Old 3rd May 2009, 22:04   #76
powertwin's Avatar
Thanked: 154 Times
Exclamation
Originally Posted by siddartha View Post
hey everybody , puttin up a pic of some of the parts that i need for the engine rebuild. hey trammway thanks a lot for offering the help , please have a look these parts.
part no 1
part no. 2 :
part no.3
part no 4 :
part no 5 :
part no 6&7 : engine mounting rubbers/beddings.
other than these i need the following :
1 set of rings
5 carb inlet manifold.
6 front brake master and wheel cylinder kits
7 set of all cables
8 set of indicators
11 brake pads
In the above list :
I can give you my spare Rings set ( Nippon / Enfeild' O.E)
Indicators, inlet manifold..............have to check with my friend.
Brake pads.........Brembo is difficult to source ( bit expensive to!!)
some Indian make,think we can.
cheers!!
powertwin is offline   Reply With Quote
Old 3rd May 2009, 22:25   #77
powertwin's Avatar
Thanked: 154 Times
part no 1 : engine/ crankshaft bearings.
part no. 2 : gear selector shaft.
part no.3 : kicker shaft
part no 4 : gear "push " rod.
part no 5 : first gear cog
1 set of rings
2 gudegeon pin
3 packing kit
4 oil seals
7 set of all cables
8 set of indicators
9 gear palls and spring.
10 "dx" model side panels and rear mudguard.
11 brake pads
i know this is a huge list of mostly non existant parts . i will be happy find atleast some of the above parts with everybody's help. what i dont find i will make do with what ever i already have.
Some O.E's & Some alternatives:
1) Do not ask for Fury crank bearings.....just take the sample to the Exclusive
Bearing retail shop ( at Chennai or Mumbai)ask them, sure its available in "Swedan SKF",but may not be readily availble,....order and get it.
2) Stuffs like Packing kit ,has to be made
3) Reg Oil seals..............get as per sample from decent " Industrial Oil seal dealars"
4) Cables.............easy to find substiutes from the new gen bikes
5) If you need master cylnder washers & caliper washers,......that too get it from "Oil seal & O ring" dealars.
Other parts.....as on date...no idea,let me try.
ps: Confirm me......pm me
Old 18th May 2009, 17:47   #78
siddartha's Avatar
Thanked: 23 Times
hey powertwin , what indicators are you using on your bike , are they shogun indicators?
siddartha is offline   Reply With Quote
Old 19th May 2009, 15:14   #79
powertwin's Avatar
Thanked: 154 Times
it is "Shogan" Trafficators, where you see in the pics posted here !!!
but I have the original indicators
Old 19th May 2009, 18:55   #80
siddartha's Avatar
Thanked: 23 Times
list of parts found/ procured after lots of searching.
1.packing kit
2. piston rings ( 2 sets)
3. all oil seals.
4. bearings for both ends of the con rod.
5. carb inlet manifold.
6.foot pegs
7. dx side panels
8 "magura" master cylinder.
9. headlight/indicators combinations switches.
10.ignition coil.
11. front sprocket.
12.clutch plates
13. engine mounting rubbers/beddings.
14. gear "push" rod
15. kicker shaft
16. gear selector shaft.
17 . connecting rod.
one very critical component still not found: 1 gear cog.
Old 19th May 2009, 20:11   #81
powertwin's Avatar
Thanked: 154 Times
@ Sid :Have a look at the Fury's indicators ( which i hold in my hand)
Just for comparision, have also posted "Shogan's indicator light also"( seen fitted in my Fury)
Congrats,for sourcing so many parts !!! was it from a "FURY DONOR" or from a gentleman from Bangy ( sorry ,couldnt recollect his name) ??
Old 19th May 2009, 20:17   #82
siddartha's Avatar
Thanked: 23 Times
@powertwin: none of the parts are from a "donor" fury. managed to get parts from 3 different sources , may be one of them is the same person you are talking abt. i dont know.
do you have extra set of indicators?
Old 19th May 2009, 21:17   #83
Hi
These are standard ULO indicators, Zundapp used them on pretty much every model fitted with indicators (except for K80, KS 80 Super and KS 80 Sport). Widely and cheaply available in Germany
Kind regards.....
Thanh
Thanh-BKK is offline   Reply With Quote
Old 20th May 2009, 12:55   #84
siddartha's Avatar
Thanked: 23 Times
Originally Posted by Thanh-BKK View Post
Hi
Kind regards.....
Thanh
now i will have to find friends / make friends in germany.
Old 20th May 2009, 13:41   #85
Hi
All you need is E-Bay and a PayPal account.... have a look:
http://cgi.ebay.de/4-Stueck-Zuendapp-CS-50-KS-50-80-Blinker-530-16-768-6-V_W0QQitemZ330267891500QQcmdZViewItemQQptZMotorrad _Kraftradteile?hash=item330267891500&_trksid=p3286 .c0.m14&_trkparms=72%3A1229|66%3A2|65%3A12|39%3A1| 240%3A1318|301%3A1|293%3A1|294%3A50
http://cgi.ebay.de/Zuendapp-Blinker-CS-GTS-KS-Hai-50-80-125-175-517-529-530_W0QQitemZ400049986513QQcmdZViewItemQQptZMotorr ad_Kraftradteile?hash=item400049986513&_trksid=p32 86.c0.m14&_trkparms=72%3A1229|66%3A2|65%3A12|39%3A 1|240%3A1318|301%3A1|293%3A1|294%3A50
http://cgi.ebay.de/Zuendapp-Blinker-6V_W0QQitemZ270376427074QQcmdZViewItemQQptZMotorra d_Kraftradteile?hash=item270376427074&_trksid=p328 6.c0.m14&_trkparms=72%3A1229|66%3A2|65%3A12|39%3A1 |240%3A1318|301%3A0|293%3A1|294%3A50
With kind regards....
Thanh
Old 22nd May 2009, 20:49   #86
powertwin's Avatar
Thanked: 154 Times
Sorry, No extras !!!
Let me try with a friend at Kerala (He has 1 or 2 sets, will ask him,wether he is ready to part it )
Old 2nd June 2009, 17:38   #87
sandeepm's Avatar
Hmmm.. pretty lucky to find all these parts. Hope they were genuine... especially the selector shaft..
I also got a bunch of parts for my bike from Delhi, Coimbi and Blr.. but many turned out to be fake.. waste of money :(
Repurchased most, but still havent got a kick lever spring..
who's doing up the bike? Mine is with R in Kmangala.. (and is going to be buried there I think
Sandeep
1.packing kit
3. all oil seals.
6.foot pegs
7. dx side panels
10.ignition coil.
11. front sprocket.
12.clutch plates
14. gear "push" rod
15. kicker shaft
sandeepm is offline   Reply With Quote
Old 2nd June 2009, 18:45   #88
Hi
The kick lever spring is identical to the one in the Explorer, in case it is easier for you to find one such. Indeed the kick starter itself, while not identical in looks, will fit just fine. The kick starter on my KS 175 broke twice and each time, during the time it took to have it welded, i temporarily replaced it with one from a C50 Sport, worked just fine.
Kind regards.
Thanh
Old 3rd June 2009, 17:31   #89
sandeepm's Avatar
Hi Thanh,
Actually I did get the explorer spring. But it seems to be weaker than the KS175 ... the return is pretty limp and I suspect it wont last long..
Hence the search for the Fury spring..
Sandeep
Hi
Kind regards.
Thanh
Old 3rd June 2009, 20:11   #90
Hi
Actually the springs are indeed identical, same part number in Zundapp part catalogue. I have practical experience, as mentioned it happened to me before - the entire kick starter assembly from the Explorer (Zundapp CS 50) can be used on the Fury (Zundapp KS 175). Actually pretty much all Zundapp models with the pushrod gearboxes and 3 to 5 gears use identical kick starters and springs, only the rear plate differs between some of the older models (old Sport Combinette and Falconette with fan cooling), anything from type 517 (late 60's) onward is identical right to the last 1984 GTS 50 five-speed (type 529). That of course includes the KS 100, KS 125 and KS 175 in all versions and others where such engine was used (GS and MC models, Laverda LZ 125).
You may need to wind the spring one more turn which is a little tricky as the spring loves to slip out of the retainer (correct word..?) on the rear plate. I don't know how to correctly explain in English. I often spend considerable time getting that spring in there as i had to change kick starters on customer's mopeds quite often. Wear some sort of goggles when handling that spring, if it does come out it does so fiercely
Kind regards.....
Thanh
Restoring my Enfield Fury DX 175 aruncheloor Motorbikes 25 5th September 2017 17:16
Pics for bike lovers - RX 100 - Fury 175 GPX - XL1200 N Nightster - CBR 1000R gthang Superbikes & Imports 29 9th July 2010 09:41
Help required: Restoring my 1972 FIAT 1100D wartikars Post-War 22 11th March 2010 22:15
Restoring my college mate 1991 Enfield 500CC sreejeshmp Motorbikes 5 1st December 2009 21:25
Help needed in Restoring a Royal Enfield "ENSIGN" dharan2786 Post-War 1 26th March 2009 03:37
