cons & Pros of putting 17" front and 18" rear Wheel in Honda Unicorn
Hi i am having unicorn. What will be the advantages &
disadvantages of putting 17" front rim instead of 18" stock one with
18" rear? & how will be the bike if i change both wheels to 17" rim in
case of handling,performance,low end torque etc Just wanted to know
sreerama is offline   Reply With Quote
Old 6th December 2008, 10:39   #2
praJEEP's Avatar
First of all why are you changing to 17" are you too short in height !
praJEEP is offline   Reply With Quote
Old 6th December 2008, 11:43   #3
Sankar's Avatar
Thanked: 4,637 Times
Better options for tyres
Old 6th December 2008, 20:11   #4
sreerama's Avatar
ya planning to put r15 tires. Want to know from experts how the bike will behave using 17" front & 18" rear wheel in mu uni.
Old 6th December 2008, 23:45   #5
Ricci's Avatar
Thanked: 995 Times
Your bike may be slightly lower in front , a little more weight bias in front and the speedometer read more optimistic , but the R-15 tyre being an 80/100 , the difference may not be signifcant vs the thinner 2.75 . Try get a measurement of the 2.75 circumference and the R-15's tyre circumference.
Ricci is offline   Reply With Quote
Old 7th December 2008, 09:47   #6
sreerama's Avatar
R15 tires fit only in 17" rim & they offer excellent dry & wet grip like Michelin. Michelin too have those kind of tires but those are big not suitable for indian bikes.
MRF imported special compound to make this r15 tires for offering excellent wet & dry grip with thin tires.
Old 7th December 2008, 22:03   #7
Technocrat's Avatar
Thanked: 2,589 Times
I am not sure how the front suspension will behave after this change.
Old 8th December 2008, 11:45   #8
praJEEP's Avatar
R-15 rim width is more than unicorn check that out first.
Old 8th December 2008, 11:49   #9
SunnyBoi's Avatar
Thanked: 2,832 Times
no it isnt. R15 has a 1.6x17 rim while a unicorn has a 1.6x18 rim
SunnyBoi is offline   Reply With Quote
Old 8th December 2008, 11:51   #10
msvg's Avatar
Thanked: 15 Times
Any change in rim will bring down mileage.
Only thing that the handling might improve..
msvg is offline   Reply With Quote
Old 8th December 2008, 18:25   #11
sreerama's Avatar
i think apache rtr has 17" front & 18" rear how does it handle?
Old 8th December 2008, 19:31   #12
Technocrat's Avatar
It handles brilliantly but the arrangement is not after market & isa well designed one.
Leather Steering Cover - Pros & Cons mithun Modifications & Accessories 31 12th July 2016 19:23
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Radial Tyres - Pros & Cons mithun Tyre & Alloy wheel Section 51 10th June 2013 12:41
Pros & Cons of low profile tyres? satish_appasani Tyre & Alloy wheel Section 16 17th September 2004 21:39
