Old 14th January 2013, 12:41   #151
ashis89's Avatar
Thanked: 1,352 Times
Default Re: Upgrade Headlight lamp on Bike
Originally Posted by knaveen View Post
Finally changed the bulb to Philips xtreme - vision. Got it for Rs.500 from GP road. Changed the pilot lamps to LEDs.
Have to test it tonight. The only issue till now is that when the headlamp is on and the bike is in idle, the battery indicator starts to blink after a couple of minutes. Have to switch it off on signals i guess. Apart from this no issues.
I changed the stock bulb with Osram NBs 60/55W on saturday. Went on a trip to Mysore and back yesterday. Used the low-beam mostly and was happy but it needs a little focusing.
Can you let me know the brand,price and details of the LEDs? I would like to upgrade the same to save some power.
ashis89 is offline   Reply With Quote
Old 14th January 2013, 13:05   #152
Thanked: 87 Times
The ones i changed were cheap chinese ones. They cost 100 a pair and have 5 LEDs per unit. They are direct fit inplace of the existing pilot lamps on my bike. There are expensive options available with more number of SMD LEDs, the max i saw was 18 per unit. They are available in either white or blue. Check if the color output of your HL matches with these LEDs, else it might look a bit odd like it does on mine
knaveen is offline   (1) Thanks Reply With Quote
Old 14th January 2013, 15:54   #153
ashwin.terminat's Avatar
Thanked: 1,310 Times
Originally Posted by hrman View Post
There were a couple of days when it was really cold in winter, I took out the scooter early in the morning, and it would stop if the accelerator did not give any input. I thought it would be because of the higher wattage lamp, which made the battery die down. But haven't faced the issue since. Even when I gave it for servicing a couple of days back, he did not report any problem.
Going from the bold parts, I guess there's no need to upgrade. Seems more like a cold start issue. Try warming up the bike in the mornings before you start moving for a minute or so. You can do this by just leaving the bike on idle with the choke pulled for a minute or so. I doubt you should have the problem after that.
ashwin.terminat is offline   Reply With Quote
Old 14th January 2013, 20:43   #154
sagarpadaki's Avatar
Thanked: 1,337 Times
I replaced the stock bulb on my TVS Wego with the Philips Xtreme 60/55 H4 bulb from my car. No changes done to any electricals whatsoever.
Now the throw in low beam is superb and quite wide and bright for a Scooter. I try not to go on high beam as this is extra bright and may end up blinding motorists.
I am on the stock battery which was 4 amp i guess. There were a couple of days when it was really cold in winter, I took out the scooter early in the morning, and it would stop if the accelerator did not give any input. I thought it would be because of the higher wattage lamp, which made the battery die down. But haven't faced the issue since. Even when I gave it for servicing a couple of days back, he did not report any problem.
Is there a need to go for a higher rated battery or a relay? My scooter was bought in April 2011. The replacement was done at the TVS service station itself. My two year warranty expires in April 2013.
Since Wego is not fully DC, i dont think its deriving power directly from battery. So its drawing power from the alternator. BTW i thought wego has 9Ampere battery. Can you check your manual.If battery is indeed 4A then upgrading to 9A does not make sense because it will take long time to charge it!
No need for relay et all. Stock wiring can handle +20W of power easily.
sagarpadaki is online now   Reply With Quote
Old 14th January 2013, 22:36   #155
Thanked: 87 Times
Attaching pics of the new HL.
Old 17th January 2013, 20:14   #156
Schoudhury's Avatar
Thanked: 470 Times
Guys
I was checking the manual of my pulsar, and looks like the headlight bulb is a H7 bulb, so looks like i cant fit the h4 bulb from my car on to my bike.
So does it mean I need to buy a H7 bulb for the same.
Please advise.
Schoudhury is offline   Reply With Quote
Old 17th January 2013, 20:35   #157
ku69rd's Avatar
Thanked: 1,230 Times
Originally Posted by Schoudhury View Post
Guys
Please advise.
Sir,
Why are you not exploring the option of upgrading it to the projector headlight similar to that of 220P. It has a good spread and quite powerful. Have a check on it before you want to explore anything else.
ku69rd is offline   Reply With Quote
Old 18th January 2013, 08:13   #158
Schoudhury's Avatar
Thanked: 470 Times
Originally Posted by ku69rd View Post
Sir,
Can we fit the projector of 220 in pulsar old gen 200 ?
I basically wanted something better than the present headlights.
Let me see if we can do that.
Thanks Maheshji
Old 18th January 2013, 08:40   #159
Thanks Maheshji
Old gen 200 uses a H7 lamp? I dont think so. Because, it has both high and low beam in a single bulb. It has to be H4. Can you verify?
Old 18th January 2013, 11:42   #160
mashmash's Avatar
Thanked: 125 Times
Thanks Maheshji
Sure you can. I have a P220 projector fitted in a Fiero with stock electrical. I want to now increase the power rating by doing the works at Ruby. Unfortunately, have not been able to find the time to go visit them.
I want to change the whole electrical system in the Fiero and upgrade it to RTR system. Anyone done this? How long would it take? Would like to have a little idea before I visit Ruby.
MaSh
mashmash is offline   Reply With Quote
Old 18th January 2013, 11:42   #161
Schoudhury's Avatar
Thanked: 470 Times
Yup, i was also surprised to see the same in the manual itself.
Can any of pulsar owner check the same in their booklets also and confirm.
Old 18th January 2013, 12:14   #162
ku69rd's Avatar
Thanks Maheshji
Sirji,
Absolutely no hassles in getting them fitted. Since they both are from the same stable it should be a seamless shift except for some damage to your wallet.
This would be a worthwhile exercise if you plan to keep the bike for long else not worth spending that much on it.
Am not quite sure on the lighting coils in Bajaj, else you might want to upgrade the lighting coil and fit a 55/60 or even better go in for those 90/100 head light bulbs. Bulbs might not be an expensive affair and coils would be a one time investment. Not sure if the reflector can hold up to the heat though which needs some citation.
All the best and please do post some snaps of your bike in your garage
Old 19th January 2013, 01:29   #163
sajjt's Avatar
Thanked: 97 Times
Sirji,
Its not a direct snap on transformation like you think. Separate brackets has to be fabricated and welded to accomodate the 220's fairing. Above all P220 has got a meaty 200W 3phase alternator to support the 55W twin pods whereas the 200 has got only 130W single phase alternator. On lower rpms battery drain will be the biggest issue. Another catch will be the conflicts with the BCU for the extra load which I doubt. It may not turnout to be a worthy effort.
Assume that your bike is UG4 which is DC lighting. Try with a 55/60W on the stock reflector and observe its supporting without any battery drain and BCU issues for a few days and then go with the upgrade. My 2 cents.
sajjt is offline   Reply With Quote
Old 26th January 2013, 19:33   #164
vikash49's Avatar
Thanked: 442 Times
Smile DIY Headlamp upgrade on TVS Wego!
Last year I had upgraded the stock Headlamp Bulb (H4 55w/60w) on my CBR250R to a Philips Crystal Vision H4 55w/60w.
Name:  Xtreme vision1.jpg
So the OEM bulb from the CBR (Philips H4 55w/60w, made in Germany) was still lying with me.
Today being a holiday, I was home and had time to kill on my hands, so decided to plonk the 55w/60w bulb into my one month old TVS Wego
The OEM bulb on the Wego is Halonix HS1 35w/35w which is a PX43T socket.
Name:  OEM Halonix HS1 35w35.jpg
The bulb i intended to replace this with was an H4, which is a P43T socket. But, the good news is that, a PX43T socket can also accept a P43T socket bulb! So, you can use an H4 bulb on a HS1 socket, but cannot use a HS1 buld on a H4 socket.
Opening up six screws with a philips head screwdriver, and you can pull out the headlight console..
Name:  Open Headlight console.jpg
Replace the bulb and screw everything back into place..
Name:  Philips H4 55w60.jpg
Thats it. Done!
I did the headlamp change in the afternoon, hence could not click before after pics to show a true comparision.
Though this is an apples to oranges comparision, I did a comparo with a neighbours 2yr old honda activa equipped with a Halonix 35w/35w halogen bulb. See for yourself...
Back alley (no light)
Name:  No Lights.jpg
Activa OEM 35w low beam
Name:  Activa low beam.jpg
Wego 55w H4 low beam
Name:  Wego low beam.jpg
Activa OEM 35w High beam
Name:  Activa ligh beam.jpg
Wego 55w H4 High beam
Name:  Wego high beam.jpg
Only cause of concern is that, I'm not too sure whether the skinny bulb connector / low gauge wiring will be able to handle the additional 20watts of current in the long run.
Name:  bulb connector.jpg
So, overall..
+ 10mins DIY job that cost me nothing!
+ two fold increase in headlight intensity & spread!
+ The illumination can now rivall that of my CBR250!
So far, I'm loving it!
vikash49 is offline   (1) Thanks Reply With Quote
Old 26th January 2013, 20:32   #165
hrman's Avatar
Thanked: 435 Times
Default Re: DIY Headlamp upgrade on TVS Wego!
Even I found the original lamps of the Wego are a dud. I upgraded to Philips Xtreme Power 80%. I share your concern on the wire. I've been running it for over three months, sparingly used during night time driving. So far so good.
hrman is offline   Reply With Quote
Honda Activa DIY: Headlight upgrade and LEDs for indicators + tail lamps a4anurag Motorbikes 13 11th February 2018 10:36
DIY: Honda Activa Headlight Upgrade autocrat Motorbikes 20 28th February 2017 00:06
Headlight Upgrade for Bajaj Pulsar 150 DTSi ankushmulay Motorbikes 73 6th March 2013 21:32
Headlight Upgrade for Avenger 180cc manishalive Motorbikes 2 13th October 2010 18:20
Headlight Upgrade for our 1998 Cielo GLX VSG12777 Modifications & Accessories 2 13th April 2009 10:33
