| Motorbikes Everything related to the two-wheeled breed. |
| | LinkBack | Thread Tools |
| | #62 (permalink) |
| BHPian Join Date: Jun 2006 Location: kottayam
| Joel, thanks for the info! Is this available at the tvs showroom? Because the one seen in tvs showroom is common one for samurai and shogun without separate pulsar/ pick up coil. Moreover, the parts manual doesnt list any ignition setup with a separate pick up/pulsar coil. Where else is india nippon kit available? where can it be sourced in Bangalore? Cost? Does the kit include flywheel? Is the pick up coil internal or external to the flywheel magnet?
__________________ YOU CAN HAVE ANY COLOR AS LONG AS IT IS BLACK! 04 Pulsar 180 Dtsi - 2wheels Need 4 more! Which one? Last edited by bmw_m5_titus : 26th May 2009 at 13:28. |
| | #63 (permalink) |
| BHPian Join Date: Mar 2005 Location: bangalore
| The pick-up is adjustable with a kidney-slot and its mostly external if I remember right. Ok, now I'm taking about special Nippon rally kits which were used for racing. Also there were some special kits meant for factory bikes. They are not available anymore, but you can check with a few rallyists if they have one. Ravi Nagesh also used to make kits for the Shogun once upon a time with 100/90 coil and an external coil. Just figure out if you can do something on your own locally.
__________________ There is more to life than incresing its speed! |
| | #64 (permalink) | |
| BHPian Join Date: Feb 2009 Location: Coc, Cbe
| Quote:
Any news on Shoguns running Rx Cdi? I'm going to try next. | |
| | #66 (permalink) |
| well, my Ax200 is back with few specs changed to Crank setup: 90 degree. Ignition: coil plate with 2 primary coils + 2 CDIs & rest. Exhaust: Twin pipes. From the first ride it feels relaxed than previous 180 crank. Seemingly lacks the punch factor of earlier.Hope rides next days would reveal the actual. I had been thinking too wild on the Ignition system, wanting to adapt some better Tvs-suzuki setup. however the possibilities ran too complex & i just went with the initial plan of adding a primary coil offset by 90degrees on plate. Minor corrections & it fired up by 2-3 kicks. It is always better keeping it simple & direct . Pickup coils etc would have meant a tougher timing process, well time consuming also. May i'll try later by a month or so as my next crank set gets ready.& yes the wiring has become much funny. No mech would want to touch it! |
| | #67 (permalink) |
| Tuff times. Getting parts machined & made is taking too much time that i'm losing my mind on further improvements. Like 10 days for a single piece from lathe shop is . It takes 2 more w/shops to finish my crank assy machining in this part of country. It is accurate quality job, but !! Coudn't find a shop doing lathe-milling-surface grinding all with same quality (& affordable?) hence many shops. Waste of time. Feels like attempting nothing more at all. |
| | #68 (permalink) |
| tic..tic..titic...turrrr... ![]() what actually started as building a parallel twin has now become more of an experiment trying out different crank sets and tuning states. Hope it be of some help in future. While at machining for a 90 degree crank, it some how stuck me hard to try a 360 setup & thus it runs now. I couldn't find much on the net about 2 stokes apart from vibration prone nature. Its seemed who-knows-how it runs actual on a small capacity engine tempting me to try out. Results has been quite interesting. Engine responds mostly as like with 180 but induces some vibrations on to body parts at high rpm's. can feel the tank but not on foot peg or handle bar. It has just clocked some 200kms now on this crank. It actually would turn out a test for crank toughness also to handle stress. Fun part is that i could not kick it over to start & had to add couple of gaskets to slightly lower the compression ratio. Don't say to kick it hard, it just wont budge. Similar was my trial with 90 crank. It was too good that i would fix 90 as final form in my twin with a new piece expected by month end. Mean while I met a mechanic very close by who works on RD's & some Honda multi cyls. Glad that he is knowledgeable & readily offered help. Took the bike for a tuning check since cylinders were out-of-sync while idling or rolling off throttle. After a couple of question on status of cylinder sizes, carb, reed, exhaust conditions etc, he told me to remove the intake manifold with balancer tubing. To my surprise both cyl's got similar on regular manifolds. I might keep it for the 90. His shop I feel like a finishing school for my kid. Ok., I need some info > What differences both '+/-' does a small capacity 360 degree twin has in comparison to same CC single? lets consider power delivery & rideability related characteristics only & leave those of constructional-cost-fuel efficiency. bye., |
| | #69 (permalink) |
| ^ Ok here it is. just my points wrf 360 set> more like a single barring instant throttle response, vibrations turn irritating as well- not much rideable for long. Good for riding around in top gear :-) Dropped 360 for now & same Crank has been reset to the classic 180 degree. Runs smooth, sound good with twin exhaust pipes. But don't know how long would the crank last. reason ? rocking couple (more like alternating twist forces due to opposite direction of movement of pistons, crank weights in either cyls) at the crank joint strong enough to shear it off. See image wrf different cranks. 'P' is primary & 'S' is secondary inertia forces of crank assy. |
| | #70 (permalink) |
| So here it is- Hopefully my closing post. They say pictures better words, so it be. & yes, specs: main feature for me is the 90degree crankset running beautiful. Thnx to buddies Titus & Anand for photos. ![]() ![]() ![]() ![]() ![]() ![]() ![]() bye., |
| | #71 (permalink) | |
| Team-BHP Support ![]() | Quote:
Do you know what kind of crank was used by the legendary RD350 ??
__________________ The difference between the men and the boys....................is the speed of their toys. | |
| | #74 (permalink) |
| BHPian Join Date: Aug 2004 Location: Ponda , Goa
| I guess I dropped in a little late in the thread , the work is awesome Rennjit. On the topic of the CDI - there was an article in silicon chip (september 1997) on how to make your own programmable CDI - If you can find the article somewhere and can build it yourself or get someone to build it for you , you will not need to find some other CDI to modify and adapt for your bike! I google'd a bit and came accross this Programmable High Energy Ignition System - Jaycar Electronics this seems to be a kit based on the same silicon chip design - and it doesn't cost the earth either - maybe you could give it a shot . In case you decide to build it yourself the CDI shouldn't cost you more than a few hundred rupees ![]() Last edited by techn0l0gist : 14th November 2009 at 00:39. |
| | #75 (permalink) |
| BHPian | Neat mods, rennjith
__________________ When the road ends, I make my own road 1984 Ambassador (Sold)/Indica Vista TDi/Bullet STD 350/Unicorn/FireFox Fusion |
| Thread Tools | |
Similar Threads | ||||
| Hi Everyone at BHP(Be Hope Personified) | Ushuaia | Introduce yourself | 3 | 10th March 2010 00:36 |
| No hope for this country at all | Nikhilb2008 | Shifting gears | 66 | 16th February 2009 00:36 |
| Oil prices to hit USD 200 a barrel | DieselFan | Shifting gears | 30 | 19th June 2008 18:49 |
| BEWARE : P200 Fork Barrel - Might kill you! | pawan_pullarwar | Motorbikes | 33 | 13th May 2007 03:24 |
| Hope all's well with you Mumbaikars | pdev29 | Shifting gears | 109 | 14th July 2006 18:56 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698
