Old 18th March 2011, 15:19   #16
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 465 Times
Default re: Disc Brakes of 2-Wheelers -Problems & Solutions !!!
Originally Posted by Manoj2268 View Post
Ask for 'minor kit - brake caliper'
Part no. DE 1510 51
It contains the Oil and dust seals, bleeder cap, dust cover and insulator. If you also want to replace the pistons , then ask for 'major kit - brake caliper' (DE 1510 52)
Thanks Manoj. I will start with the Bajaj service centers and see if I can get it from them. If not, I will try my luck at Nanapeth.
pjbiju is offline   Reply With Quote
Old 19th March 2011, 17:45   #17
pjbiju's Avatar
Thanked: 465 Times
Default Re: Disc Brakes of 2-Wheelers -Problems & Solutions !!!
Part no. DE 1510 51
I got the major kit made by KBX for Rs. 180. It came with two cylinders as well. The minor kit cost was ~Rs. 60.
Now to rebuild the caliper.
Old 21st March 2011, 18:53   #18
pjbiju's Avatar
Thanked: 465 Times
I returned the caliper rebuild kit. One of the caliper pistons could not be removed, however hard I tried, with compressed air. So I got the caliper assembly replaced. It cost me Rs. 1100.
Old 21st March 2011, 19:59   #19
georgev's Avatar
Congrats..so you used which caliper assy ? Gladiator ? direct fit ?
georgev is offline   Reply With Quote
Old 21st March 2011, 22:51   #20
Thanked: 54 Times
When the piston gets stuck , just weld an old bolt to the inside of the piston and tap out the bolt so that the piston comes out . My zeus piston got stuck and i did that . Saved almost Rs 2000 . After removing the piston get a 180 grit sand paper and clean the insides and replace the kits .
Old 22nd March 2011, 13:18   #21
pjbiju's Avatar
Thanked: 465 Times
KBX kit for Pulsar. It comes with new brake pads as well.
This is a good idea. Actually I wanted to complete this task over the last weekend. I was finding it extremely difficult to ride the bike without the front brakes. But yes, I could have saved Rs. 800-900 had I followed your advice. Anyway this should help people who have such problems in the future.
Old 26th March 2011, 15:34   #22
Manoj2268's Avatar
Thanked: 94 Times
Or, you could have done one more thing. If the Pistons are stuck inside the calipers, wedge a piece of plywood between the calipers and press the brake lever. The pressure of the brake fluid is more than the compressed air.. The stuck piston will come out slowly and when it's 3/4th out, pull the pistons with a plyer.
I saved nearly 4500 when my karizma's caliper pistons got stuck..
Manoj2268 is online now   Reply With Quote
Old 5th May 2011, 17:26   #23
pulsarmaniac's Avatar
Thanked: 9 Times
I had the same problem with my Pulsar 200 yesterday. I had to go to the nearest roadside mechanic as i had to reach office in time. he just bleeded the fluid, removed and adjusted the brake pads. then he topped the new fluid (I doubt the correct one or even sealed). The front wheel as of now is relatively free but i am yet not comfortable with this. I want to get this fixed properly over the weekend. Please suggest guys. Should i go for the Major kit/Minor kit? Where can i find the kits around Malad, Goregaon West and nearby in Mumbai? Please suggest a good mech if you know any guys
pulsarmaniac is offline   Reply With Quote
Old 6th April 2015, 12:50   #24
saket77's Avatar
Thanked: 5,049 Times
Changed my Stunner's brake pads yesterday. Bought a set of Bybre disc brake pads from Honda ASC and replaced it myself. Though it will take some time to break-in the new pads but the still as of now, the braking power is very good. The printed price for the set was Rs. 482/- but somehow I was billed for Rs. 360/- only.
saket77 is offline   Reply With Quote
Bikes - Anti Lock Braking system on Disc Brakes mail4ajo Motorbikes 10 2nd March 2015 11:40
Mahindra Pik-up 4x4 = Brand new MM540 4x4with front disc brakes & 63HPDI Turbo? Ashley Nair 4x4 Vehicles 31 14th July 2011 12:29
Disc Brakes for Rear Wheel ~ H O N D A ~ Modifications & Accessories 39 24th June 2006 09:50
Disc Brakes - can someone xplain them to me? Shan2nu Technical Stuff 17 9th March 2006 00:08
