| Motorbikes Everything related to the two-wheeled breed. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jul 2008 Location: New Delhi
| Hi folks! Reading on about the amazing things our fellow members do here, I was looking for some concrete information on whether someone (like me :P ) can go about adding something like a Fuel Injection kit to a bike that doesn't have one ? Not that I have any concerns for the average or anything, I love my Kat 600 any day the way it thrills me!! but just wanted to understand if there's a possibility to this, cos there's quite a few times, I have got into carb trouble with this one, and hence, becomes a bit tedious for a novice like me to maintain it with such quirks every now and then..Suggestions welcomed! Cheers. |
| | #2 (permalink) |
| BHPian Join Date: Mar 2006 Location: goa
| As for your first question, it is possible to convert to fuel injection a bit difficult but not impossible. Need to find parts for the bike, like fuel pump,throttle body [available from other suzuki bikes as well as letter model of Katana], injectors, senors and ECU ,I would suggest a after market unit easy to setup and many are used on this type of setups. If your thinking of converting to injection just because of carb problems than please let us know the problem. there may be solutions to your problems. Last edited by dinar : 18th March 2009 at 18:26. |
| | #5 (permalink) | |
| Quote:
Not quite positives towards such an attempt I see.. Well, as for the problems, I'm not able to understand very clearly myself what the issue is, and even when I've got to fix that it is due to that, I'm not very technical to get into fixing all that myself. More or less, it's about the proper sized jets, carb cleaning, synchro of all 4, analyzing and rubber cap and float status and replacing / fixing them if needed.. If you know some one in Delhi who can actually do this, lemme know.. ![]() Cheers, J. | |
| | #6 (permalink) | |
| BHPian Join Date: Aug 2006 Location: New Delhi
| Quote:
That amounts to designing and fabricating a generation engine! Give it an analysis yourself. Cheers. | |
| | #7 (permalink) |
| BHPian Join Date: Nov 2007 Location: Lot of places
| No can't do. FI is not a plug and play component, it is many pieces in a large puzzle that a bike designed for carbs is entirely unsuited for.
__________________ Ducati Monster S2R1000 - BMW F650CS - Karizma - Yezdi - RX-100 |
| | #8 (permalink) | |
| Quote:
So you are getting it done from someone and you are not satisfied with the work, right. As for a mechanic in Delhi, members from north will be able to help you, I have no idea of this my friend. By the way if you want to get the FI thingy, it's doable. I have seen old BMWs, suzukis and kawasakis getting converted to FI. Hunt the net and you'll get a lot of such stories. One should know what is needed to do this job that's it. Last edited by dinar : 19th March 2009 at 00:21. | |
| | #9 (permalink) | |
| Quote:
I have the manual with me, as well as a toolkit, but not the in-depth knowledge or maybe heart to get into it myself.. :P anyways, thanks.. and good luck on yr project too..! ![]() | |
| Thread Tools | |
Similar Threads | ||||
| A Comparison of (Fuel/Oil/Engine) Additives vs Manual Decarbonization | ibm_jennifer | Accessory/Part Reviews | 141 | 1st August 2009 10:06 |
| PROJECT: Hybrid Add-on Kit For Scooter. | SRK | Motorbikes | 30 | 8th March 2009 18:51 |
| Getz with K&N FIPK (Fuel Injection Performance Kit) | sam_786 | Modifications & Accessories | 23 | 24th December 2008 18:13 |
| Sequential injection LPG kit | ask77 | Technical Stuff | 2 | 20th November 2008 10:13 |
| Carb or Fuel Injection ? | shuvc | Hatchbacks | 4 | 1st July 2007 18:00 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
