Old 6th December 2009, 23:48   #76
Rennjit's Avatar
Thanked: 77 Times
Adding one of completed proto. 90deg phase crank gives uneven exhaust note & replica shogun muffler assy cuts much sound wrf stock samurai's. Don't know when would i be able to make a proper video of it running on road or at least that of an engine pulse tacho clipped on. I tried capturing an on-road audio track with an old cellphone taped to rear fender but it got too noisy.
bye.,
Rennjit is offline   Reply With Quote
Old 7th December 2009, 01:48   #77
Thanked: 296 Times
WOW amazing job. I still potter around on a Suzuki Samurai. Planning to upgrade to an RD 350 for the past 15 years. Someday!!
wildsdi5530 is offline   Reply With Quote
Old 19th April 2011, 16:09   #78
Rennjit's Avatar
Thanked: 77 Times
Exclamation zundapp twin
Found this Twin cyl topic on Zundapp forum. Its a good ref with detail pics but sadly needs a login to see and its in dutch. still a worthy effort for those seriously interested. And yes the machine seen here is superbly finished.
Old 19th April 2011, 21:42   #79
yamdoot's Avatar
Thanked: 12 Times
Default Re: The Double Barrel of Hope : AX-200 twin
Long time Rennjit! Hows the bike running ? I love the twin layout.. reminds me of 80's Suzuki GTs.. have you thought of trying a balance tube between carb manifolds? [Like they have on the RDs] ? For this you can simply use two Supra powerbox manifolds and connect them with a hose.
yamdoot is offline   Reply With Quote
Old 23rd December 2013, 16:41   #80
Hi Rennjith any chance you still have this Bike/setup, would love to do something like this on my own Samnurai/Supra. let me know
AJ
AdityaJayaram is offline   Reply With Quote
Old 28th December 2013, 06:50   #81
Rennjit's Avatar
Thanked: 77 Times
hi AdityaJayaram, I have the engine but it is lying split up now. The bike's registration expired & to present it to Rto, i had to put it back to normal form. Next time, may be couple of years later for just the fun of doing it & as i have so much parts lying around, i'd do a narrow welded case engine & put it in an older broader chassis than the skinny suzuki. It'd look weird
Supra barrels would be much more interesting than samurai's. pl do share it if you intend to proceed.
Rennjit is offline   (1) Thanks Reply With Quote
Old 3rd January 2016, 11:41   #82
Hi Renjith, sorry about this late post i had'nt logged back in to check, I hope you are well
I still have my samurai, (expired registration ) its running a supra block with a .5 shogun piston i would still love to do this if you're keen . I'm in bangalore. Do pm me you're number and we can get in touch. i have a spare stock supra block as well.
I can probably source all the parts for this project from the scrap yard or some contacts of mine
Cheers,
Aditya
Old 2nd January 2017, 19:54   #83
is this the right place to upload it
vishvesshpoddar is offline   Reply With Quote
Oil Barrel - how much of what does it contain calm_cruiser Technical Stuff 1 18th September 2010 06:55
Oil prices to hit USD 200 a barrel DieselFan Shifting gears 30 19th June 2008 18:49
ECM Info for Phase 3 Baleno 1.6(should be similar for our version I hope) ECM Technical Stuff 15 10th February 2008 18:00
BEWARE : P200 Fork Barrel - Might kill you! pawan_pullarwar Motorbikes 33 13th May 2007 03:24
Hope all's well with you Mumbaikars pdev29 Shifting gears 109 14th July 2006 18:56
