Old 22nd June 2014, 17:31   #226
Default Re: Upgrade Headlight lamp on Bike
Thank you for your help. I could not find any details regarding headlight/holder. Kindly check the attachment.
Tomorrow, I will check the bulb/holder and let you know, what's written on it.
tavakari is offline   Reply With Quote
Old 22nd June 2014, 20:47   #227
Thanked: 14,596 Times
The bulbs holder is P43t. You try any H4 bulbs as an upgrade. I will suggest Philips Xtreme Vision 60/55W.
Anurag.
a4anurag is online now   Reply With Quote
Old 22nd June 2014, 22:18   #228
audioholic's Avatar
Thanked: 6,107 Times
Those specs wont hold good now since you have converted the entire setup to 12V. What about the headlights?
Unless the headlamp assembly is changed or retrofitted with a different reflector, the bulb type isnt P43t(HS1). I would be surprised if it was even S2, found on some gearless bikes of the past. It will be S1 which was available in 25/25w category. Also unless the alternator capacity has been increased rather than just rewinding it to 12V, there is no way a 60/55w bulb can be run satisfactorily.
audioholic is offline   Reply With Quote
Old 24th June 2014, 15:03   #229
Any idea, how to increase the alternator capacity?
Old 24th June 2014, 16:44   #230
audioholic's Avatar
When the alternator is rewound, the coils should be wound as to increase thr current capacity along with a regulator upgrade if necessary. This is the first requirement. Next the battery will also be upgraded to a higher rating. Enquire with the mechanic if the alternator winding will be fine in its current state for a powerful headlamp.
Old 25th August 2014, 20:32   #231
ashis89's Avatar
Thanked: 1,350 Times
Default Headlamp upgrade for an Activa: Suggestions please
Originally Posted by vikash49 View Post
Today being a holiday, I was home and had time to kill on my hands, so decided to plonk the 55w/60w bulb into my one month old TVS Wego
+ 10mins DIY job that cost me nothing!
+ two fold increase in headlight intensity & spread!
+ The illumination can now rivall that of my CBR250!
So far, I'm loving it!
Originally Posted by hrman View Post
Even I found the original lamps of the Wego are a dud. I upgraded to Philips Xtreme Power 80%. I share your concern on the wire. I've been running it for over three months, sparingly used during night time driving. So far so good.
How is the 55/60 setup on the Wego? Any side-effects or problems faced?
I am facing the same problem with my Activa. The headlight has been woefully dim. Since it was used very rarely (3.5k kms in 2.8 yrs), I never bothered to upgrade. Off late I have been using it more frequently and find the need for an upgrade. I feel like a blind man while riding it at night, especially coming from the 60/55W NBs on my Pulsar.
Should I upgrade the bulb to a higher rating one or just get a better bulb (XV/NB) of the stock rating? Anyone who has done similar change on an Activa?
ashis89 is offline   Reply With Quote
Old 25th August 2014, 21:33   #232
hrman's Avatar
Thanked: 435 Times
Default Re: Headlamp upgrade for an Activa: Suggestions please
55/60 Xtreme setup is running fine on my Wego. Been over a year and half I think. Cant see any after effects.
hrman is offline   (1) Thanks Reply With Quote
Old 26th September 2014, 07:51   #233
motomaverick's Avatar
Thanked: 868 Times
Hello folks, I am back into the world of biking and its associated modification. I got myself a pre-worshipped Bajaj Pulsar 150 DTSi UG2. Now what I want to know is where do I get the Electricals converted to DC? Is ruby Electricals still there with Kennedy at the helm?
Old 29th November 2014, 23:32   #234
Kappa's Avatar
Thanked: 16 Times
Hi guys!
I have an old Honda Activa which has a stock 35W Halonix headlamp bulb. Because of less visibility, I wish to upgrade it to a 55W bulb. I have a spare 55W Halonix H4 with me but the problem is that the new bulb does not fit in housing of the Activa's assembly. Please help.
Thanks!
Kappa is offline   Reply With Quote
Old 30th November 2014, 23:45   #235
Ricci's Avatar
Thanked: 995 Times
^you may need to file the prongs of the bulb a little. But a 60/55W bulb in an Activa may not work efficiently, the system is AC and I don't know how much power the alternator makes. Most 2 wheelers with 35W bulbs don't run 60W ones well without increasing electrical power output.
Ricci is offline   Reply With Quote
Old 1st December 2014, 00:35   #236
audioholic's Avatar
Originally Posted by Kappa View Post
Hi guys!
Thanks!
No technically sound option for that bulb type. H4 will never fit in that holder which is meant for S bulbs. Even if you shoehorn a H4 bulb the reflector will not focus the light properly since the location of the bulb filament in S1 bulb on your activa will he different from H4 you will install. Upon all these, the alternator will not provide the kind of power the 55W will need either.
I am sorry I don't have a solution, but this one again doesn't look like a solution to the problem.
Old 1st December 2014, 20:54   #237
Kappa's Avatar
Thanked: 16 Times
Is there a way with which I can connect the headlamp directly to the battery instead of the alternator?
Old 3rd December 2014, 21:10   #238
audioholic's Avatar
Yes. Can be done but thats with a relay and related circuitry. Direct connection can be done but not advisable.
Old 4th December 2014, 09:02   #239
Thanked: 659 Times
Xbhp has a long running thread that should answer all your questions, including on Ruby electricals.
Motard_Blr is offline   Reply With Quote
Old 4th December 2014, 12:22   #240
sushrutha's Avatar
Thanked: 325 Times
Ruby electricals is still there at the same place & Kennedy has moved to Marathally itseems.
I along with my friend have installed Hid with FX-R projectors in my Pulsar.
Rewinding was done at Ruby Electricals & have put APE(3 wheeler) Rectifier and converted the bike to DC.
Honda Activa DIY: Headlight upgrade and LEDs for indicators + tail lamps a4anurag Motorbikes 13 11th February 2018 10:36
DIY: Honda Activa Headlight Upgrade autocrat Motorbikes 20 28th February 2017 00:06
Headlight Upgrade for Bajaj Pulsar 150 DTSi ankushmulay Motorbikes 73 6th March 2013 21:32
Headlight Upgrade for Avenger 180cc manishalive Motorbikes 2 13th October 2010 18:20
Headlight Upgrade for our 1998 Cielo GLX VSG12777 Modifications & Accessories 2 13th April 2009 10:33
