Old 20th March 2009, 17:17   #16
jango's Avatar
Thanked: 19 Times
Post
But the fact here is that in most hill stations at least in S.India ( Ooty and Kodai ) i have mostly seen Max-100's, bullet 350's and Rx-100's. Have hardly seen ZMA's but have seen more of Splendors.l
Just my observations !!
jango is offline   Reply With Quote
Old 20th March 2009, 18:31   #17
bigron's Avatar
Thanked: 314 Times
In as much as the bullet suits your requirement.I suggest you avoid it solely on the ground that is is a heavy bike and a little cumbersome at steep and sharp turns.But again if you are comfortable with the weight my all means go for it.
bigron is offline   Reply With Quote
Old 20th March 2009, 18:57   #18
kannan666's Avatar
Thanked: 70 Times
Don't think the stance of a sports bike will suit for a ride in the hillstations ! What do you guys think ? I'd still stick with the RE Bullet although it can be quite a handfull on steep and sharp turns like fellow bhpian bigron suggests ! And once you suffer a puncture, be ready for some real good exercise !
Did someone suggest an RX100 here ? I'd go for that anyday......
kannan666 is offline   Reply With Quote
Old 20th March 2009, 19:08   #19
Sankar's Avatar
Thanked: 4,656 Times
I'm assuming you're more of an enthusiast than a commuter:
If you're going to have to go up and down the ghats you need good brakes as well! It's as important as the torque you need. Go for a AVL 500, it has good torque, front disk brake and can take the rough, meaning no plastic panels to rattle your brains out. The sprag clutch is a known issue and new AVL500s are supposedly coming with a new ignition with delay circuit which eliminates the sprag clutch breakages.
Karizma is good, very good in every sense except the body plastic; that shouldn't be a problem if you're not going to really rough it up. Riding position is also relaxed, but at the same time good enough for some thrills.
Stock Bullet CI 350 does not have enough torque to conquer the hills if you are into spirited riding. And it will take a bit too many gearshifts compared to a 500 Cast iron or AVL.
Old 20th March 2009, 19:14   #20
Thanked: 253 Times
SX4, I believe you are looking for a Karizma!
But if you enjoy playing grease-monkey, it'll have to be a Bullet!
Old 20th March 2009, 19:19   #21
vivekiny2k's Avatar
Thanked: 184 Times
1.5 L and nobody is suggesting imports? I can see the original poster devastated.
vivekiny2k is offline   Reply With Quote
Old 20th March 2009, 19:27   #22
Thanked: 253 Times
Because he wants to use it in the hills. Tumbles, water crossings and bad roads will be part of the package. He should not have to pawn his house for repairs to the bike!
Old 20th March 2009, 20:28   #23
Would have suggested TVS RTR, but seating position for tall people is not very confortable and it likes only highway kind of roads.
Karizma/ P220 should be ur best bet.
katpasin is offline   Reply With Quote
Old 20th March 2009, 21:27   #24
Thanked: 68 Times
and 5 overhauls?
Having seen sprag clutch problems with atleast 4 bikes I saw personally, I don't trust RE
Buy only if any friend of yours has bought recently and NOT had sprag clutch issues.
One got to be lousiest driver, for a bullet to have 5 overhauls in 20years.
Buddy, I own a 500 CI engined Bullet for 5 years and done about 40k KMs. Never had the clutch problem that you mentioned. Nor do scores of bullets running on roads for decades. Give advise based on your personal experience, not based on hearsay.
-Vaspro
vaspro is offline   Reply With Quote
Old 20th March 2009, 22:29   #25
streetrage911's Avatar
-Vaspro
I totally agree what vaspro has said. There are no clutch problems with REs. And a TBTS is pretty confortable too for hills.
streetrage911 is offline   Reply With Quote
Old 21st March 2009, 01:04   #26
phamilyman's Avatar
Thanked: 3,526 Times
-Vaspro
Now now despite me saying about my own friends - you assume my post is based on hearsay. Either you neglect to read, or you don't care to understand. Let me lay it out in black and white - I have helped personally a friend to get his 500LB returned to RE, and get full money back. And he had issues from 8k km onwards, 5 replacements till he sent it back at 18k km in ten months only!! I'm not a bullet hater boy - just someone whose seen the crap firsthand.
My post is ambiguous yes - yeah the 500CI was awesome, but I've seen enough crap on the 500LBs, so excuse moi while I spread the good word.
And FWIW, the sprag clutch issue is endemic with the initial 500LBs, not the CIs. Since you refuse to acknowledge fact, let's use Google?
Here we go:
Bullet Machismo 500 LB Pictorial Review | Vicky blog | Indian Automobile blog - "The sprag clutch (part no 560011/A) in the electric start system is getting faulty very frequently. 3 times in first 1700 kms!!"
http://www.team-bhp.com/forum/motorb...ml#post1095851 (New Bullet Fan Needs Help!)
http://www.team-bhp.com/forum/motorb...ml#post1096253 (New Bullet Fan Needs Help!)
Royal Enfield Machismo 500 review - Page 5 - India Travel Forum, BCMTouring.com
Old 21st March 2009, 01:36   #27
akshay4587's Avatar
Thanked: 1,686 Times
1.5L would fetch him a 15+ year old 400 may be
do you think its worth the pain?
Old 21st March 2009, 06:12   #28
straight6's Avatar
Thanked: 118 Times
1.5L will get him a crap import. Don't even bother.
straight6 is offline   Reply With Quote
Old 22nd March 2009, 22:49   #29
SX4
Thanx for the advice guys...think i should stick to the bullet 500
SX4 is offline   Reply With Quote
Info required: Kolli malai - small hill station subbusos Route / Travel Queries 29 27th August 2016 11:16
Kodaikanal - The last unspoilt hill station.....so far ajmat Travelogues 29 5th July 2012 19:52
Delhi-Badrinath-Kedarnath-Hill Station-Delhi - Possible in 7 Days? ashthedivx Route / Travel Queries 30 20th May 2010 20:53
All Bangalore bhpians plan for may 1st and 2nd trip to hill station or beach rocky080 The Team-BHP Meet Section 86 3rd May 2010 14:06
Off to cure my sins, visitng a hanging bridge and a 7000 feet hill station snaronikar Travelogues 45 9th June 2009 22:20
