Old 8th September 2009, 21:55   #301
Bluu's Avatar
Thanked: 85 Times
Can I replace the stock LB seat with one from the Electra 5S?
Bluu is offline   Reply With Quote
Old 19th September 2009, 15:13   #302
Rennjit's Avatar
Thanked: 77 Times
Default O-ring chain ?
Now at 13K Kms, my electra's chain is due for replacement. Its stretched out making clanky noises. Did cleaning-relubing etc but no use. RE manual also says to replace chain at 12K kms. Ain't O'ring chains supposed to have better life? mine was cleaned-lubed almost every 2 weeks with WD40 / fresh engine oil.
Mechanic known to me suggests non O-ring type chain (for old bullets but same size sprockets) calling it better in terms of life & runs smoother (less stickiness/ rolls free), no noise etc.
Anyone faced this before, suggest which one to go for - O'ring type or regular.
bye.,
Rennjit is offline   Reply With Quote
Old 21st September 2009, 21:27   #303
bmw_m5_titus's Avatar
Originally Posted by niks_devil666 View Post
Has anyone tried to fit a tacho on the bull ?
Nikhil, Renjjit(team-bhp id) had hooked up a tbird tacho to his electra 5s! It was seeing so less action, he didnt make it permanent!
bmw_m5_titus is offline   Reply With Quote
Old 21st September 2009, 22:03   #304
bj96's Avatar
Thanked: 128 Times
Do you carry heavy load/double seating often? Mine is done 12.4k- its not as bad. Didn't you adjust your chain during this 13k run? Try shifting back the rear wheel (it has adjusters and a backing plate) a notch or two- to tighten the chain and see if it is better. I had adjusted my chain around 7K and it still looks ok.
Don't run your bull w/ loose chain for long it could lead to costlier damages. As manual says 12k/chain- it is better to follow that if the bull is your primary mover and runs a lot. You can retain the old as a spare for emergency. Even I am mulling a chain replacement- pls post the MRP if you happen to get your replaced.
Thanks,
-BJ
bj96 is offline   Reply With Quote
Old 28th September 2009, 13:01   #305
magneto's Avatar
Thanked: 46 Times
Default Need information on TCI
I am looking for the wiring diagram of the TCI unit fitted on a Electra , Also does anyone know whether this unit is a AC or a DC unit as i believe that Nippon India makes both these options.
Bye M.
magneto is offline   Reply With Quote
Old 1st October 2009, 12:51   #306
Thanked: 56 Times
hello everyone !
Can i remove the PAV unit from my Std 350 ? will it adversely effect the engine ? what difference would it make though ? I am hungry for more thump, though i have added the RE Retro Bubble silencer/bend pipe :(
been reading this thread from quite some now
shan2129 is offline   Reply With Quote
Old 1st October 2009, 22:26   #307
bj96's Avatar
Thanked: 128 Times
Originally Posted by shan2129 View Post
hello everyone !
It would not affect the engine, but, would certainly affect the exhaust pollution. You may also loose the engine emission warranty- which is warranted for 30k/3yrs by REI. Getting a PUC certificate (by honest means) may be a pain after this or you must run very lean mixture to pass the PUC test.
-BJ
Old 2nd October 2009, 00:31   #308
Thanked: 56 Times
hi !
Thanks for the answer , Is there any side effects other than pollution ? i would certainly like not to polute the air too much.
Is there any +ve effects in removing ?
Another query i have is : I just did my IInd service on 1535 kms ( 3 months from purchase) , and the pick up of the bike & the thump are really low. My bike used to be Thumping great right before the 1st service. But it blurts out air type Thump & not the solid music i used to hear before.
Another thing i am concerned about is the Engine Oil. The RE mech. Mixed two oils, i told him not to but he did, one was very thick ( yellow colored) and the other is Red ( suspected Veedol ) I checked the Oil levels today & it was just on the minmum mark. i tried to check it after riding for 10 mins. but the result was same. The Oil change after the first service was pretty normal, but this one is very thick. I took my bike to a Local mech. and he said that the RE guys used 90 number OIL, i dont know what that is, but am really confused in what to do next ?
Any help would be deeply appreciated.
Sorry for the long post. But I am way too into the Tension part regading my Blaze ( BULL )
Old 4th October 2009, 10:03   #309
Thanked: 1,556 Times
Use only 20w50 oil for ci engined bulls. In all probability, the mech would have mixed castrol crb with veedol. And this isn't a good thing. So drain the oil and pour in new 20w50 oil. If you are checking the oil level after parking the bull for a while, it could indicate a low level due to wetsumping. To avoid this, either park your engine at tdc or chech engine oil 5 minutes after you have come back from a ride. Never mix oils.
Cheers,
Jay
JayPrashanth is offline   Reply With Quote
Old 4th October 2009, 11:23   #310
Thanked: 56 Times
thanks a loy jay for the help ! Should i go with veedol or any other brands ?
How much shoould i pour ? 2.25 ltr. or less ?
Old 4th October 2009, 20:37   #311
taj
taj's Avatar
Thanked: 18 Times
Little bit of deviation from the current flow of thread: Following my decision to own my first Bull, had visited RE showroom at Cochin, tested both TBTS and LB 500, personally i liked TBTS(unlike many fellow BHpian,s) for its riding position and comfort, and decided to go fot it.
I was told that new Model 500cc UC Engine with FI in launching in 3 months and booking starts in a month, price approximately about 1.5L .
taj is offline   Reply With Quote
Old 4th October 2009, 21:13   #312
Taj, they are saying that to all. I was there recently to pick up an LB for a friend. heard it myself. Btw did the saleguys try to promote the TBts over the LB?
And yes, a big congrats! The TBTS is a good ride, with its own merits, though it doesnt have the wild abundant torque of the LB500
Old 4th October 2009, 21:40   #313
navpreet318's Avatar
Thanked: 826 Times
Well i bought the MACH V two days back.probably the final few pieces left.In Alberto Green.
Now the biggest problem i am facing is the seat.the seat base is giving me great discomfort.So what can be done to make the seat better.Can i install the Thunderbird seat?
Or is there any other solution to this problem.
Rest its a marvel.I've sort of rediscovered biking with this bike.Cruising at 30kph with a dug dug sound is the best thing is this world.
navpreet318 is offline   Reply With Quote
Old 4th October 2009, 21:42   #314
cruiser_1982's Avatar
Thanked: 16 Times
@Taj, are you talking about thunderbird 500 CC or Machismo 500 cc?
cruiser_1982 is offline   Reply With Quote
Old 4th October 2009, 21:51   #315
Thanked: 826 Times
^ Machismo 500 UCE is being launched.
The dealer in delhi where i bought my bike from has said that both the Machismo 350 and 500 will be stopped and UCE's will be launched in their place.
Which current RE UCE Bullet to buy? Or should I go for a used CI Bullet? swami69 Motorbikes 77 14th September 2015 17:50
All Bullet Gurus:: Need your Suggestion : Planning to Modify Bullet-Project Wanderer Shubhendra Motorbikes 56 6th October 2014 11:18
HELP: W124 Benz needs some speaker help Screwdriva In-Car Entertainment 20 27th August 2008 10:18
