Old 16th February 2009, 13:23   #1
mithun's Avatar
Thanked: 59 Times
Wink Why the new bikes are not having fuel filter ?
Even in the bikes that were released 10 years ago or more, I've seen fuel filter just after the fuel petcock. But in the new-age bikes there are no fuel filter !
What's the reason behind that ?
Is that because all the petrol in India suddenly became crystal clean ?
Or is it simply to cut costs ?
Old 16th February 2009, 13:29   #2
sai_ace's Avatar
Thanked: 195 Times
The fi bikes do come with a fuel filter. My rtr fi has one. Dont know about the other bikes.
sai_ace is offline   Reply With Quote
Old 16th February 2009, 13:44   #3
mithun's Avatar
Thanked: 59 Times
I'm telling about the carb bikes. The FI bikes are a minuscule of the bike population.
Old 16th February 2009, 20:07   #4
rranjith_kum's Avatar
Thanked: 17 Times
Well I have been sitting with my manual and all the stuffs, I really dont seem to find any info about my bike's fuel filter maybe this leaves me to assume that mine doesn't really use one !!
rranjith_kum is offline   Reply With Quote
Old 17th February 2009, 09:19   #5
bblost's Avatar
Thanked: 6,981 Times
I am not sure but maybe the filter is inside the tank!
Old 17th February 2009, 09:23   #6
DKG
DKG's Avatar
Thanked: 970 Times
I doubt that. Usually its integral in the feed unit which attaches to the tank. Not the traditional filter midway on the fuel feed pipe.
DKG is offline   Reply With Quote
Old 17th February 2009, 09:30   #7
Sankar's Avatar
Thanked: 4,657 Times
The new fuel taps have an integrated fuel filter which can be cleaned by unscrewing a single big bolt at the bottom of the fuel tap. And they have strainers inside the fuel tank too. Even the old taps had strainers inside the tank, new ones must be better.
Old 17th February 2009, 09:30   #8
mithun's Avatar
Thanked: 59 Times
Why is it so ? Does it serve any special purpose ? Or is it simply to save space ?
Old 17th February 2009, 09:38   #9
bblost's Avatar
The old type of filters depend on gravity to do the job.
The dirt particles would settle down to the bottom of the Purcolator (?) and the fuel would flow out of a pipe that is a little higher up in the bottle.
The new ones would have a mesh surrounding the inlet pipe inside the tank.
I once removed this pipe in my Splendour. I don't remember how it was. :(
try the same on your bike and check it out.
Old 17th February 2009, 10:34   #10
The FI bikes typically have an integrated fuel filter and pressure regulator built into one unit.
Now, what about an oil filter? Where would I be able to find the oil filter on my Karizma?
xxaarraa is offline   Reply With Quote
Old 17th February 2009, 10:50   #11
Sankar's Avatar
It doesn't have one!
Karizma has only a oil strainer screen inside the drain bolt!
Old 17th February 2009, 11:37   #12
That's interesting. Any particular reason why? Are most Indian bikes built this way or is the Karizma an oddity?
I am not complaining trust me, makes oil changes that much easier! Twist, drain, refill. That's brilliant! On my other bike, I have to drain, take off half the plastic to get to the oil filter, drain more and then put it all back together. Don't enjoy it.
Old 17th February 2009, 11:58   #13
Ajaybiz's Avatar
Thanked: 148 Times
My old CBZ is having total 3 fuel filter one in gas tank fixed on top of fuel tap, one is to deposit the durt particles at bottom of fuel tap and last one is in fuel line which filters those particles which passes through aboved two filters.
Same setup i am running on my RD's.
Ajaybiz is offline   Reply With Quote
Old 17th February 2009, 12:10   #14
Sankar's Avatar
I don't know the reason for that. Maybe Honda has a great faith in it's engine not shedding large enough metal particles Even the CRF230s don't have oil filter.. same engine.
Many other bikes do have oil filters, Suzuki Fiero, Apache, Caliber, Pulsar etc..
Old 17th February 2009, 14:03   #15
Thanked: 17 Times
Can you name your bike I just dont understand this process and by the way where is your oil filter located !!
In my bike FZ16 the engine oil filter element is located in right side of the engine. Typically the small circular arch with three bolts near the engine oil filling let !! so there was typically no oil that could flow its way from there.
Anna add FZ 16 to the list !!
having a lowprofile tyres higher rimsize Vs having high profile tyres smaller rimsize rider60 Tyre & Alloy wheel Section 26 12th September 2017 23:28
Ikon Fuel Filter : OEM is cheaper than After-Market filter RM2488 Technical Stuff 13 28th June 2012 11:39
Is Oil filter and Fuel filter different? finneyp Technical Stuff 10 25th July 2008 11:45
Why the cars are not having any Reserve ? mithun Technical Stuff 25 1st July 2007 02:17
