Old 23rd January 2009, 18:15   #1
rahulsingh007's Avatar
Thanked: 43 Times
Unhappy Carb Tuning : Help Required
I have and Apache RTR 160 Refresh , June 2008.
The bike was running pretty fine, but 1 day I thought about tuning the Carb and Increasing its efficiency and performance,
but sadly I ended up screwing the carb and even my bike, after some time I took the Initiative to revert the tuning ,
but not I am finding it pretty difficult to tune it right, because the bike gives me jerks at a constant speed (45-50 kmph in 5th gear)
and when I hold the clutch when the bike is running at high speeds 40-50 kmph, the rpm goes down very slowly to 2k and then does not go back till the idle rpm (1200 rpm) .
Please suggest the best way that I can tune the carb and also when i tried tuning via spark plug test method I found out That the ring near the electrode always remains dry black, and thus I am unable to adjust accordingly
Please Help
rahulsingh007 is offline   Reply With Quote
Old 23rd January 2009, 19:00   #2
Jaggu's Avatar
Thanked: 8,670 Times
First tell us what you did, its a CV carb right? Which all settings you adjusted and do you know the original settings (no of turns the screws were set at)?
Old 23rd January 2009, 19:05   #3
invincible7's Avatar
Thanked: 154 Times
Take the bike to the TVS service center, they will set it up for you.
Or write down step by step illustration of what all changes you did when setting (trying to) in the first place.
invincible7 is offline   Reply With Quote
Old 23rd January 2009, 19:12   #4
aaggoswami's Avatar
Thanked: 1,541 Times
If possible, give more details on what you really adjusted.
I think that generally what we are allowed to adjust is the idling screw, but I think you did some other adjustments also.
So now either you go by trial and error method again to solve this problem yourself, or go to dealer to get it fixed. Tell them and explain what you have done. This should solve your problem.
aaggoswami is offline   Reply With Quote
Old 23rd January 2009, 20:01   #5
Awaiting Email Confirmation
Did you note down the changes you made?
Go to the authorized service.
SuperSyn is offline   Reply With Quote
Old 24th January 2009, 11:42   #6
Thanked: 43 Times
I also had adjusted the volume control screw. I think if you can tell me what exctly to read in the spark plug it would help me alot
Old 24th January 2009, 12:29   #7
Thanked: 43 Times
which part of the spark plug to read, good if you can explain with a diagram
Old 24th January 2009, 20:56   #8
it feels like a leak in the inlet ,that is
1)There is a Secondary air injection pipe going from the carb black manifold rubber to a diaphragm pump,see if it cracked or come out.
2)see if the air filter rubber on the carb loose.
3)The stock carb is as good as they come,unless using a fre flow do not fiddle
cheers
EH
venugopal is offline   Reply With Quote
Tuning Box versus Remaps (Diesel tuning) Ravveendrra Modifications & Accessories 154 29th April 2018 22:45
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
K&N Required For A Zen Carb. greddy Modifications & Accessories 11 1st November 2006 16:27
The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box turboindia Modifications & Accessories 108 17th April 2006 12:33
Help required in Tuning Pioneer FH-P4100 shalini_g In-Car Entertainment 6 29th March 2006 11:33
